#include "cs_field_default.h"
#include "cs_field_pointer.h"
#include "cs_map.h"
#include "cs_parameters.h"
#include "cs_porous_model.h"
#include "cs_mesh_location.h"
#include "cs_time_step.h"
#include "cs_velocity_pressure.h"
cs_velocity_pressure_model_t * | cs_get_glob_velocity_pressure_model (void) |
cs_velocity_pressure_param_t * | cs_get_glob_velocity_pressure_param (void) |
Provide access to cs_glob_velocity_pressure_param. More... | |
void | cs_velocity_pressure_set_n_buoyant_scalars (void) |
void | cs_velocity_pressure_set_solid (void) |
void | cs_velocity_pressure_model_log_setup (void) |
Print the volocity-pressure model parameters to setup log. More... | |
void | cs_velocity_pressure_param_log_setup (void) |
Print Velocity-pressure parameters to setup.log. More... | |
Velocity-pressure coupling model and parameters.
cs_velocity_pressure_model_t* cs_get_glob_velocity_pressure_model | ( | void | ) |
cs_velocity_pressure_param_t* cs_get_glob_velocity_pressure_param | ( | void | ) |
void cs_velocity_pressure_model_log_setup | ( | void | ) |
Print the stokes model parameters to setup.log.
void cs_velocity_pressure_param_log_setup | ( | void | ) |
void cs_velocity_pressure_set_n_buoyant_scalars | ( | void | ) |
void cs_velocity_pressure_set_solid | ( | void | ) |
