7.1
cs_bad_cells_regularisation.h
1 #ifndef __CS_BAD_CELLS_REGULARISATION_H__
2 #define __CS_BAD_CELLS_REGULARISATION_H__
5  * Divergence operators.
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_halo.h"
36
38
41 /*=============================================================================
42  * Local Macro definitions
46  * Type definition
48
50  * Global variables
52
54  * Public function prototypes for Fortran API
56
57 /*=============================================================================
58  * Public function prototypes
59  *============================================================================*/
60
61 /*----------------------------------------------------------------------------*/
67
68 void
70
71 void
73  int boundary_projection);
74
75 void
77  int boundary_projection);
78
79 void
81  int boundary_projection);
82
83 /*----------------------------------------------------------------------------*/
84
86
87 #endif /* __CS_BAD_CELLS_REGULARISATION_H__ */
void cs_bad_cells_regularisation_vector(cs_real_3_t *var, int boundary_projection)
Regularisation on bad cells for vectors.
Definition: cs_bad_cells_regularisation.c:209
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:337
void cs_bad_cells_regularisation_scalar(cs_real_t *var)
Add comments.
Definition: cs_bad_cells_regularisation.c:82
Definition: cs_defs.h:322
void cs_bad_cells_regularisation_tensor(cs_real_9_t *var, int boundary_projection)
Regularisation on bad cells for tensors.
Definition: cs_bad_cells_regularisation.c:571
cs_real_t cs_real_9_t[9]
Definition: cs_defs.h:339
void cs_bad_cells_regularisation_sym_tensor(cs_real_6_t *var, int boundary_projection)
Regularisation on bad cells for symmetric tensors.
Definition: cs_bad_cells_regularisation.c:389
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
