7.1
cs_cdofb_monolithic_sles.h
1 #ifndef __CS_CDOFB_MONOLITHIC_SLES_H__
2 #define __CS_CDOFB_MONOLITHIC_SLES_H__
5  * Functions dedicated to the linear algebra settings and operations in case
6  * of CDO face-based schemes with a monolithic velocity-pressure coupling
8
9 /*
10  This file is part of Code_Saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2021 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Standard C library headers
35  *----------------------------------------------------------------------------*/
36
37 /*----------------------------------------------------------------------------
38  * Local headers
39  *----------------------------------------------------------------------------*/
41 #include "cs_navsto_param.h"
46
48  * Macro definitions
50
52  * Type definitions
54
55 /* Context related to the resolution of a saddle point problem */
56 typedef struct {
57
58  /* Block matrices: The gradient operator is the -transpose of div_op */
59
60  /*
61  * If n_row_blocks = 1 and div_op == NULL then all the velocity-pressure
62  * components are gathered in one block. In this case, the full matrix is a
63  * 1x1 matrix
64  *
65  * If n_row_blocks = 1 and div_op != NULL then all the velocity components
66  * are gathered in one block. In this case, the full matrix is a 2x2 matrix
67
68  * If n_row_blocks = 3 and div_op == NULL then there is one block dedicated
69  * to each velocity component. In this case, the full matrix is a 4x4 matrix
70  *
71  * Please notice that div_op if not NULL is stored in a non-assembled way.
72  */
73
75
76  /* Blocks related to the velocity momentum */
78
79  /* B*.approx(A^-1).B^t which corresponds to a compatible discretization of
80  the discrete Laplacian on the pressure space */
82
83  cs_real_t *div_op; /* Block related to the -divergence (block
84  A_{10}) */
85
86  /* Arrays split according to the block shape. U is interlaced or not
87  * according to the SLES strategy */
88
89  cs_lnum_t n_faces; /* local number of DoFs for each component
90  * of the velocity */
91  cs_lnum_t n_cells; /* local number of DoFs for the pressure */
92
93  cs_real_t *u_f; /* velocity values at faces */
94  cs_real_t *p_c; /* pressure values at cells */
95
96  cs_real_t *b_f; /* RHS for the momentum (size = 3*n_faces) */
97  cs_real_t *b_c; /* RHS for the mass equation (size =
98  n_cells) */
99
100  cs_sles_t *sles; /* main SLES structure */
101  cs_sles_t *schur_sles; /* auxiliary SLES for the Schur complement
102  * May be NULL */
103
104  cs_real_t graddiv_coef; /* value of the grad-div coefficient in case
105  * of augmented system */
106
108
109 /*============================================================================
110  * Public function prototypes
111  *============================================================================*/
112
113 /*----------------------------------------------------------------------------*/
119 /*----------------------------------------------------------------------------*/
120
123
124 /*----------------------------------------------------------------------------*/
132 /*----------------------------------------------------------------------------*/
133
134 void
136  cs_lnum_t n_faces,
138
139 /*----------------------------------------------------------------------------*/
145 /*----------------------------------------------------------------------------*/
146
147 void
149
150 /*----------------------------------------------------------------------------*/
156 /*----------------------------------------------------------------------------*/
157
158 void
160
161 /*----------------------------------------------------------------------------*/
167 /*----------------------------------------------------------------------------*/
168
169 void
171
172 /*----------------------------------------------------------------------------*/
180 /*----------------------------------------------------------------------------*/
181
182 void
184  const cs_cdo_quantities_t *quant,
185  const cs_range_set_t *rset);
186
187 /*----------------------------------------------------------------------------*/
198 /*----------------------------------------------------------------------------*/
199
200 void
202  void *context);
203
204 /*----------------------------------------------------------------------------*/
217 /*----------------------------------------------------------------------------*/
218
219 int
221  const cs_equation_param_t *eqp,
223
224 /*----------------------------------------------------------------------------*/
238 /*----------------------------------------------------------------------------*/
239
240 int
242  const cs_equation_param_t *eqp,
244
245 /*----------------------------------------------------------------------------*/
258 /*----------------------------------------------------------------------------*/
259
260 int
262  const cs_equation_param_t *eqp,
264
265 /*----------------------------------------------------------------------------*/
277 /*----------------------------------------------------------------------------*/
278
279 int
281  const cs_equation_param_t *eqp,
283
284 /*----------------------------------------------------------------------------*/
299 /*----------------------------------------------------------------------------*/
300
301 int
303  const cs_equation_param_t *eqp,
305
306 /*----------------------------------------------------------------------------*/
322 /*----------------------------------------------------------------------------*/
323
324 int
326  const cs_equation_param_t *eqp,
328
329 /*----------------------------------------------------------------------------*/
341 /*----------------------------------------------------------------------------*/
342
343 int
345  const cs_equation_param_t *eqp,
347
348 /*----------------------------------------------------------------------------*/
361 /*----------------------------------------------------------------------------*/
362
363 int
365  const cs_equation_param_t *eqp,
367
368 /*----------------------------------------------------------------------------*/
369
371
372 #endif /* __CS_CDOFB_MONOLITHIC_SLES_H__ */
int cs_cdofb_monolithic_uzawa_cg_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Use the preconditioned Uzawa-CG algorithm to solve the saddle-point problem arising from CDO-Fb schem...
