Collaboration diagram for Module for turbulence constants:Variables | |
| double precision, save | xkappa |
Karman constant. (= 0.42) Useful if and only if iturb >= 10. (mixing length, , , LES, v2f or ) More... | |
| double precision, save | cstlog |
constant of logarithmic law function: ( ) constant of the logarithmic wall function. Useful if and only if iturb >= 10 (mixing length, , , LES, v2f or ) More... | |
| real(c_double), pointer, save | ypluli |
limit value of for the viscous sublayer. ypluli depends on the chosen wall function: it is initialized to 10.88 for the scalable wall function (iwallf=4), otherwise it is initialized to . In LES, ypluli is taken by default to be 10.88. More... | |
| double precision, save | apow |
| Werner and Wengle coefficient. More... | |
| double precision, save | bpow |
| double precision, save | cpow |
| double precision, save | dpow |
| real(c_double), pointer, save | cmu |
constant for all the RANS turbulence models Warning, different values for the v2f model Useful if and only if iturb = 20, 21, 30, 31, 50, 51 or 60 ( , or ) More... | |
| real(c_double), pointer, save | cmu025 |
More... | |
| real(c_double), pointer, save | ce1 |
constant for all the RANS turbulence models except for the v2f and the models. Useful if and only if iturb= 20, 21, 30 or 31 ( or ) More... | |
| real(c_double), pointer, save | ce2 |
constant for the and LRR models. Useful if and only if iturb= 20, 21 or 30 ( or LRR) More... | |
| double precision, save | cnl1 |
constant for the model from Baglietto et al. (quadratric) Useful if and only if iturb= 23 More... | |
| double precision, save | cnl2 |
| double precision, save | cnl3 |
| double precision, save | cnl4 |
| double precision, save | cnl5 |
| double precision, save | ce4 |
| Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment. More... | |
| real(c_double), pointer, save | crij1 |
constant for the LRR model. Useful if and only if iturb=30 ( LRR) More... | |
| real(c_double), pointer, save | crij2 |
| real(c_double), pointer, save | crij3 |
constant for the buoyant production term models. More... | |
| double precision, save | crijp1 |
constant for the LRR model, corresponding to the wall echo terms. Useful if and only if iturb=30 and irijec=1 ( LRR) More... | |
| double precision, save | crijp2 |
| double precision, save | cssge2 |
constant for the SSG model. Useful if and only if iturb=31 ( SSG) More... | |
| double precision, save | cssgs1 |
| double precision, save | cssgs2 |
| double precision, save | cssgr1 |
| double precision, save | cssgr2 |
| double precision, save | cssgr3 |
| double precision, save | cssgr4 |
| double precision, save | cssgr5 |
| double precision, save | cebms1 |
| constant of the Rij-epsilon EBRSM More... | |
| double precision, save | cebms2 |
| double precision, save | cebmr1 |
| double precision, save | cebmr2 |
| double precision, save | cebmr3 |
| double precision, save | cebmr4 |
| double precision, save | cebmr5 |
| real(c_double), pointer, save | csrij |
constant for the models. More... | |
| double precision, save | cebme2 |
| double precision, save | cebmmu |
| double precision, save | xcl |
| double precision, save | xa1 |
| constant in the expression of Ce1' for the Rij-epsilon EBRSM More... | |
| double precision, save | xct |
| double precision, save | xceta |
| double precision, save | cpale1 |
| specific constant of v2f "BL-v2k" (or phi-alpha) More... | |
| double precision, save | cpale2 |
| double precision, save | cpale3 |
| double precision, save | cpale4 |
| double precision, save | cpalc1 |
| double precision, save | cpalc2 |
| double precision, save | cpalct |
| double precision, save | cpalcl |
| double precision, save | cpalet |
| double precision, save | ckwsk1 |
constant for the SST model. Useful if and only if iturb=60 More... | |
| double precision, save | ckwsk2 |
| double precision, save | ckwsw1 |
constant for the SST model. Useful if and only if iturb=60 ( SST) More... | |
| double precision, save | ckwsw2 |
| double precision, save | ckwbt1 |
| double precision, save | ckwbt2 |
| real(c_double), pointer, save | cddes |
constant for the hybrid SST model. Useful if and only if iturb=60 ( SST) and hybrid_turb=1 More... | |
| real(c_double), pointer, save | csas |
constant for the hybrid SST model. Useful if and only if iturb=60 ( SST) and hybrid_turb=3 More... | |
| real(c_double), pointer, save | csas_eta2 |
| real(c_double), pointer, save | chtles_bt0 |
constant for the HTLES model. Useful if and only if iturb=60 ( SST) or if iturb=51 ( ), and hybrid_turb=4 More... | |
| double precision, save | ckwgm1 |
| double precision, save | ckwgm2 |
| double precision, save | ckwa1 |
specific constant of k-omega SST constant for the SST model. Useful if and only if iturb=60 ( SST) More... | |
