7.1
cs_mesh_quantities.c File Reference
Management of mesh quantities. More...
#include <float.h>
#include "cs_halo_perio.h"
#include "cs_math.h"
#include "cs_mesh_connect.h"
#include "cs_bad_cells_regularisation.h"
+ Include dependency graph for cs_mesh_quantities.c:
int cs_mesh_quantities_cell_cen_choice (int algo_choice)
 Query or modification of the option for computing cell centers. More...
int cs_mesh_quantities_face_cog_choice (int algo_choice)
 Query or modification of the option for computing face centers. More...
cs_mesh_quantities_tcs_mesh_quantities_create (void)
 Create a mesh quantities structure. More...
cs_mesh_quantities_tcs_mesh_quantities_destroy (cs_mesh_quantities_t *mq)
 Destroy a mesh quantities structure. More...
void cs_mesh_quantities_free_all (cs_mesh_quantities_t *mq)
 Reset a mesh quantities structure to its empty initial state. More...
void cs_mesh_quantities_compute_preprocess (const cs_mesh_t *m, cs_mesh_quantities_t *mq)
 Compute mesh quantities needed for preprocessing. More...
void cs_mesh_quantities_compute (const cs_mesh_t *m, cs_mesh_quantities_t *mq)
 Compute mesh quantities. More...
void cs_mesh_quantities_fluid_compute (const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
void cs_mesh_quantities_fluid_vol_reductions (const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
void cs_mesh_init_fluid_sections (const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
void cs_mesh_quantities_sup_vectors (const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
void cs_mesh_quantities_face_normal (const cs_mesh_t *mesh, cs_real_t *p_i_face_normal[], cs_real_t *p_b_face_normal[])
void cs_mesh_quantities_i_faces (const cs_mesh_t *mesh, cs_real_t *p_i_face_cog[], cs_real_t *p_i_face_normal[])
void cs_mesh_quantities_b_faces (const cs_mesh_t *mesh, cs_real_t *p_b_face_cog[], cs_real_t *p_b_face_normal[])
void cs_mesh_quantities_cell_faces_cog (const cs_mesh_t *mesh, const cs_real_t i_face_norm[], const cs_real_t i_face_cog[], const cs_real_t b_face_norm[], const cs_real_t b_face_cog[], cs_real_t cell_cen[])
 Compute approximate cells centers as the mean of the given face centers weighted by the associated surfaces. More...
cs_real_tcs_mesh_quantities_cell_volume (const cs_mesh_t *mesh)
void cs_mesh_quantities_check_vol (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int allow_error)
cs_real_6_tcs_mesh_quantities_cell_extents (const cs_mesh_t *m, cs_real_t tolerance)
 Compute the bounding box for cells. More...
int cs_mesh_quantities_compute_count (void)
void cs_mesh_quantities_b_thickness_v (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, int n_passes, cs_real_t b_thickness[])
 Determine local boundary thickness around each vertex. More...
void cs_mesh_quantities_b_thickness_f (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, int n_passes, cs_real_t b_thickness[])
 Determine local boundary thickness around each boundary face. More...
void cs_mesh_quantities_log_setup (void)
 Log mesh quantities options to setup file. More...
void cs_mesh_quantities_dump (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
Please refer to the geometric quantities section of the theory guide for more informations.
◆ cs_mesh_init_fluid_sections()
void cs_mesh_init_fluid_sections ( const cs_mesh_t mesh,
cs_mesh_quantities_t mesh_quantities
◆ cs_mesh_quantities_b_faces()
void cs_mesh_quantities_b_faces ( const cs_mesh_t mesh,
cs_real_t p_b_face_cog[],
cs_real_t p_b_face_normal[]
◆ cs_mesh_quantities_b_thickness_f()
void cs_mesh_quantities_b_thickness_f ( const cs_mesh_t m,
const cs_mesh_quantities_t mq,
int  n_passes,
[in]mpointer to mesh structure
[in]mqpointer to mesh quantities structures.
