cs_interface_set_t * | cs_cdo_connect_define_face_interface (const cs_mesh_t *mesh) |
| Create and define a new cs_interface_set_t structure on faces. More...
cs_cdo_connect_t * | cs_cdo_connect_init (cs_mesh_t *mesh, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t hho_scheme_flag) |
| Allocate and define a new cs_cdo_connect_t structure Range sets and interface sets are allocated and defined according to the value of the different scheme flags. cs_range_set_t structure related to vertices is shared the cs_mesh_t structure (the global one) More...
cs_cdo_connect_t * | cs_cdo_connect_free (cs_cdo_connect_t *connect) |
| Destroy a cs_cdo_connect_t structure. More...
void | cs_cdo_connect_discrete_curl (const cs_cdo_connect_t *connect, const cs_real_t *edge_values, cs_real_t **p_curl_values) |
| Compute the discrete curl operator across each primal faces. From an edge-based array (seen as circulations) compute a face-based array (seen as fluxes) More...
void | cs_cdo_connect_summary (const cs_cdo_connect_t *connect, cs_flag_t eb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag) |
| Summary of connectivity information. More...
void | cs_cdo_connect_dump (const cs_cdo_connect_t *connect) |
| Dump a cs_cdo_connect_t structure. More...
◆ CS_CDO_CONNECT_EDGE_SCAL
#define CS_CDO_CONNECT_EDGE_SCAL 7 /* Eb scalar-valued DoF */ |
◆ CS_CDO_CONNECT_FACE_SP0
#define CS_CDO_CONNECT_FACE_SP0 2 /* Fb or HHO-P0 scalar-valued DoF */ |
◆ CS_CDO_CONNECT_FACE_SP1
#define CS_CDO_CONNECT_FACE_SP1 3 /* HHO-P1 scalar-valued */ |
◆ CS_CDO_CONNECT_FACE_SP2
#define CS_CDO_CONNECT_FACE_SP2 4 /* HHO-P2 scalar-valued DoF */ |
◆ CS_CDO_CONNECT_FACE_VHP0
#define CS_CDO_CONNECT_FACE_VHP0 3 /* HHO-P0 vector-valued DoF */ |
◆ CS_CDO_CONNECT_FACE_VHP1
#define CS_CDO_CONNECT_FACE_VHP1 5 /* HHO-P1 vector-valued DoF */ |
◆ CS_CDO_CONNECT_FACE_VHP2
#define CS_CDO_CONNECT_FACE_VHP2 6 /* HHO-P2 vector-valued DoF */ |
◆ CS_CDO_CONNECT_FACE_VP0
#define CS_CDO_CONNECT_FACE_VP0 3 /* Fb vector-valued DoF */ |
◆ CS_CDO_CONNECT_N_CASES
#define CS_CDO_CONNECT_N_CASES 8 |
◆ CS_CDO_CONNECT_VTX_SCAL
#define CS_CDO_CONNECT_VTX_SCAL 0 /* Vb or VCb scalar-valued DoF */ |
◆ CS_CDO_CONNECT_VTX_VECT
#define CS_CDO_CONNECT_VTX_VECT 1 /* Vb or VCb vector-valued DoF */ |
◆ CS_TRIANGLE_CASE
#define CS_TRIANGLE_CASE 3 /* Number of vertices in a triangle */ |
◆ cs_cdo_connect_define_face_interface()
- Parameters
- Returns
- a pointer to a new allocated cs_interface_set_t structure
DOXYGEN_SHOULD_SKIP_THIS
- Parameters
- Returns
◆ cs_cdo_connect_discrete_curl()
- Parameters
[in] | connect | pointer to a cs_cdo_connect_t struct. |
[in] | edge_values | array of values at edges |
[in,out] | curl_values | array storing the curl across faces (allocated if necessary) |
◆ cs_cdo_connect_dump()
◆ cs_cdo_connect_free()
◆ cs_cdo_connect_init()
- Parameters
[in,out] | mesh | pointer to a cs_mesh_t structure |
[in] | eb_scheme_flag | metadata for Edge-based schemes |
[in] | fb_scheme_flag | metadata for Face-based schemes |
[in] | vb_scheme_flag | metadata for Vertex-based schemes |
[in] | vcb_scheme_flag | metadata for Vertex+Cell-based schemes |
[in] | hho_scheme_flag | metadata for HHO schemes |
- Returns
- a pointer to a cs_cdo_connect_t structure
◆ cs_cdo_connect_summary()
- Parameters
[in] | connect | pointer to cs_cdo_connect_t structure |