Definition: cs_cdofb_monolithic_sles.c:4766
void cs_cdofb_monolithic_sles_set_shared(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_range_set_t *rset)
Set pointers to shared structures.
Definition: cs_cdofb_monolithic_sles.c:3955
Definition: cs_equation_param.h:177
int cs_cdofb_monolithic_uzawa_al_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Use the Uzawa algorithm with an Augmented Lagrangian technique to solve the saddle-point problem aris...
Definition: cs_cdofb_monolithic_sles.c:5381
cs_real_t * b_c
Definition: cs_cdofb_monolithic_sles.h:97
cs_real_t * div_op
Definition: cs_cdofb_monolithic_sles.h:83
int cs_cdofb_monolithic_gkb_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Use the GKB algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes and Na...
Definition: cs_cdofb_monolithic_sles.c:4613
int cs_cdofb_monolithic_by_blocks_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-b...
void cs_cdofb_monolithic_sles_reset(cs_cdofb_monolithic_sles_t *msles)
Reset to zero rhs and clean the cs_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:3871
Definition: cs_cdofb_monolithic_sles.h:104
Definition: cs_navsto_param.h:605
Definition: cs_defs.h:322
Definition: cs_matrix.h:93
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
void cs_cdofb_monolithic_sles_init(cs_lnum_t n_cells, cs_lnum_t n_faces, cs_cdofb_monolithic_sles_t *msles)
Allocate and initialize the rhs.
Definition: cs_cdofb_monolithic_sles.c:3838
cs_real_t * u_f
Definition: cs_cdofb_monolithic_sles.h:93
cs_sles_t * sles
Definition: cs_cdofb_monolithic_sles.h:100
Definition: cs_cdofb_monolithic_sles.h:56
cs_real_t * b_f
Definition: cs_cdofb_monolithic_sles.h:96
Definition: cs_range_set.h:57
int cs_cdofb_monolithic_uzawa_n3s_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Definition: cs_cdofb_monolithic_sles.c:5052
cs_matrix_t ** block_matrices
Definition: cs_cdofb_monolithic_sles.h:77
int cs_cdofb_monolithic_krylov_block_precond(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Definition: cs_cdofb_monolithic_sles.c:4432
void cs_cdofb_monolithic_set_sles(cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to couple the system...
Definition: cs_cdofb_monolithic_sles.c:3981
cs_real_t * p_c
Definition: cs_cdofb_monolithic_sles.h:94
cs_sles_t * schur_sles
Definition: cs_cdofb_monolithic_sles.h:101
cs_cdofb_monolithic_sles_t * cs_cdofb_monolithic_sles_create(void)
Create an empty cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:3801
Definition: cs_defs.h:316
void cs_cdofb_monolithic_sles_clean(cs_cdofb_monolithic_sles_t *msles)
Free a part of the structure.
Definition: cs_cdofb_monolithic_sles.c:3905
int n_row_blocks
Definition: cs_cdofb_monolithic_sles.h:74
int cs_cdofb_monolithic_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Definition: cs_cdofb_monolithic_sles.c:4229
cs_lnum_t n_cells
Definition: cs_cdofb_monolithic_sles.h:91
cs_lnum_t n_faces
Definition: cs_cdofb_monolithic_sles.h:89
cs_matrix_t * compatible_laplacian
Definition: cs_cdofb_monolithic_sles.h:81
int cs_cdofb_monolithic_uzawa_al_incr_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Use the Uzawa algorithm with an Augmented Lagrangian technique in an incremental way to solve the sad...
Definition: cs_cdofb_monolithic_sles.c:5529
void cs_cdofb_monolithic_sles_free(cs_cdofb_monolithic_sles_t **p_msles)
Free memory related to cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:3929
