Collaboration diagram for Module for physical constants:Modules | |
| Module for turbulence constants | |
| double precision | tkelvi |
| Temperature in Kelvin correponding to 0 degrees Celsius (= +273,15) More... | |
| double precision | xcal2j |
| Calories (1 cvar_al = xcal2j J) More... | |
| double precision | stephn |
Stephan constant for the radiative module in . More... | |
| real(c_double), pointer, save | rair |
| Perfect gas constant for air (mixture) More... | |
| real(c_double), pointer, save | rvsra |
| ratio gaz constant h2o/ dry air More... | |
| real(c_double), pointer, save | clatev |
| latent heat of evaporation More... | |
| double precision | kboltz |
Boltzmann constant ( ) More... | |
| double precision | cs_physical_constants_r |
Ideal gas constant ( ) More... | |
| real(c_double), pointer, save | gx |
| Gravity. More... | |
| real(c_double), pointer, save | gy |
| real(c_double), pointer, save | gz |
| integer(c_int), pointer, save | icorio |
| Coriolis effects. More... | |
| integer(c_int), pointer, save | ixyzp0 |
| Physical constants of the fluid filling xyzp0 indicator. More... | |
| integer(c_int), pointer, save | icp |
indicates if the isobaric specific heat is variable: More... | |
| integer(c_int), pointer, save | icv |
isochoric specific heat More... | |
| integer(c_int), pointer, save | irovar |
variable density field : More... | |
| integer(c_int), pointer, save | ivivar |
variable viscosity field : More... | |
| integer(c_int), pointer, save | ivsuth |
| Sutherland law for laminar viscosity and thermal conductivity Only useful in gas mix (igmix) specific physics. More... | |
| real(c_double), pointer, save | ro0 |
| reference density. More... | |
| real(c_double), pointer, save | viscl0 |
| reference molecular dynamic viscosity. More... | |
| real(c_double), pointer, save | p0 |
| reference pressure for the total pressure. More... | |
| real(c_double), pointer, save | pred0 |
reference value for the reduced pressure (see ro0).More... | |
| real(c_double), dimension(:), pointer, save | xyzp0 |
coordinates of the reference point for the total pressure. More... | |
| real(c_double), pointer, save | t0 |
| reference temperature. More... | |
| double precision, save | eint0 |
| Reference internal energy for the barotropic compressible module. More... | |
| real(c_double), pointer, save | cp0 |
| reference specific heat. More... | |
| real(c_double), pointer, save | cv0 |
| Reference isochoric specific heat. More... | |
| real(c_double), pointer, save | lambda0 |
| Reference thermal conductivity. More... | |
| real(c_double), pointer, save | xmasmr |
Molar mass of the perfect gas in (if ieos=1) More... | |
| integer(c_int), pointer, save | ipthrm |
| Uniform variable thermodynamic pressure for the low-Mach algorithm. More... | |
| real(c_double), pointer, save | pther |
| Thermodynamic pressure for the current time step. More... | |
| real(c_double), pointer, save | pthera |
| Thermodynamic pressure for the previous time step. More... | |
| real(c_double), pointer, save | pthermax |
| pthermax: Thermodynamic maximum pressure for user clipping, used to model a venting effect More... | |
| real(c_double), pointer, save | sleak |
| Leak surface. More... | |
| real(c_double), pointer, save | kleak |
| Leak head loss (2.9 by default, from Idelcick) More... | |
| real(c_double), pointer, save | roref |
| Initial reference density. More... | |
| real(c_double), pointer, save clatev |
| real(c_double), pointer, save cp0 |
Useful if there is 1 <= n <= nscaus, so that iscalt = n and itherm = 1 (there is a "temperature" scalar), unless the user specifies the specific heat in the user subroutine cs_user_physical_properties (icp > 0) with the compressible module or coal combustion, cp0 is also needed even when there is no user scalar.
| double precision cs_physical_constants_r |
| real(c_double), pointer, save cv0 |
Useful for the compressible module (J/kg/K)
| double precision, save eint0 |
| real(c_double), pointer, save gx |
Gravity.
| real(c_double), pointer, save gy |
| real(c_double), pointer, save gz |
| integer(c_int), pointer, save icorio |
Coriolis effects.
| integer(c_int), pointer, save icp |
is variable:
is declared as a property field
). With the electric module, it is automatically set to 1. The user is not allowed to modify these default choices.
is then specified by the user in the appropriate subroutine (cs_user_physical_properties for the standard physics).| integer(c_int), pointer, save icv |
| integer(c_int), pointer, save ipthrm |
| integer(c_int), pointer, save irovar |
| integer(c_int), pointer, save ivivar |
| integer(c_int), pointer, save ivsuth |
| integer(c_int), pointer, save ixyzp0 |
| double precision kboltz |
| real(c_double), pointer, save kleak |
| real(c_double), pointer, save lambda0 |
Useful with thermal model (W/m/K)
| real(c_double), pointer, save p0 |
| real(c_double), pointer, save pred0 |
(see ro0).
It is especially used to initialise the reduced pressure and as a reference value for the outlet boundary conditions. For an optimised precision in the resolution of
, it is wiser to keep pred0 to 0. With the compressible module, the "pressure" variable appearing in the equations directly represents the total pressure. It is therefore initialized to p0 and not pred0 (see ro0). Always useful, except with the compressible module
| real(c_double), pointer, save pther |
| real(c_double), pointer, save pthera |
| real(c_double), pointer, save pthermax |
| real(c_double), pointer, save rair |
| real(c_double), pointer, save ro0 |
reference density.
Negative value: not initialized. Its value is not used in gas or coal combustion modelling (it will be calculated following the perfect gas law, with
and
). With the compressible module, it is also not used by the code, but it may be (and often is) referenced by the user in user subroutines; it is therefore better to specify its value.
Always useful otherwise, even if a law defining the density is given by the user subroutines cs_user_physical_properties. indeed, except with the compressible module, CS does not use the total pressure
when solving the Navier-Stokes equation, but a reduced pressure .
. where
is a reference point (see xyzp0) and
and
are reference values (see pred0 and p0). Hence, the term
in the equation is treated as
. The closer ro0 is to the value of
, the more
will tend to represent only the dynamic part of the pressure and the faster and more precise its solution will be. Whatever the value of ro0, both
and
appear in the log and the post-processing outputs.. with the compressible module, the calculation is made directly on the total pressure
| real(c_double), pointer, save roref |
| real(c_double), pointer, save rvsra |
| real(c_double), pointer, save sleak |
Leak surface.
| double precision stephn |
in
| real(c_double), pointer, save t0 |
Useful for the specific physics gas or coal combustion (initialization of the density), for the electricity modules to initialize the domain temperature and for the compressible module (initializations). It must be given in Kelvin.
| double precision tkelvi |
| real(c_double), pointer, save viscl0 |
Negative value: not initialized. Always useful, it is the used value unless the user specifies the viscosity in the subroutine cs_user_physical_properties
| double precision xcal2j |
| real(c_double), pointer, save xmasmr |
(if ieos=1)
Always useful
| real(c_double), dimension(:), pointer, save xyzp0 |
equals p0 at this face). Nonetheless, if xyzp0 is specified by the user, the calculation will remain correct.Always useful, except with the compressible module.
