1 #ifndef __CS_EQUATION_H__ 2 #define __CS_EQUATION_H__ 113 const char *fld_name);
481 int *n_predef_equations,
482 int *n_user_equations);
741 const int reaction_id);
void cs_equation_post_balance(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *ts)
Predefined extra-operations related to all equations.
Definition: cs_equation.c:3515
time step descriptor
Definition: cs_time_step.h:64
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
cs_property_t * cs_equation_get_time_property(const cs_equation_t *eq)
Return a pointer to the cs_property_t structure associated to the unsteady term for this equation (NU...
Definition: cs_equation.c:906
Definition: cs_advection_field.h:149
void cs_equation_read_extra_restart(cs_restart_t *restart)
Write into the restart file additionnal arrays (not defined as fields) but useful for the checkpoint/...
Definition: cs_equation.c:3467
void cs_equation_set_flag(cs_equation_t *eq, cs_flag_t flag)
Redefine the flag associated to an equation.
Definition: cs_equation.c:779
Definition: cs_field.h:125
Definition: cs_equation_param.h:177
bool cs_equation_set_functions(void)
Assign a set of pointer functions for managing the cs_equation_t structure during the computation Aft...
Definition: cs_equation.c:1995
void cs_equation_compute_flux_across_plane(const cs_equation_t *eq, const char *ml_name, const cs_real_3_t direction, cs_real_t *diff_flux, cs_real_t *conv_flux)
Compute the diffusive and convective flux across a plane defined by a mesh location structure attache...
Definition: cs_equation.c:3223
cs_equation_builder_t * cs_equation_get_builder(const cs_equation_t *eq)
Return the cs_equation_builder_t structure associated to a cs_equation_t structure. Only for an advanced usage.
Definition: cs_equation.c:844
cs_real_t * cs_equation_get_edge_values(const cs_equation_t *eq, bool previous)
For a given equation, retrieve an array of values related to each edge of the mesh for the unknowns...
Definition: cs_equation.c:2976
void cs_equation_set_sles(void)
Setup the linear algebra requirements.
Definition: cs_equation.c:1575
void cs_equation_compute_boundary_diff_flux(cs_real_t t_eval, const cs_equation_t *eq, cs_real_t *diff_flux)
Compute the diffusive flux across all boundary faces According to the space discretization scheme...
Definition: cs_equation.c:3138
bool cs_equation_uses_new_mechanism(const cs_equation_t *eq)
Return true is the given equation is steady otherwise false.
Definition: cs_equation.c:1136
void cs_equation_current_to_previous(const cs_equation_t *eq)
Apply the current to previous to all fields (and potentially arrays) related to an equation...
Definition: cs_equation.c:2868
void cs_equation_get_cellwise_builders(const cs_equation_t *eq, cs_cell_sys_t **csys, cs_cell_builder_t **cb)
For a given equation, retrieve the related cellwise builder structures: cs_cell_builder_t and cs_cell...
Definition: cs_equation.c:2897
void cs_equation_set_default_param(cs_equation_key_t key, const char *keyval)
Set a parameter attached to a keyname for the default settigns.
Definition: cs_equation.c:1545
void cs_equation_compute_diff_flux_cellwise(const cs_equation_t *eq, cs_flag_t location, cs_real_t t_eval, cs_real_t *diff_flux)
Cellwise computation of the diffusive flux across all cell faces. Primal or dual faces are considered...
Definition: cs_equation.c:3296
void cs_equation_build_system(const cs_mesh_t *mesh, cs_equation_t *eq)
Build the linear system for this equation.
Definition: cs_equation.c:2568
Definition: cs_defs.h:322
void cs_equation_integrate_variable(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, cs_real_t *result)
Compute the integral over the domain of the variable field associated to the given equation...
Definition: cs_equation.c:3028
Definition: cs_cdo_local.h:146
cs_property_t * cs_equation_get_reaction_property(const cs_equation_t *eq, const int reaction_id)
Return a pointer to the cs_property_t structure associated to the reaction term with id equal to reac...
Definition: cs_equation.c:931
cs_equation_param_t * cs_equation_param_by_field_name(const char *field_name)
Return the cs_equation_param_t structure related to a cs_equation_t structure thanks to the field nam...
Definition: cs_equation.c:497
cs_real_t * cs_equation_get_vertex_values(const cs_equation_t *eq, bool previous)
For a given equation, retrieve an array of values related to each vertex of the mesh for the unknowns...
Definition: cs_equation.c:3002
cs_equation_t * cs_equation_by_id(int eq_id)
Find the cs_equation_t structure with id eq_id Return NULL if not find.
Definition: cs_equation.c:542
void cs_equation_log_setup(void)
Summarize all cs_equation_t structures.