[in]n_passesnumber of optional smoothing passes
[out]b_thicknessthickness for each mesh boundary face
◆ cs_mesh_quantities_b_thickness_v()
void cs_mesh_quantities_b_thickness_v ( const cs_mesh_t m,
int  n_passes,
[in]n_passesnumber of smoothing passes
[out]b_thicknessthickness for each mesh vertex (0 at non-boundary vertices)
◆ cs_mesh_quantities_cell_cen_choice()
int cs_mesh_quantities_cell_cen_choice ( int  algo_choice)
[in]algo_choice< 0 : query 0 : computation based on face centers (default) 1 : computation by cell sub-volumes
0 or 1 according to the selected algorithm
◆ cs_mesh_quantities_cell_extents()
cs_real_6_t* cs_mesh_quantities_cell_extents ( const cs_mesh_t m,
cs_real_t  tolerance
The corresponding array is allocated by this function, and it is the caller's responsability to free it when they are no longer needed.
[in]toleranceaddition to local extents of each element: extent = base_extent * (1 + tolerance)
pointer to newly allocated cell volumes array
◆ cs_mesh_quantities_cell_faces_cog()
void cs_mesh_quantities_cell_faces_cog ( const cs_mesh_t mesh,
n-1 Sum Surf(Fi) G(Fi) i=0 G(C) = --------------------— n-1 Sum Surf(Fi) i=0
[in]meshpointer to mesh structure
[in]i_face_normsurface normal of internal faces
[in]i_face_cogcenter of gravity of internal faces
[in]b_face_normsurface normal of border faces
[in]b_face_cogcenter of gravity of border faces
[out]cell_cencell centers
◆ cs_mesh_quantities_cell_volume()
cs_real_t* cs_mesh_quantities_cell_volume ( const cs_mesh_t mesh)
◆ cs_mesh_quantities_check_vol()
void cs_mesh_quantities_check_vol ( const cs_mesh_t mesh,
const cs_mesh_quantities_t mesh_quantities,
int  allow_error
◆ cs_mesh_quantities_compute()
void cs_mesh_quantities_compute ( const cs_mesh_t m,
[in,out]mqpointer to mesh quantities structures.
◆ cs_mesh_quantities_compute_count()
int cs_mesh_quantities_compute_count ( void  )
◆ cs_mesh_quantities_compute_preprocess()
void cs_mesh_quantities_compute_preprocess ( const cs_mesh_t m,
◆ cs_mesh_quantities_create()
cs_mesh_quantities_t* cs_mesh_quantities_create ( void  )
pointer to created cs_mesh_quantities_t structure
◆ cs_mesh_quantities_destroy()
cs_mesh_quantities_t* cs_mesh_quantities_destroy ( cs_mesh_quantities_t mq)
NULL
◆ cs_mesh_quantities_dump()
void cs_mesh_quantities_dump ( const cs_mesh_t mesh,
◆ cs_mesh_quantities_face_cog_choice()
int cs_mesh_quantities_face_cog_choice ( int  algo_choice)
[in]algo_choice< 0 : query 0 : standard computation 1 : use adjustment for volume from versions 1.1 to 5.3
◆ cs_mesh_quantities_face_normal()
void cs_mesh_quantities_face_normal ( const cs_mesh_t mesh,
cs_real_t p_i_face_normal[],
◆ cs_mesh_quantities_fluid_compute()
void cs_mesh_quantities_fluid_compute ( const cs_mesh_t mesh,
◆ cs_mesh_quantities_fluid_vol_reductions()
void cs_mesh_quantities_fluid_vol_reductions ( const cs_mesh_t mesh,
◆ cs_mesh_quantities_free_all()
void cs_mesh_quantities_free_all ( cs_mesh_quantities_t mq)
◆ cs_mesh_quantities_i_faces()
void cs_mesh_quantities_i_faces ( const cs_mesh_t mesh,
cs_real_t p_i_face_cog[],
◆ cs_mesh_quantities_log_setup()
void cs_mesh_quantities_log_setup ( void  )
◆ cs_mesh_quantities_sup_vectors()
void cs_mesh_quantities_sup_vectors ( const cs_mesh_t mesh,
