80 for (
short int e = 0; e < fm->
n_ef; e++)
82 p_f *= 0.5 / pfq.
meas;
101 cs_reco_cw_scalar_pv_at_face_center(
const short int f,
110 assert(cs_eflag_test(cm->
flag,
114 for (
int ie = cm->
f2e_idx[f]; ie < cm->f2e_idx[f+1]; ie++) {
116 p_f += (p_v[v[0]] + p_v[v[1]]) * cm->
tef[ie];
142 if (p_v == NULL || cm == NULL)
148 for (
short int v = 0;
v < cm->
n_vc;
v++)
149 p_c += cm->
wvc[
v] * p_v[
v];
void cs_reco_cw_cgrd_wbs_from_pvc(const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *cgrd)
Compute the mean value of a gradient inside a given primal cell. Use the WBS algo. for approximating the gradient. The computation takes into account a subdivision into tetrahedra of the current cell based on p_{ef,c}.
Definition: cs_reco.c:1299
double * tef
Definition: cs_cdo_local.h:254
void cs_reco_cw_cell_vect_from_face_dofs(const cs_cell_mesh_t *cm, const cs_real_t i_face_vals[], const cs_real_t b_face_vals[], cs_real_t *cell_reco)
Reconstruct the vector-valued quantity inside each cell from the face DoFs (interior and boundary)...
Definition: cs_reco.c:1061
Definition: cs_flag.h:205
void cs_reco_ccen_edge_dof(cs_lnum_t c_id, const cs_adjacency_t *c2e, const cs_cdo_quantities_t *quant, const double *dof, double reco[])
Reconstruct at the cell center a field of edge-based DoFs.
Definition: cs_reco.c:726
void cs_reco_conf_vtx_dofs(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const double *dof, double *p_crec[], double *p_frec[])
Reconstruct at cell centers and face centers a vertex-based field Linear interpolation. If p_crec and/or p_frec are not allocated, this done in this subroutine.
Definition: cs_reco.c:81
double * wvc
Definition: cs_cdo_local.h:222
double * tef
Definition: cs_cdo_local.h:295
void cs_reco_grad_33_cell_from_fb_dofs(cs_lnum_t c_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *u_c, const cs_real_t *u_f, cs_real_t grd_c[])
Reconstruct the mean-value of the tensor gradient field with DoFs arising from a face-based scheme (v...
Definition: cs_reco.c:910
double meas
Definition: cs_cdo_quantities.h:123
Definition: cs_cdo_local.h:202
Definition: cs_flag.h:211
void cs_reco_pv_at_cell_center(cs_lnum_t c_id, const cs_adjacency_t *c2v, const cs_cdo_quantities_t *quant, const double *array, cs_real_t *val_xc)
Reconstruct the value at the cell center from an array of values defined on primal vertices...
Definition: cs_reco.c:437
short int * f2e_ids
Definition: cs_cdo_local.h:252
void cs_reco_grad_cell_from_pv(cs_lnum_t c_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *pdi, cs_real_t val_xc[])
Reconstruct the value at the cell center of the gradient of a field defined on primal vertices...
Definition: cs_reco.c:965
short int n_ef
Definition: cs_cdo_local.h:292
Definition: cs_defs.h:322
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:114
Definition: cs_field_pointer.h:128
void cs_reco_cw_cell_vect_from_flux(const cs_cell_mesh_t *cm, const cs_real_t *fluxes, cs_real_t *cell_reco)
Reconstruct the vector-valued quantity inside each cell from the given flux array. This array is stored in the same order as cm->f_ids Scalar-valued face DoFs are related to the normal flux across primal faces.
Definition: cs_reco.c:1016
cs_real_t cs_reco_cw_scalar_pv_inside_cell(const cs_cell_mesh_t *cm, const cs_real_t pdi[], const cs_real_t length_xcxp, const cs_real_t unitv_xcxp[], cs_real_t wbuf[])
Reconstruct the value of a scalar potential at a point inside a cell The scalar potential has DoFs lo...
Definition: cs_reco.c:1146
cs_eflag_t flag
Definition: cs_cdo_local.h:204
void cs_reco_ccen_edge_dofs(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const double *dof, double *p_ccrec[])
Reconstruct at each cell center a field of edge-based DoFs.
