Build an algebraic CDO vertex-based system for unsteady convection-diffusion-reaction of vector-valued equations with source terms. More...
#include <float.h>
#include <bft_mem.h>
#include "cs_cdo_advection.h"
#include "cs_cdo_bc.h"
#include "cs_cdo_diffusion.h"
#include "cs_cdo_local.h"
#include "cs_cdovb_priv.h"
#include "cs_equation_bc.h"
#include "cs_equation_common.h"
#include "cs_evaluate.h"
#include "cs_hodge.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_post.h"
#include "cs_quadrature.h"
#include "cs_reco.h"
#include "cs_scheme_geometry.h"
#include "cs_search.h"
#include "cs_sles.h"
#include "cs_source_term.h"
#include "cs_timer.h"
#include "cs_cdovb_vecteq.h"
bool | cs_cdovb_vecteq_is_initialized (void) |
Check if the generic structures for building a CDO-Vb scheme are allocated. More... | |
void | cs_cdovb_vecteq_init_common (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_structure_t *ms) |
Allocate work buffer and general structures related to CDO vector-valued vertex-based schemes Set shared pointers. More... | |
void | cs_cdovb_vecteq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb) |
Retrieve work buffers used for building a CDO system cellwise. More... | |
void | cs_cdovb_vecteq_finalize_common (void) |
Free work buffer and general structure related to CDO vertex-based schemes. More... | |
void * | cs_cdovb_vecteq_init_context (const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb) |
Initialize a cs_cdovb_vecteq_t structure storing data useful for building and managing such a scheme. More... | |
void * | cs_cdovb_vecteq_free_context (void *builder) |
Destroy a cs_cdovb_vecteq_t structure. More... | |
void | cs_cdovb_vecteq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Set the initial values of the variable field taking into account the boundary conditions. Case of vector-valued CDO-Vb schemes. More... | |
void | cs_cdovb_vecteq_solve_steady_state (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Build and solve the linear system arising from a vector steady-state convection/diffusion/reaction equation with a CDO-Vb scheme. One works cellwise and then process to the assembly. More... | |
void | cs_cdovb_vecteq_update_field (const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val) |
Store solution(s) of the linear system into a field structure Update extra-field values if required (for hybrid discretization) More... | |
cs_real_t * | cs_cdovb_vecteq_get_vertex_values (void *context, bool previous) |
Retrieve an array of values at mesh vertices for the variable field associated to the given context The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
cs_real_t * | cs_cdovb_vecteq_get_cell_values (void *context, bool previous) |
Compute an array of values at mesh cells by interpolating the variable field associated to the given context located at mesh vertices The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
void | cs_cdovb_vecteq_current_to_previous (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Operate a current to previous operation for the field associated to this equation and potentially for related fields/arrays. More... | |
void | cs_cdovb_vecteq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Predefined extra-operations related to this equation. More... | |
void cs_cdovb_vecteq_current_to_previous | ( | const cs_equation_param_t * | eqp, |
cs_equation_builder_t * | eqb, | ||
void * | context | ||
[in] | eqp | pointer to a cs_equation_param_t structure |
[in,out] | eqb | pointer to a cs_equation_builder_t structure |
[in,out] | context | pointer to cs_cdovb_vecteq_t structure |
void cs_cdovb_vecteq_extra_post | ( | const cs_equation_param_t * | eqp, |
void cs_cdovb_vecteq_finalize_common | ( | void | ) |
void* cs_cdovb_vecteq_free_context | ( | void * | builder | ) |
[in,out] | builder | pointer to a cs_cdovb_vecteq_t structure |
void cs_cdovb_vecteq_get | ( | cs_cell_sys_t ** | csys, |
cs_cell_builder_t ** | cb | ||
[out] | csys | pointer to a pointer on a cs_cell_sys_t structure |
[out] | cb | pointer to a pointer on a cs_cell_builder_t structure |
cs_real_t* cs_cdovb_vecteq_get_cell_values | ( | void * | context, |
bool | previous | ||
[in,out] | context | pointer to a data structure cast on-the-fly |
[in] | previous | retrieve the previous state (true/false) |
cs_real_t* cs_cdovb_vecteq_get_vertex_values | ( | void * | context, |
void cs_cdovb_vecteq_init_common | ( | const cs_cdo_quantities_t * | quant, |
const cs_cdo_connect_t * | connect, | ||
const cs_time_step_t * | time_step, | ||
const cs_matrix_structure_t * | ms | ||
[in] | quant | additional mesh quantities struct. |
[in] | connect | pointer to a cs_cdo_connect_t struct. |
[in] | time_step | pointer to a time step structure |
[in] | ms | pointer to a cs_matrix_structure_t structure |
void* cs_cdovb_vecteq_init_context | ( | const cs_equation_param_t * | eqp, |
int | var_id, | ||
int | bflux_id, | ||
cs_equation_builder_t * | eqb | ||
[in] | var_id | id of the variable field |
[in] | bflux_id | id of the boundary flux field |
void cs_cdovb_vecteq_init_values | ( | cs_real_t | t_eval, |
const int | field_id, | ||
const cs_mesh_t * | mesh, | ||
const cs_equation_param_t * | eqp, | ||
[in] | t_eval | time at which one evaluates BCs |
[in] | field_id | id related to the variable field of this equation |
[in] | mesh | pointer to a cs_mesh_t structure |
[in,out] | context | pointer to the scheme context (cast on-the-fly) |
bool cs_cdovb_vecteq_is_initialized | ( | void | ) |
DOXYGEN_SHOULD_SKIP_THIS
void cs_cdovb_vecteq_solve_steady_state | ( | bool | cur2prev, |
[in] | cur2prev | true="current to previous" operation is performed |
[in] | field_id | id of the variable field related to this equation |
void cs_cdovb_vecteq_update_field | ( | const cs_real_t * | solu, |
const cs_real_t * | rhs, | ||
void * | data, | ||
cs_real_t * | field_val | ||
[in] | solu | solution array |
[in] | rhs | rhs associated to this solution array |
[in,out] | data | pointer to cs_cdovb_vecteq_t structure |
[in,out] | field_val | pointer to the current value of the field |