Definition: cs_equation.c:1508
cs_param_space_scheme_t
Definition: cs_param_types.h:180
cs_equation_param_t * cs_equation_get_param(const cs_equation_t *eq)
Return the cs_equation_param_t structure associated to a cs_equation_t structure. ...
Definition: cs_equation.c:522
cs_equation_t * cs_equation_by_field_name(const char *field_name)
Return the pointer to a cs_equation_t structure thanks to the field name of the variable field associ...
Definition: cs_equation.c:399
cs_param_space_scheme_t cs_equation_get_space_scheme(const cs_equation_t *eq)
Return the type of numerical scheme used for the discretization in space.
Definition: cs_equation.c:1027
void cs_equation_initialize(const cs_mesh_t *mesh, const cs_time_step_t *ts, const cs_cdo_quantities_t *quant, cs_cdo_connect_t *connect)
Allocate and initialize the builder of the algebraic system. Set the initialize condition to all vari...
Definition: cs_equation.c:2509
void cs_equation_unset_shared_structures(cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t hho_scheme_flag)
Release shared structures among the activated class of discretization schemes.
Definition: cs_equation.c:1740
cs_param_time_scheme_t cs_equation_get_time_scheme(const cs_equation_t *eq)
Return the type of numerical scheme used for the discretization in time.
Definition: cs_equation.c:956
cs_real_t * cs_equation_get_face_values(const cs_equation_t *eq, bool previous)
For a given equation, retrieve an array of values related to each face of the mesh for the unknowns...
Definition: cs_equation.c:2950
void * cs_equation_get_scheme_context(const cs_equation_t *eq)
Return a pointer to a structure useful to handle low-level operations for the given equation...
Definition: cs_equation.c:864
Definition: cs_restart.h:93
Definition: cs_range_set.h:57
void cs_equation_extra_post(void)
Predefined extra-operations related to equations according to the type of numerical scheme (for the s...
Definition: cs_equation.c:3636
cs_field_t * cs_equation_get_boundary_flux(const cs_equation_t *eq)
Return the field structure for the (normal) boundary flux associated to a cs_equation_t structure...
Definition: cs_equation.c:736
void cs_equation_compute_vtx_field_gradient(const cs_equation_t *eq, cs_real_t *v_gradient)
Cellwise computation of the discrete gradient at vertices.
Definition: cs_equation.c:3377
cs_property_t * cs_equation_get_diffusion_property(const cs_equation_t *eq)
Return a pointer to the cs_property_t structure associated to the diffusion term for this equation (N...
Definition: cs_equation.c:884
void cs_equation_solve_deprecated(cs_equation_t *eq)
Solve the linear system for this equation.
Definition: cs_equation.c:2609
Definition: cs_cdo_local.h:60
int cs_equation_get_id(const cs_equation_t *eq)
Return the id number related to the given cs_equation_t structure.
Definition: cs_equation.c:582
cs_equation_t * cs_equation_add_user(const char *eqname, const char *varname, int dim, cs_param_bc_type_t default_bc)
Add a new user equation structure and set a first set of parameters.
Definition: cs_equation.c:1315
cs_equation_key_t
List of available keys for setting the parameters of an equation.
Definition: cs_equation_param.h:1086
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
cs_equation_type_t
Type of equations managed by the solver.
Definition: cs_equation_param.h:156
char *restrict varname
Definition: cs_equation_priv.h:330
cs_equation_t * cs_equation_add_user_tracer(const char *eqname, const char *varname, int dim, cs_param_bc_type_t default_bc, cs_property_t *time_pty, cs_adv_field_t *adv, cs_property_t *diff_pty)
Add a new user transport equation and set a first set of parameters If time_pty is NULL...
Definition: cs_equation.c:1363
int cs_equation_get_field_id(const cs_equation_t *eq)
Return the id related to the variable field structure associated to the cs_equation_t structure...
Definition: cs_equation.c:622
void cs_equation_create_fields(void)
Create a field structure related to all cs_equation_t structures.
Definition: cs_equation.c:2404
bool cs_equation_has_field_name(const cs_equation_t *eq, const char *fld_name)
Check if the asociated field to a cs_equation_t structure has name equal to fld_name.
Definition: cs_equation.c:431
cs_equation_type_t cs_equation_get_type(const cs_equation_t *eq)
Return the type of equation for the given equation structure.
Definition: cs_equation.c:1091
void cs_equation_add_user_hook(cs_equation_t *eq, void *context, cs_equation_user_hook_t *func)
Add a user hook to enable an advanced user to get a fine control of the cellwise system building...
Definition: cs_equation.c:803
unsigned short int cs_flag_t
Definition: cs_defs.h:324
void cs_equation_solve(bool cur2prev, const cs_mesh_t *mesh, cs_equation_t *eq)
Build and then solve the linear system for an equation with an unsteady term.