Definition: cs_reco.c:771
void cs_reco_vect_pv_at_cell_centers(const cs_adjacency_t *c2v, const cs_cdo_quantities_t *quant, const double *array, cs_real_t *val_xc)
Reconstruct the value at all cell centers from an array of values defined on primal vertices...
Definition: cs_reco.c:213
void cs_reco_cell_vector_by_face_dofs(cs_lnum_t c_id, const cs_adjacency_t *c2f, const cs_cdo_quantities_t *cdoq, const cs_real_t face_dofs[], bool local_input, cs_real_t *cell_reco)
Reconstruct the vector-valued quantity inside a cell from the face DoFs (interior and boundary)...
Definition: cs_reco.c:328
void cs_reco_grad_cell_from_fb_dofs(cs_lnum_t c_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *p_c, const cs_real_t *p_f, cs_real_t grd_c[])
Reconstruct the mean-value of the gradient field with DoFs arising from a face-based scheme (values a...
Definition: cs_reco.c:859
short int * e2v_ids
Definition: cs_cdo_local.h:298
Definition: cs_cdo_local.h:60
cs_quant_t * face
Definition: cs_cdo_local.h:238
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
void cs_reco_dfbyc_in_cell(const cs_cell_mesh_t *cm, const cs_real_t *array, cs_real_3_t val_c)
Reconstruct a constant vector inside the cell c. array is scanned thanks to the c2e connectivity...
Definition: cs_reco.c:622
cs_quant_t face
Definition: cs_cdo_local.h:280
Definition: cs_cdo_quantities.h:121
Definition: cs_defs.h:316
short int n_vc
Definition: cs_cdo_local.h:219
Definition: cs_flag.h:214
void cs_reco_dfbyc_at_cell_center(cs_lnum_t c_id, const cs_adjacency_t *c2e, const cs_cdo_quantities_t *quant, const double *array, cs_real_3_t val_xc)
Reconstruct a constant vector at the cell center from an array of values defined on dual faces lying ...
Definition: cs_reco.c:581
void cs_reco_cell_vectors_by_ib_face_dofs(const cs_adjacency_t *c2f, const cs_cdo_quantities_t *cdoq, const cs_real_t i_face_vals[], const cs_real_t b_face_vals[], cs_real_t *cell_reco)
Definition: cs_reco.c:264
short int * e2v_ids
Definition: cs_cdo_local.h:243
void cs_reco_vect_pv_from_pc(const cs_adjacency_t *c2v, const cs_cdo_quantities_t *quant, const double *val, cs_real_t *reco_val)
Reconstruct a vector-valued array at vertices from a vector-valued array at cells.
Definition: cs_reco.c:479
void cs_reco_pf_from_pv(cs_lnum_t f_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const double *pdi, cs_real_t *pdi_f)
Reconstruct the value at the face center from an array of values defined on primal vertices...
Definition: cs_reco.c:530
void cs_reco_cw_vgrd_wbs_from_pvc(const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *vgrd)
Compute the weighted (by volume) gradient inside a given primal cell for the related vertices...
Definition: cs_reco.c:1202
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:270
void cs_reco_cell_curl_by_edge_dofs(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *circ, cs_real_t **p_curl)
Reconstruct a cell-wise constant curl from the knowledge of the circulation at primal edges...
Definition: cs_reco.c:815
void cs_reco_cw_cell_grad_from_scalar_pv(const cs_cell_mesh_t *cm, const cs_real_t pdi[], cs_real_t *cell_gradient)
Definition: cs_reco.c:1105
Definition: cs_flag.h:190
short int * f2e_idx
Definition: cs_cdo_local.h:251
void cs_reco_pv_at_cell_centers(const cs_adjacency_t *c2v, const cs_cdo_quantities_t *quant, const double *array, cs_real_t *val_xc)
Definition: cs_reco.c:167
void cs_reco_dfbyc_in_pec(const cs_cell_mesh_t *cm, short int e, const cs_real_t *array, cs_real_3_t val_pec)
Reconstruct a constant vector inside pec which is a volume surrounding the edge e inside the cell c...
Definition: cs_reco.c:668
Definition: cs_flag.h:217
void cs_reco_cell_vectors_by_face_dofs(const cs_adjacency_t *c2f, const cs_cdo_quantities_t *cdoq, const cs_real_t face_dofs[], cs_real_t *cell_reco)
Definition: cs_reco.c:391
