7.1
cs_boundary_conditions.c File Reference
#include <stdarg.h>
#include <mpi.h>
#include <ple_locator.h>
#include "cs_boundary.h"
#include "cs_coupling.h"
#include "cs_gradient.h"
#include "cs_gui_util.h"
#include "cs_field_default.h"
#include "cs_field_pointer.h"
#include "cs_flag_check.h"
#include "cs_halo.h"
#include "cs_math.h"
#include "cs_mesh_connect.h"
#include "cs_parameters.h"
#include "cs_prototypes.h"
#include "cs_post.h"
#include "cs_xdef_eval_at_zone.h"
#include "fvm_nodal.h"
#include "cs_boundary_conditions.h"
+ Include dependency graph for cs_boundary_conditions.c:
void cs_boundary_conditions_error (const int *bc_flag, const char *type_name)
 Handling of boundary condition definition errors and associated output. More...
ple_locator_t * cs_boundary_conditions_map (cs_mesh_location_type_t location_type, cs_lnum_t n_location_elts, cs_lnum_t n_faces, const cs_lnum_t *location_elts, const cs_lnum_t *faces, cs_real_3_t *coord_shift, int coord_stride, double tolerance)
 Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later interpolation. More...
void cs_boundary_conditions_mapped_set (const cs_field_t *f, ple_locator_t *locator, cs_mesh_location_type_t location_type, int normalize, int interpolate, cs_lnum_t n_faces, const cs_lnum_t *faces, cs_real_t *balance_w, int nvar, cs_real_t rcodcl[])
 Set mapped boundary conditions for a given field and mapping locator. More...
int cs_boundary_conditions_add_map (int bc_location_id, int source_location_id, cs_real_t coord_shift[3], double tolerance)
 Add location of locate shifted boundary face coordinates on cells or boundary faces for automatic interpolation. More...
void cs_boundary_conditions_create (void)
 Create the legacy boundary conditions face type and face zone arrays. More...
void cs_boundary_conditions_free (void)
 Free the boundary conditions face type and face zone arrays. More...
void cs_boundary_conditions_set_convective_outlet_scalar (cs_real_t *coefa, cs_real_t *cofaf, cs_real_t *coefb, cs_real_t *cofbf, cs_real_t pimp, cs_real_t cfl, cs_real_t hint)
 Set convective oulet boundary condition for a scalar. More...
void cs_boundary_conditions_compute (int nvar, int itypfb[], int icodcl[], double rcodcl[])
 Update per variable boundary condition codes. More...
void cs_boundary_conditions_complete (int nvar, int itypfb[], int icodcl[], double rcodcl[])
 Automatic adjustments for boundary condition codes. More...
Boundary condition handling.
◆ cs_boundary_conditions_add_map()
int cs_boundary_conditions_add_map ( int  bc_location_id,
double  tolerance
Note
This function is currently restricted to mapping of boundary face locations (usually from boundary zones) to cell of boundary face locations, but could be extended to other location types in the future.
[in]bc_location_idid of selected boundary mesh location; currently restricted to subsets of boundary faces (i.e. boundary zone location ids).
[in]source_location_idid of selected location mesh location (usually CS_MESH_LOCATION_CELLS but can be a more restricted cell or boundary face zone location location id).
[in]coord_shiftcoordinates shift relative to selected boundary faces
[in]tolerancerelative tolerance for point location.
id of added map
◆ cs_boundary_conditions_complete()
void cs_boundary_conditions_complete ( int  nvar,
int  itypfb[],
int  icodcl[],
double  rcodcl[]
[in]nvarnumber of variables requiring BC's
[in]itypfbtype of boundary for each face
[in,out]icodclboundary condition codes
[in,out]rcodclboundary condition values
◆ cs_boundary_conditions_compute()
void cs_boundary_conditions_compute ( int  nvar,
int  itypfb[],
int  icodcl[],
double  rcodcl[]
◆ cs_boundary_conditions_create()
void cs_boundary_conditions_create ( void  )
◆ cs_boundary_conditions_error()
void cs_boundary_conditions_error ( const int *  bc_flag,
const char *  type_name
[in]bc_flagarray of BC type ids
[in]type_namename of attribute in error, or NULL
◆ cs_boundary_conditions_free()
void cs_boundary_conditions_free ( void  )
◆ cs_boundary_conditions_map()
ple_locator_t* cs_boundary_conditions_map ( cs_mesh_location_type_t  location_type,
cs_lnum_t  n_faces,
const cs_lnum_t location_elts,
const cs_lnum_t faces,
cs_real_3_t coord_shift,
int  coord_stride,
double  tolerance
[in]location_typematching values location (CS_MESH_LOCATION_CELLS or CS_MESH_LOCATION_BOUNDARY_FACES)
[in]n_location_eltsnumber of selected location elements
[in]n_facesnumber of selected boundary faces
[in]location_eltslist of selected location elements (0 to n-1), or NULL if no indirection is needed
[in]faceslist of selected boundary faces (0 to n-1), or NULL if no indirection is needed
[in]coord_shiftarray of coordinates shift relative to selected boundary faces
[in]coord_strideaccess stride in coord_shift: 0 for uniform shift, 1 for "per face" shift.
associated locator structure
◆ cs_boundary_conditions_mapped_set()
void cs_boundary_conditions_mapped_set ( const cs_field_t f,
ple_locator_t *  locator,
int  normalize,
int  interpolate,
cs_lnum_t  n_faces,
cs_real_t balance_w,
int  nvar,
cs_real_t  rcodcl[]
[in]ffield whose boundary conditions are set
[in]locatorassociated mapping locator, as returned by cs_boundary_conditions_map.
[in]normalizenormalization option: 0: values are simply mapped 1: values are mapped, then multiplied by a constant factor so that their surface integral on selected faces is preserved (relative to the input values) 2: as 1, but with a boundary-defined weight, defined by balance_w 3: as 1, but with a cell-defined weight, defined by balance_w
[in]interpolateinterpolation option: 0: values are simply based on matching cell or face center values 1: values are based on matching cell or face center values, corrected by gradient interpolation
[in]balance_woptional balance weight, or NULL
◆ cs_boundary_conditions_set_convective_outlet_scalar()
void cs_boundary_conditions_set_convective_outlet_scalar ( cs_real_t coefa,
cs_real_t cofaf,
cs_real_t coefb,
cs_real_t cofbf,
cs_real_t  pimp,
cs_real_t  cfl,
cs_real_t  hint
[out]coefaexplicit BC coefficient for gradients
[out]cofafexplicit BC coefficient for diffusive flux
[out]coefbimplicit BC coefficient for gradients
[out]cofbfimplicit BC coefficient for diffusive flux
[in]pimpFlux value to impose
[in]cflLocal Courant number used to convect
[in]hintInternal exchange coefficient