Definition: cs_equation.c:2756
cs_param_bc_type_t
Definition: cs_param_types.h:439
cs_flag_t cs_equation_get_flag(const cs_equation_t *eq)
Return the flag associated to an equation.
Definition: cs_equation.c:757
cs_gnum_t cs_equation_get_global_n_dofs(const cs_equation_t *eq, const cs_cdo_quantities_t *cdoq)
Return the global number of degrees of freedom associated to this cs_equation_t structure.
Definition: cs_equation.c:663
bool cs_equation_needs_steady_state_solve(void)
Check if a steady-state computation is requested according to the setting.
Definition: cs_equation.c:1443
cs_field_t * cs_equation_get_field(const cs_equation_t *eq)
Return the field structure associated to a cs_equation_t structure.
Definition: cs_equation.c:602
const cs_range_set_t * cs_equation_get_range_set(const cs_equation_t *eq)
Return the range set structure associated to a cs_equation_t structure.
Definition: cs_equation.c:642
cs_equation_t * cs_equation_add(const char *eqname, const char *varname, cs_equation_type_t eqtype, int dim, cs_param_bc_type_t default_bc)
Add a new equation structure and set a first set of parameters.
Definition: cs_equation.c:1173
void cs_equation_compute_peclet(const cs_equation_t *eq, const cs_time_step_t *ts, cs_real_t peclet[])
Compute and post-process Peclet number if requested.
Definition: cs_equation.c:3419
void cs_equation_solve_steady_state_wrapper(const char *eqname)
Build and then solve the linear system for a steady-state equation. This is wrapper for the FORTRAN i...
Definition: cs_equation.c:2793
cs_equation_param_t * cs_equation_param_by_name(const char *eqname)
Return the cs_equation_param_t structure associated to a cs_equation_t structure based on the equatio...
Definition: cs_equation.c:463
void cs_equation_set_shared_structures(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t hho_scheme_flag)
Set shared structures among the activated class of discretization schemes.
Definition: cs_equation.c:1615
void() cs_equation_user_hook_t(const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const void *eq_context, const cs_cell_mesh_t *cm, cs_hodge_t *mass_hodge, cs_hodge_t *diff_hodge, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Generic function prototype for a hook during the cellwise building of the linear system Enable an adv...
Definition: cs_equation_common.h:93
int cs_equation_get_var_dim(const cs_equation_t *eq)
Return the dimension of the variable solved by this equation.
Definition: cs_equation.c:1070
void cs_equation_set_range_set(const cs_cdo_connect_t *connect)
Assign a cs_range_set_t structures for synchronization when computing in parallel mode...
Definition: cs_equation.c:1782
void cs_equation_destroy_all(void)
Destroy all cs_equation_t structures.
Definition: cs_equation.c:1396
void cs_equation_get_count(int *n_equations, int *n_predef_equations, int *n_user_equations)
Get the count of equations of each macro type.
Definition: cs_equation.c:1492
void cs_equation_solve_steady_state(const cs_mesh_t *mesh, cs_equation_t *eq)
Build and then solve the linear system for this equation when the goal is to find the steady state...
Definition: cs_equation.c:2719
cs_real_t * cs_equation_get_cell_values(const cs_equation_t *eq, bool previous)
For a given equation, retrieve an array of values related to each cell of the mesh for the unknowns...
Definition: cs_equation.c:2924
Definition: cs_param_types.h:242
const char * cs_equation_get_name(const cs_equation_t *eq)
Return the name related to the given cs_equation_t structure.
Definition: cs_equation.c:562
cs_equation_t * cs_equation_by_name(const char *eqname)
Find the cs_equation_t structure with name eqname Return NULL if not find.
Definition: cs_equation.c:365
int cs_equation_get_space_poly_degree(const cs_equation_t *eq)
Return the max. degree used in the polynomial basis for the space discretization. ...
Definition: cs_equation.c:1049
void cs_equation_write_extra_restart(cs_restart_t *restart)
Definition: cs_equation.c:3490
Definition: cs_equation_priv.h:323
int cs_equation_get_n_equations(void)
Retrieve the number of equations.
Definition: cs_equation.c:348
void cs_equation_solve_wrapper(bool cur2prev, const char *eqname)
Build and then solve the linear system for an equation with an unsteady term. This is wrapper for the...
Definition: cs_equation.c:2831
cs_real_t cs_equation_get_theta_time_val(const cs_equation_t *eq)
Return the value of the theta parameter in theta time scheme discretization.
Definition: cs_equation.c:979
void cs_equation_log_monitoring(void)
Print a synthesis of the monitoring information in the performance file.
Definition: cs_equation.c:1465
bool cs_equation_is_steady(const cs_equation_t *eq)
Definition: cs_equation.c:1112
