1 #ifndef __CS_CDO_BC_H__ 2 #define __CS_CDO_BC_H__ 46 #define CS_CDO_BC_DEFAULT_DEF -1 60 #define CS_CDO_BC_NEUMANN (1 << 0) 62 #define CS_CDO_BC_HMG_NEUMANN (1 << 1) 64 #define CS_CDO_BC_DIRICHLET (1 << 2) 66 #define CS_CDO_BC_HMG_DIRICHLET (1 << 3) 68 #define CS_CDO_BC_ROBIN (1 << 4) 70 #define CS_CDO_BC_SLIDING (1 << 5) 72 #define CS_CDO_BC_TANGENTIAL_DIRICHLET (1 << 6) 155 " %s: Empty desciption buffer.", __func__);
160 sprintf(desc,
"%s",
"Homogenous Dirichlet");
163 sprintf(desc,
"%s",
"Dirichlet");
166 sprintf(desc,
"%s",
"Homogeneous Neumann");
169 sprintf(desc,
"%s",
"Neumann");
172 sprintf(desc,
"%s",
"Robin");
175 sprintf(desc,
"%s",
"Sliding");
178 sprintf(desc,
"%s",
"Dirichlet on the tangential component");
183 "%s: Invalid case. Please contact the support.\n", __func__);
Definition: cs_cdo_bc.h:66
Definition: cs_param_types.h:447
cs_lnum_t n_hmg_neu_faces
Definition: cs_cdo_bc.h:113
Definition: cs_param_types.h:442
Definition: cs_param_types.h:445
cs_lnum_t * circulation_ids
Definition: cs_cdo_bc.h:128
Definition: cs_param_types.h:443
cs_lnum_t * hmg_neu_ids
Definition: cs_cdo_bc.h:114
Definition: cs_param_types.h:446
cs_lnum_t * nhmg_dir_ids
Definition: cs_cdo_bc.h:110
cs_lnum_t n_nhmg_neu_faces
Definition: cs_cdo_bc.h:115
Definition: bft_error.c:193
cs_cdo_bc_face_t * cs_cdo_bc_free(cs_cdo_bc_face_t *face_bc)
Free a cs_cdo_bc_face_t structure.
Definition: cs_cdo_bc.c:334
cs_lnum_t n_robin_faces
Definition: cs_cdo_bc.h:119
Definition: cs_cdo_bc.h:68
Definition: cs_cdo_bc.h:64
cs_flag_t * flag
Definition: cs_cdo_bc.h:95
cs_lnum_t n_sliding_faces
Definition: cs_cdo_bc.h:123
cs_lnum_t n_b_faces
Definition: cs_cdo_bc.h:92
Definition: cs_cdo_bc.h:88
Definition: cs_cdo_bc.h:60
Definition: cs_cdo_bc.h:62
short int * def_ids
Definition: cs_cdo_bc.h:99
bool is_steady
Definition: cs_cdo_bc.h:90
cs_lnum_t n_circulation_faces
Definition: cs_cdo_bc.h:127
Definition: cs_xdef.h:154
cs_lnum_t n_hmg_dir_faces
Definition: cs_cdo_bc.h:107
cs_lnum_t * hmg_dir_ids
Definition: cs_cdo_bc.h:108
Definition: cs_param_types.h:448
Definition: cs_defs.h:316
Definition: cs_cdo_bc.h:72
unsigned short int cs_flag_t
Definition: cs_defs.h:324
cs_param_bc_type_t
Definition: cs_param_types.h:439
cs_lnum_t * robin_ids
Definition: cs_cdo_bc.h:120
cs_lnum_t * sliding_ids
Definition: cs_cdo_bc.h:124
cs_lnum_t * nhmg_neu_ids
Definition: cs_cdo_bc.h:116
cs_cdo_bc_face_t * cs_cdo_bc_face_define(cs_param_bc_type_t default_bc, bool is_steady, int dim, int n_defs, cs_xdef_t **defs, cs_lnum_t n_b_faces)
Define the structure which translates the BC definitions from the user viewpoint into a ready-to-use ...
Definition: cs_cdo_bc.c:146
Definition: cs_param_types.h:441
Definition: cs_param_types.h:444
cs_lnum_t n_nhmg_dir_faces
Definition: cs_cdo_bc.h:109
Definition: cs_cdo_bc.h:70