| double precision, save | ckwc1 |
constant for the SST model. Useful if and only if iturb=60 ( SST) specific constant of k-omega SST More... | |
| double precision, save | csab1 |
| specific constant of Spalart-Allmaras More... | |
| double precision, save | csab2 |
| double precision, save | csasig |
| double precision, save | csav1 |
| double precision, save | csaw1 |
| double precision, save | csaw2 |
| double precision, save | csaw3 |
| double precision, save | cssr1 |
| constant of the Spalart-Shur rotation/curvature correction More... | |
| double precision, save | cssr2 |
| double precision, save | cssr3 |
| real(c_double), pointer, save | almax |
| is a characteristic macroscopic length of the domain, used for the initialization of the turbulence and the potential clipping (with iclkep=1) More... | |
| real(c_double), pointer, save | uref |
| the characteristic flow velocity, used for the initialization of the turbulence. Negative value: not initialized. More... | |
| real(c_double), pointer, save | xlomlg |
| mixing length for the mixing length model More... | |
| real(c_double), pointer, save | xlesfl |
constant used in the definition of LES filtering diameter: xlesfl is a constant used to define, for each cell , the width of the (implicit) filter: ![]() Useful if and only if iturb = 40 or 41 More... | |
| real(c_double), pointer, save | ales |
constant used to define, for each cell , the width of the (implicit) filter: More... | |
| real(c_double), pointer, save | bles |
constant used to define, for each cell , More... | |
| real(c_double), pointer, save | csmago |
Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by where is the width of the filter and the filtered strain rate. More... | |
| real(c_double), pointer, save | xlesfd |
ratio between explicit and explicit filter width for a dynamic model constant used to define, for each cell , the width of the explicit filter used in the framework of the LES dynamic model: . More... | |
| real(c_double), pointer, save | smagmx |
maximum allowed value for the variable appearing in the LES dynamic model. Any larger value yielded by the calculation procedure of the dynamic model will be clipped to . More... | |
| real(c_double), pointer, save | smagmn |
minimum allowed value for the variable appearing in the LES dynamic model. Any smaller value yielded by the calculation procedure of the dynamic model will be clipped to . More... | |
| real(c_double), pointer, save | cdries |
| van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant: More... | |
| double precision, save | volmin |
| minimal control volume More... | |
| double precision, save | volmax |
| maximal control volume More... | |
| double precision, save | voltot |
| total domain volume More... | |
| double precision, save | cv2fa1 |
constant for the v2f -model. Useful if and only if iturb=50 (v2f -model) More... | |
| double precision, save | cv2fe2 |
| double precision, save | cv2fc1 |
| double precision, save | cv2fc2 |
| double precision, save | cv2fct |
| double precision, save | cv2fcl |
| double precision, save | cv2fet |
| real(c_double), pointer, save | cwale |
| constant of the WALE LES method More... | |
| double precision, save | xiafm |
| coefficient of turbulent AFM flow model More... | |
| double precision, save | etaafm |
| real(c_double), pointer, save | c1trit |
| coefficient of turbulent DFM flow model More... | |
| real(c_double), pointer, save | c2trit |
| real(c_double), pointer, save | c3trit |
| real(c_double), pointer, save | c4trit |
| double precision, save | cthafm |
| constant of GGDH and AFM on the thermal scalar More... | |
| double precision, save | cthdfm |
| double precision, save | xclt |
| constant of EB-AFM and EB-DFM More... | |
| double precision, save | rhebdfm |
| constant of EB-DFM More... | |
| double precision, save | cthebdfm |
| real(c_double), pointer, save ales |
Useful if and only if iturb = 40 or 41.
| real(c_double), pointer, save almax |
Useful if and only if iturb = 20, 21, 30, 31, 50 or 60 (RANS models)
| double precision, save apow |
| real(c_double), pointer, save bles |
| double precision, save bpow |
| real(c_double), pointer, save c1trit |
| real(c_double), pointer, save c2trit |
| real(c_double), pointer, save c3trit |
| real(c_double), pointer, save c4trit |
| real(c_double), pointer, save cddes |
constant
for the hybrid
| real(c_double), pointer, save cdries |
.Useful if and only if iturb = 40 or 41
| real(c_double), pointer, save ce1 |
constant
or
| real(c_double), pointer, save ce2 |
constant
for the
and
or
LRR)
| double precision, save ce4 |
constant
for the interfacial term (Lagrangian module) in case of two-way coupling. Useful in case of Lagrangian modelling, in
and
with two-way coupling.
