cs_cdofb_monolithic_sles.h
1 #ifndef __CS_CDOFB_MONOLITHIC_SLES_H__
2 #define __CS_CDOFB_MONOLITHIC_SLES_H__
5  * Functions dedicated to the linear algebra settings and operations in case
6  * of CDO face-based schemes with a monolithic velocity-pressure coupling
8
9 /*
10  This file is part of Code_Saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2021 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Standard C library headers
35  *----------------------------------------------------------------------------*/
36
37 /*----------------------------------------------------------------------------
38  * Local headers
39  *----------------------------------------------------------------------------*/
41 #include "cs_navsto_param.h"
46
48  * Macro definitions
50
52  * Type definitions
54
55 /* Context related to the resolution of a saddle point problem */
56 typedef struct {
57
58  /* Block matrices: The gradient operator is the -transpose of div_op */
59
60  /*
61  * If n_row_blocks = 1 and div_op == NULL then all the velocity-pressure
62  * components are gathered in one block. In this case, the full matrix is a
63  * 1x1 matrix
64  *
65  * If n_row_blocks = 1 and div_op != NULL then all the velocity components are
66  * gathered in one block. In this case, the full matrix is a 2x2 matrix
67
68  * If n_row_blocks = 3 and div_op == NULL then there is one block dedicated to
69  * each velocity component. In this case, the full matrix is a 4x4 matrix
70  *
71  * Please notice that div_op if not NULL is stored in a non-assembled way.
72  */
73
75
76  /* Blocks related to the velocity momentum */
78
79  /* B^t.Diag(A)^-1.B which corresponds to a compatible discretization of the
80  discrete Laplacian on the pressure space */
82
83  cs_real_t *div_op; /* Block related to the -divergence (block A_{10} */
84
85  /* Arrays split according to the block shape. U is interlaced or not
86  * according to the SLES strategy
87  */
88
89  cs_lnum_t n_faces; /* local number of DoFs for each component
90  * of the velocity */
91  cs_lnum_t n_cells; /* local number of DoFs for the pressure */
92
93  cs_real_t *u_f; /* velocity values at faces */
94  cs_real_t *p_c; /* pressure values at cells */
95
96  cs_real_t *b_f; /* RHS for the momentum (size = 3*n_faces) */
97  cs_real_t *b_c; /* RHS for the mass equation (size = n_cells) */
98
99  cs_sles_t *sles; /* main SLES structure */
100  cs_sles_t *schur_sles; /* auxiliary SLES for the Schur complement
101  * May be NULL */
102
103  cs_real_t graddiv_coef; /* value of the grad-div coefficient in case
104  * of augmented system */
105
107
108 /*============================================================================
109  * Public function prototypes
110  *============================================================================*/
111
118 /*----------------------------------------------------------------------------*/
119
122
123 /*----------------------------------------------------------------------------*/
131 /*----------------------------------------------------------------------------*/
132
133 void
135  cs_lnum_t n_faces,
137
138 /*----------------------------------------------------------------------------*/
144 /*----------------------------------------------------------------------------*/
145
146 void
148
149 /*----------------------------------------------------------------------------*/
155 /*----------------------------------------------------------------------------*/
156
157 void
159
160 /*----------------------------------------------------------------------------*/
166 /*----------------------------------------------------------------------------*/
167
168 void
170
171 /*----------------------------------------------------------------------------*/
179 /*----------------------------------------------------------------------------*/
180
181 void
183  const cs_cdo_quantities_t *quant,
184  const cs_range_set_t *rset);
185
186 /*----------------------------------------------------------------------------*/
197 /*----------------------------------------------------------------------------*/
198
199 void
201  void *context);
202
203 /*----------------------------------------------------------------------------*/
216
217 int
219  const cs_equation_param_t *eqp,
221
222 /*----------------------------------------------------------------------------*/
235 /*----------------------------------------------------------------------------*/
236
237 int
239  const cs_equation_param_t *eqp,
241
242 /*----------------------------------------------------------------------------*/
254 /*----------------------------------------------------------------------------*/
255
256 int
258  const cs_equation_param_t *eqp,
260
261 /*----------------------------------------------------------------------------*/
276 /*----------------------------------------------------------------------------*/
277
278 int
280  const cs_equation_param_t *eqp,
282
283 /*----------------------------------------------------------------------------*/
299 /*----------------------------------------------------------------------------*/
300
301 int
303  const cs_equation_param_t *eqp,
305
306 /*----------------------------------------------------------------------------*/
318 /*----------------------------------------------------------------------------*/
319
320 int
322  const cs_equation_param_t *eqp,
324
325 /*----------------------------------------------------------------------------*/
338 /*----------------------------------------------------------------------------*/
339
340 int
342  const cs_equation_param_t *eqp,
344
345 /*----------------------------------------------------------------------------*/
346
348
349 #endif /* __CS_CDOFB_MONOLITHIC_SLES_H__ */
int cs_cdofb_monolithic_uzawa_cg_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Use the preconditioned Uzawa-CG algorithm to solve the saddle-point problem arising from CDO-Fb schem...
