Routines to handle the cs_navsto_system_t structure. More...
#include "cs_defs.h"#include <assert.h>#include <stdlib.h>#include <string.h>#include <bft_mem.h>#include "cs_cdofb_ac.h"#include "cs_cdofb_monolithic.h"#include "cs_cdofb_monolithic_sles.h"#include "cs_cdofb_navsto.h"#include "cs_cdofb_predco.h"#include "cs_hho_stokes.h"#include "cs_evaluate.h"#include "cs_flag.h"#include "cs_log.h"#include "cs_navsto_coupling.h"#include "cs_post.h"#include "cs_volume_zone.h"#include "cs_navsto_system.h"
Include dependency graph for cs_navsto_system.c:Macros | |
| #define | CS_NAVSTO_SYSTEM_DBG 0 |
| bool | cs_navsto_system_is_activated (void) |
| Check if the resolution of the Navier-Stokes system has been activated. More... | |
| void | cs_navsto_system_update_model (bool with_thermal) |
| Update the flag associated to the modelling options. More... | |
| cs_navsto_system_t * | cs_navsto_system_activate (const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag) |
| Allocate and initialize the Navier-Stokes (NS) system. More... | |
| void | cs_navsto_system_destroy (void) |
| Free the main structure related to the Navier-Stokes system. More... | |
| cs_navsto_param_t * | cs_navsto_system_get_param (void) |
| Retrieve the structure storing the parameters for the Navier–Stokes system. More... | |
| cs_equation_t * | cs_navsto_system_get_momentum_eq (void) |
| Retrieve a pointer to the equation related to the momentum equation. More... | |
| cs_adv_field_t * | cs_navsto_get_adv_field (void) |
| Retrieve the advection field structure (the mass flux) related to the Navier-Stokes system. More... | |
| cs_real_t * | cs_navsto_get_mass_flux (bool previous) |
| Retrieve the mass flux array related to the Navier-Stokes system. More... | |
| void | cs_navsto_system_init_setup (void) |
| Start setting-up the Navier-Stokes system At this stage, numerical settings should be completely determined but connectivity and geometrical information is not yet available. More... | |
| void | cs_navsto_system_set_sles (void) |
| Define the settings for SLES related to the Navier-Stokes system. More... | |
| void | cs_navsto_system_finalize_setup (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Last step of the setup of the Navier-Stokes system. More... | |
| void | cs_navsto_system_initialize (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts) |
| Initialize the scheme context structure used to build the algebraic system. This is done after the setup step. Set an initial value for the velocity and pressure field if needed. More... | |
| void | cs_navsto_system_set_solid_cells (cs_lnum_t n_solid_cells, cs_lnum_t solid_cell_ids[]) |
| Set a solid zone related to the Navier-Stokes equations. More... | |
| void | cs_navsto_system_update (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq) |
| Update variables and related quantities when a new state of the Navier-Stokes system has been computed. More... | |
| void | cs_navsto_system_compute_steady_state (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq) |
| Build, solve and update the Navier-Stokes system in case of a steady-state approach. More... | |
| void | cs_navsto_system_compute (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq) |
| Build, solve and update the Navier-Stokes system. More... | |
| void | cs_navsto_system_extra_op (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *ts) |
| Predefined extra-operations for the Navier-Stokes system. More... | |
| void | cs_navsto_system_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step) |
| Predefined post-processing output for the Navier-Stokes system. The prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More... | |
| void | cs_navsto_system_log_setup (void) |
| Summary of the main cs_navsto_system_t structure. More... | |
| #define CS_NAVSTO_SYSTEM_DBG 0 |
| cs_adv_field_t* cs_navsto_get_adv_field | ( | void | ) |
| cs_real_t* cs_navsto_get_mass_flux | ( | bool | previous | ) |
| [in] | previous | if true return the previous state otherwise the current state. |
| cs_navsto_system_t* cs_navsto_system_activate | ( | const cs_boundary_t * | boundaries, |
| cs_navsto_param_model_t | model, | ||
| cs_navsto_param_model_flag_t | model_flag, | ||
| cs_navsto_param_coupling_t | algo_coupling, | ||
| cs_navsto_param_post_flag_t | post_flag | ||
| [in] | model | type of model related to the NS system |
| [in] | model_flag | additional high-level model options |
| [in] | algo_coupling | algorithm used for solving the NS system |
| [in] | post_flag | predefined post-processings options |
| void cs_navsto_system_compute | ( | const cs_mesh_t * | mesh, |
| [in] | time_step | structure managing the time stepping |
| void cs_navsto_system_compute_steady_state | ( | const cs_mesh_t * | mesh, |
| void cs_navsto_system_destroy | ( | void | ) |
| void cs_navsto_system_extra_op | ( | const cs_mesh_t * | mesh, |
| [in] | ts | pointer to a cs structure |
| void cs_navsto_system_extra_post | ( | void * | input, |
| int | mesh_id, | ||
| int | cat_id, | ||
| int | ent_flag[5], | ||
| cs_lnum_t | n_cells, | ||
| cs_lnum_t | n_i_faces, | ||
| cs_lnum_t | n_b_faces, | ||
| [in,out] | input | pointer to a optional structure (here a cs_navsto_system_t structure) |
| void cs_navsto_system_finalize_setup | ( | const cs_mesh_t * | mesh, |
| cs_equation_t* cs_navsto_system_get_momentum_eq | ( | void | ) |
| cs_navsto_param_t* cs_navsto_system_get_param | ( | void | ) |
| void cs_navsto_system_init_setup | ( | void | ) |
| void cs_navsto_system_initialize | ( | const cs_mesh_t * | mesh, |
| bool cs_navsto_system_is_activated | ( | void | ) |
| void cs_navsto_system_log_setup | ( | void | ) |
| void cs_navsto_system_set_sles | ( | void | ) |
| [in] | n_solid_cells | number of solid cells |
| [in] | solid_cell_ids | list of cell ids (local numbering) |
| void cs_navsto_system_update | ( | const cs_mesh_t * | mesh, |
| void cs_navsto_system_update_model | ( | bool | with_thermal | ) |
| [in] | with_thermal | true or false |