| double precision, save cebme2 |
| double precision, save cebmmu |
| double precision, save cebmr1 |
| double precision, save cebmr2 |
| double precision, save cebmr3 |
| double precision, save cebmr4 |
| double precision, save cebmr5 |
| double precision, save cebms1 |
| double precision, save cebms2 |
| real(c_double), pointer, save chtles_bt0 |
| double precision, save ckwa1 |
for the
SST)
| double precision, save ckwbt1 |
constant
for the
SST)
| double precision, save ckwbt2 |
constant
for the
SST)
| double precision, save ckwc1 |
constant
for the
| double precision, save ckwgm1 |
| double precision, save ckwgm2 |
| double precision, save ckwsk1 |
constant
for the
| double precision, save ckwsk2 |
constant
for the
| double precision, save ckwsw1 |
constant
for the
SST)
| double precision, save ckwsw2 |
constant
for the
SST)
| real(c_double), pointer, save cmu |
constant
or
| real(c_double), pointer, save cmu025 |
| double precision, save cnl1 |
constant
for the
| double precision, save cnl2 |
constant
for the
| double precision, save cnl3 |
constant
for the
| double precision, save cnl4 |
constant
for the
| double precision, save cnl5 |
constant
for the
| double precision, save cpalc1 |
| double precision, save cpalc2 |
| double precision, save cpalcl |
| double precision, save cpalct |
| double precision, save cpale1 |
| double precision, save cpale2 |
| double precision, save cpale3 |
| double precision, save cpale4 |
| double precision, save cpalet |
| double precision, save cpow |
| real(c_double), pointer, save crij1 |
constant
for the
LRR)
| real(c_double), pointer, save crij2 |
constant
for the
LRR)
| real(c_double), pointer, save crij3 |
constant
models.
| double precision, save crijp1 |
| double precision, save crijp2 |
| double precision, save csab1 |
| double precision, save csab2 |
| real(c_double), pointer, save csas |
constant
for the hybrid
| real(c_double), pointer, save csas_eta2 |
constant
for the hybrid
| double precision, save csasig |
| double precision, save csav1 |
| double precision, save csaw1 |
| double precision, save csaw2 |
| double precision, save csaw3 |
| real(c_double), pointer, save csmago |
where
| real(c_double), pointer, save csrij |
constant
for the
models.
| double precision, save cssge2 |
constant
for the
SSG)
| double precision, save cssgr1 |
constant
for the
SSG)
| double precision, save cssgr2 |
constant
for the
SSG)
| double precision, save cssgr3 |
constant
for the
SSG)
| double precision, save cssgr4 |
constant
for the
SSG)
| double precision, save cssgr5 |
constant
for the
SSG)
| double precision, save cssgs1 |
constant
for the
SSG)
| double precision, save cssgs2 |
constant
for the
SSG)
| double precision, save cssr1 |
| double precision, save cssr2 |
| double precision, save cssr3 |
| double precision, save cstlog |
, LES, v2f or
| double precision, save cthafm |
| double precision, save cthdfm |
| double precision, save cthebdfm |
| double precision, save cv2fa1 |
constant
for the v2f
-model)
| double precision, save cv2fc1 |
constant
for the v2f
-model)
| double precision, save cv2fc2 |
constant
for the v2f
-model)
| double precision, save cv2fcl |
constant
for the v2f
-model)
| double precision, save cv2fct |
constant
for the v2f
-model)
| double precision, save cv2fe2 |
constant
for the v2f
-model)
| double precision, save cv2fet |
constant
for the v2f
-model)
| real(c_double), pointer, save cwale |
| double precision, save dpow |
| double precision, save etaafm |
| double precision, save rhebdfm |
constant of EB-DFM
| real(c_double), pointer, save smagmn |
Useful if and only if iturb = 41
| real(c_double), pointer, save smagmx |
| real(c_double), pointer, save uref |
Useful if and only if iturb= 20, 21, 30, 31, 50 or 60 (RANS model) and the turbulence is not initialized somewhere else (restart file or subroutine cs_user_initialization)
| double precision, save volmax |
| double precision, save volmin |
| double precision, save voltot |
total domain volume
| double precision, save xa1 |
| double precision, save xceta |
| double precision, save xcl |
| double precision, save xclt |
| double precision, save xct |
| double precision, save xiafm |
| double precision, save xkappa |
, LES, v2f or
| real(c_double), pointer, save xlesfd |
| real(c_double), pointer, save xlesfl |
| real(c_double), pointer, save xlomlg |
Useful if and only if iturb= 10 (mixing length)
