1 #ifndef __CS_CDO_BLAS_H__ 2 #define __CS_CDO_BLAS_H__
cs_real_t() cs_cdo_blas_square_norm_diff_t(const cs_real_t *a, const cs_real_t *b)
Generic function pointer for computing a square norm of the difference between two arrays (defined at...
Definition: cs_cdo_blas.h:96
cs_real_t cs_cdo_blas_square_norm_face(const cs_real_t *array)
Compute the square norm of an array using an Euclidean 2-norm. Case of a scalar-valued array defined ...
Definition: cs_cdo_blas.c:653
cs_real_t() cs_cdo_blas_dotprod_t(const cs_real_t *a, const cs_real_t *b)
Generic function pointer for computing a dot product. Parallel synchronization is performed...
Definition: cs_cdo_blas.h:64
cs_real_t cs_cdo_blas_square_norm_pfsf_diff(const cs_real_t *a, const cs_real_t *b)
Compute the norm ||b - a||**2 Case of a scalar-valued array defined as a flux at primal faces...
Definition: cs_cdo_blas.c:917
Definition: cs_defs.h:322
cs_real_t() cs_cdo_blas_square_norm_t(const cs_real_t *array)
Generic function pointer for computing a square norm. Parallel synchronization is performed...
Definition: cs_cdo_blas.h:79
double precision, save a
cs_real_t cs_cdo_blas_square_norm_pvsp(const cs_real_t *array)
Compute the square norm of an array Case of a scalar-valued array defined as a potential at primal ve...
Definition: cs_cdo_blas.c:608
cs_real_t cs_cdo_blas_square_norm_pfvp(const cs_real_t *array)
Compute the square norm of an array Case of a vector-valued array defined as a potential at primal fa...
Definition: cs_cdo_blas.c:703
cs_real_t cs_cdo_blas_square_norm_pcsp_diff(const cs_real_t *a, const cs_real_t *b)
Compute the norm ||b - a||**2 Case of two scalar-valued arrays a and b defined as a potential at prim...
Definition: cs_cdo_blas.c:429
void cs_cdo_blas_set_shared_pointers(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition: cs_cdo_blas.c:325
cs_real_t cs_cdo_blas_dotprod_face(const cs_real_t *a, const cs_real_t *b)
Compute the dot product of two arrays using the classical Euclidean dot product (without weight)...
Definition: cs_cdo_blas.c:634
cs_real_t cs_cdo_blas_square_norm_pfsp(const cs_real_t *array)
Compute the square norm of an array Case of a scalar-valued array defined as a potential at primal fa...
Definition: cs_cdo_blas.c:677
cs_real_t cs_cdo_blas_dotprod_pfsf(const cs_real_t *a, const cs_real_t *b)
Compute the dot product of two arrays using a weighted Euclidean dot product relying on CDO quantitie...
Definition: cs_cdo_blas.c:731
cs_real_t cs_cdo_blas_square_norm_pcsp_ndiff(const cs_real_t *a, const cs_real_t *ref)
Compute the norm ||a - ref||**2 / || ref||**2 Case of two scalar-valued arrays a and ref defined as a...
Definition: cs_cdo_blas.c:514
cs_real_t cs_cdo_blas_square_norm_pcsp(const cs_real_t *array)
Compute the square norm of an array Case of a scalar-valued array defined as a potential at primal ce...
Definition: cs_cdo_blas.c:347
cs_real_t cs_cdo_blas_square_norm_pfsf(const cs_real_t *array)
Compute the square norm of an array Case of a scalar-valued array defined as a flux at primal faces...
Definition: cs_cdo_blas.c:824
double precision, save b