Definition: cs_cdofb_monolithic_sles.c:3115
void cs_cdofb_monolithic_sles_set_shared(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_range_set_t *rset)
Set pointers to shared structures.
Definition: cs_cdofb_monolithic_sles.c:2566
Definition: cs_equation_param.h:202
int cs_cdofb_monolithic_uzawa_al_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Use the Uzawa algorithm with an Augmented Lagrangian technique to solve the saddle-point problem aris...
Definition: cs_cdofb_monolithic_sles.c:3693
cs_real_t * b_c
Definition: cs_cdofb_monolithic_sles.h:97
cs_real_t * div_op
Definition: cs_cdofb_monolithic_sles.h:83
Definition: cs_defs.h:495
int cs_cdofb_monolithic_gkb_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Use the GKB algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes and Na...
Definition: cs_cdofb_monolithic_sles.c:2962
int cs_cdofb_monolithic_by_blocks_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-b...
Definition: cs_cdofb_monolithic_sles.c:2932
void cs_cdofb_monolithic_sles_reset(cs_cdofb_monolithic_sles_t *msles)
Reset to zero rhs and clean the cs_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:2482
Definition: cs_cdofb_monolithic_sles.h:103
Definition: cs_navsto_param.h:540
Definition: cs_defs.h:307
Definition: cs_matrix.h:94
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
void cs_cdofb_monolithic_sles_init(cs_lnum_t n_cells, cs_lnum_t n_faces, cs_cdofb_monolithic_sles_t *msles)
Allocate and initialize the rhs.
Definition: cs_cdofb_monolithic_sles.c:2449
cs_real_t * u_f
Definition: cs_cdofb_monolithic_sles.h:93
cs_sles_t * sles
Definition: cs_cdofb_monolithic_sles.h:99
Definition: cs_cdofb_monolithic_sles.h:56
cs_real_t * b_f
Definition: cs_cdofb_monolithic_sles.h:96
Definition: cs_range_set.h:57
int cs_cdofb_monolithic_uzawa_n3s_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Definition: cs_cdofb_monolithic_sles.c:3383
cs_matrix_t ** block_matrices
Definition: cs_cdofb_monolithic_sles.h:77
void cs_cdofb_monolithic_set_sles(cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to couple the system...
Definition: cs_cdofb_monolithic_sles.c:2592
cs_real_t * p_c
Definition: cs_cdofb_monolithic_sles.h:94
cs_sles_t * schur_sles
Definition: cs_cdofb_monolithic_sles.h:100
cs_cdofb_monolithic_sles_t * cs_cdofb_monolithic_sles_create(void)
Create an empty cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:2412
Definition: cs_defs.h:301
void cs_cdofb_monolithic_sles_clean(cs_cdofb_monolithic_sles_t *msles)
Free a part of the structure.
Definition: cs_cdofb_monolithic_sles.c:2516
Definition: cs_defs.h:496
int n_row_blocks
Definition: cs_cdofb_monolithic_sles.h:74
int cs_cdofb_monolithic_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Definition: cs_cdofb_monolithic_sles.c:2802
cs_lnum_t n_cells
Definition: cs_cdofb_monolithic_sles.h:91
cs_lnum_t n_faces
Definition: cs_cdofb_monolithic_sles.h:89
cs_matrix_t * compatible_laplacian
Definition: cs_cdofb_monolithic_sles.h:81
int cs_cdofb_monolithic_uzawa_al_incr_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
Use the Uzawa algorithm with an Augmented Lagrangian technique in an incremental way to solve the sad...
Definition: cs_cdofb_monolithic_sles.c:3832
void cs_cdofb_monolithic_sles_free(cs_cdofb_monolithic_sles_t **p_msles)
Free memory related to cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:2540
