Functions dedicated to to the linear algebra settings and operations in case of CDO face-based schemes with a monolithic velocity-pressure coupling. More...
#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <float.h>#include <assert.h>#include <string.h>#include <bft_mem.h>#include "cs_blas.h"#include "cs_cdo_blas.h"#include "cs_equation.h"#include "cs_fp_exception.h"#include "cs_iter_algo.h"#include "cs_matrix_default.h"#include "cs_navsto_coupling.h"#include "cs_navsto_sles.h"#include "cs_parall.h"#include "cs_saddle_itsol.h"#include "cs_sles.h"#include "cs_timer.h"#include "cs_cdofb_monolithic_sles.h"
Include dependency graph for cs_cdofb_monolithic_sles.c:Functions | |
| cs_cdofb_monolithic_sles_t * | cs_cdofb_monolithic_sles_create (void) |
| Create an empty cs_cdofb_monolithic_sles_t structure. More... | |
| void | cs_cdofb_monolithic_sles_init (cs_lnum_t n_cells, cs_lnum_t n_faces, cs_cdofb_monolithic_sles_t *msles) |
| Allocate and initialize the rhs. More... | |
| void | cs_cdofb_monolithic_sles_reset (cs_cdofb_monolithic_sles_t *msles) |
| Reset to zero rhs and clean the cs_sles_t structure. More... | |
| void | cs_cdofb_monolithic_sles_clean (cs_cdofb_monolithic_sles_t *msles) |
| Free a part of the structure. More... | |
| void | cs_cdofb_monolithic_sles_free (cs_cdofb_monolithic_sles_t **p_msles) |
| Free memory related to cs_cdofb_monolithic_sles_t structure. More... | |
| void | cs_cdofb_monolithic_sles_set_shared (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_range_set_t *rset) |
| Set pointers to shared structures. More... | |
| void | cs_cdofb_monolithic_set_sles (cs_navsto_param_t *nsp, void *context) |
| Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to couple the system. No mesh information is available at this stage. nsp is not declared as cnost to avoid compilation warnings but it should be modified at this stage. More... | |
| int | cs_cdofb_monolithic_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles) |
| Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-based approach. The full system is treated as one block and solved as it is. In this situation, PETSc or MUMPS are usually considered. More... | |
| int | cs_cdofb_monolithic_krylov_block_precond (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles) |
| Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-based approach. The system is split into blocks to enable more efficient preconditioning techniques. The main iterative solver is a Krylov solver such as GCR, GMRES or MINRES. More... | |
| int | cs_cdofb_monolithic_gkb_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles) |
| Use the GKB algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes and Navier-Stokes with a monolithic coupling. More... | |
| int | cs_cdofb_monolithic_uzawa_cg_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles) |
| Use the preconditioned Uzawa-CG algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes, Oseen and Navier-Stokes with a monolithic coupling This algorithm is based on Koko's paper "Uzawa conjugate gradient method for the Stokes problem: Matlab implementation with P1-iso-P2/ P1 finite element". More... | |
| int | cs_cdofb_monolithic_uzawa_n3s_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles) |
| Use the preconditioned Uzawa-CG algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes, Oseen and Navier-Stokes with a monolithic coupling This algorithm is based on the EDF report H-E40-1991-03299-FR devoted the numerical algorithms used in the code N3S. Specifically a Cahout-Chabard preconditioning is used to approximate the Schur complement. More... | |
| int | cs_cdofb_monolithic_uzawa_al_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles) |
| Use the Uzawa algorithm with an Augmented Lagrangian technique to solve the saddle-point problem arising from CDO-Fb schemes for Stokes, Oseen and Navier-Stokes with a monolithic coupling. More... | |
| int | cs_cdofb_monolithic_uzawa_al_incr_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles) |
| Use the Uzawa algorithm with an Augmented Lagrangian technique in an incremental way to solve the saddle-point problem arising from CDO-Fb schemes for Stokes, Oseen and Navier-Stokes with a monolithic coupling. More... | |
| int cs_cdofb_monolithic_gkb_solve | ( | const cs_navsto_param_t * | nsp, |
| cs_cdofb_monolithic_sles_t * | msles | ||
| [in,out] | msles | pointer to a cs_cdofb_monolithic_sles_t structure |
| int cs_cdofb_monolithic_krylov_block_precond | ( | const cs_navsto_param_t * | nsp, |
| void cs_cdofb_monolithic_set_sles | ( | cs_navsto_param_t * | nsp, |
| void * | context | ||
| void cs_cdofb_monolithic_sles_clean | ( | cs_cdofb_monolithic_sles_t * | msles | ) |
| [in,out] | msles | pointer to the structure to clean |
| cs_cdofb_monolithic_sles_t* cs_cdofb_monolithic_sles_create | ( | void | ) |
| void cs_cdofb_monolithic_sles_free | ( | cs_cdofb_monolithic_sles_t ** | p_msles | ) |
| [in,out] | p_msles | double pointer to the structure to free |
| void cs_cdofb_monolithic_sles_init | ( | cs_lnum_t | n_cells, |
| cs_lnum_t | n_faces, | ||
| [in] | n_cells | local number of cells |
| [in] | n_faces | local number of faces |
| [in,out] | msles | pointer to the structure to reset |
| void cs_cdofb_monolithic_sles_reset | ( | cs_cdofb_monolithic_sles_t * | msles | ) |
| void cs_cdofb_monolithic_sles_set_shared | ( | const cs_cdo_connect_t * | connect, |
| const cs_range_set_t * | rset | ||
| [in] | connect | pointer to cdo connectivities |
| [in] | quant | pointer to additional mesh quantities |
| [in] | rset | pointer to a cs_range_set_t structure |
| int cs_cdofb_monolithic_solve | ( | const cs_navsto_param_t * | nsp, |
| int cs_cdofb_monolithic_uzawa_al_incr_solve | ( | const cs_navsto_param_t * | nsp, |
| int cs_cdofb_monolithic_uzawa_al_solve | ( | const cs_navsto_param_t * | nsp, |
| int cs_cdofb_monolithic_uzawa_cg_solve | ( | const cs_navsto_param_t * | nsp, |
| int cs_cdofb_monolithic_uzawa_n3s_solve | ( | const cs_navsto_param_t * | nsp, |
