#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <float.h>#include <assert.h>#include "bft_mem.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_math.h"#include "cs_mesh_location.h"#include "cs_prototypes.h"#include "cs_parameters.h"#include "cs_time_step.h"#include "cs_physical_constants.h"#include "cs_parall.h"#include "cs_lagr.h"#include "cs_lagr_agglo.h"#include "cs_lagr_clogging.h"#include "cs_lagr_injection.h"#include "cs_lagr_particle.h"#include "cs_lagr_stat.h"#include "cs_random.h"#include "cs_lagr_fragmentation.h"
Include dependency graph for cs_lagr_fragmentation.c:Functions | |
| cs_lnum_t | cs_lagr_fragmentation (cs_real_t dt, cs_real_t minimum_particle_diam, cs_lnum_t main_start, cs_lnum_t main_end, cs_lnum_t agglo_start, cs_lnum_t agglo_end) |
| Particle fragmentation algorithm. More... | |
| cs_lnum_t cs_lagr_fragmentation | ( | cs_real_t | dt, |
| cs_real_t | minimum_particle_diam, | ||
| cs_lnum_t | main_start, | ||
| cs_lnum_t | main_end, | ||
| cs_lnum_t | agglo_start, | ||
| cs_lnum_t | agglo_end | ||
Parcels represent physical particles with similar properties (size). The number of physical particles in a parcel is represented by the statistical weight.
For each parcel, the number of fragmentation events is generated with a Poisson distribution that depends on the fragmentation kernel.
Working hypotheses: 1) Discrete diameters
Warning: particle indices are not necessarily contiguous (due to agglomeration occuring before).
Two contiguous groups: particles present before agglomeration newly created particles (due to agglomeration)
| [in] | dt | time step |
| [in] | minimum_particle_diam | minumum diameter (monomere diameter) |
| [in] | main_start | index of the first particle in cell present before the agglomeration |
| [in] | main_end | index after the last particle in cell, present before the agglomeration |
| [in] | agglo_start | index of the first particle in cell, created by the agglomeration |
| [in] | agglo_end | index after the last particle in cell, created by the agglomeration |
