cs_navsto_param_t Struct Reference
Structure storing the parameters related to the resolution of the Navier-Stokes system. More...
#include <cs_navsto_param.h>
+ Collaboration diagram for cs_navsto_param_t:
Data Fields
Physical modelling
Which equations to solve ? Properties and their related fields are allocated according to the choice of model for Navier-Stokes
cs_navsto_param_model_t model
cs_navsto_param_model_flag_t model_flag
cs_turbulence_param_tturbulence
Properties and fields related to the Navier-Stokes module
cs_physical_constants_tphys_constants
cs_property_tmass_density
cs_property_ttot_viscosity
cs_property_tlam_viscosity
Numerical options
Set of numerical options to build the linear system and how to solve it
cs_param_dof_reduction_t dof_reduction_mode
cs_navsto_param_coupling_t coupling
cs_real_t gd_scale_coef
cs_param_time_scheme_t time_scheme
cs_real_t theta
cs_param_space_scheme_t space_scheme
cs_param_advection_form_t adv_form
cs_param_advection_scheme_t adv_scheme
cs_param_advection_strategy_t adv_strategy
cs_param_advection_extrapol_t adv_extrapol
cs_quadrature_type_t qtype
cs_navsto_param_sles_tsles_param
cs_real_t delta_thermal_tolerance
int n_max_outer_iter
Output
int verbosity
cs_navsto_param_post_flag_t post_flag
Initial conditions (IC)
Set of parameters used to take into account the initial condition on the pressure and/or the velocity. CAUTION: so far, there is no check if the different IC are compatible with the boundary conditions for instance
bool velocity_ic_is_owner
int n_velocity_ic_defs
cs_xdef_t ** velocity_ic_defs
bool pressure_ic_is_owner
int n_pressure_ic_defs
cs_xdef_t ** pressure_ic_defs
Boundary conditions (BC)
Set of parameters used to take into account the boundary conditions on the pressure and/or the velocity.
const cs_boundary_tboundaries
bool velocity_bc_is_owner
int n_velocity_bc_defs
cs_xdef_t ** velocity_bc_defs
bool pressure_bc_is_owner
int n_pressure_bc_defs
cs_xdef_t ** pressure_bc_defs
Other conditions
cs_real_t reference_pressure
cs_lnum_t n_solid_cells
cs_lnum_tsolid_cell_ids
Field Documentation
◆ adv_extrapol
adv_extrapol
Extrapolation used to estimate the advection field
◆ adv_form
adv_form
Type of formulation for the advection term
◆ adv_scheme
adv_scheme
Type of scheme for the advection term
◆ adv_strategy
adv_strategy
Strategy to handle the advection term
◆ boundaries
const cs_boundary_t* boundaries
◆ coupling
coupling
Choice of algorithm for solving the system
◆ delta_thermal_tolerance
Value under which one considers that the thermal equation is converged max_{c Cells} |T_c - T_{ref}|/|T_{ref}| < eps => stop iteration
◆ dof_reduction_mode
dof_reduction_mode
How are defined the Degrees of freedom
◆ gd_scale_coef
gd_scale_coef
Default value to set the scaling of the grad-div term when an artificial compressibility algorithm or an Uzawa-Augmented Lagrangian method is used
◆ lam_viscosity
cs_property_t* lam_viscosity
◆ mass_density
mass_density
Mass_density of the fluid, pointer to cs_property_t used in several terms in the Navier-Stokes equations
◆ model
model
Modelling related to the Navier-Stokes system of equations
◆ model_flag
model_flag
Flag storing high-level option related to the Navier-Stokes system
◆ n_max_outer_iter
n_max_outer_iter
Stopping crierion related to the maximum number of outer iterations allowed. This outer iteration encompasses the Navier-Stokes system, and (according to the case settings) the turbulence system and/or the thermal system.
◆ n_pressure_bc_defs
n_pressure_bc_defs
Number of boundary conditions associated to the pressure field.
◆ n_pressure_ic_defs
n_pressure_ic_defs
Number of initial conditions associated to the pressure
◆ n_solid_cells
n_solid_cells
If n_solid_cells > 0, then one requests that a part of the fluid is considered as a solid and an enforcement of this condition has to be done on the (Navier-)Stokes system. This implies an enforcement on the momentum equation and a specific treatment of the pressure gradient.
◆ n_velocity_bc_defs
n_velocity_bc_defs
Number of definitions related to the settings of the boundary conditions for the velocity field.
◆ n_velocity_ic_defs
n_velocity_ic_defs
Number of initial conditions associated to the velocity
◆ phys_constants
phys_constants
Main physical constants (gravity vector and coriolis source term). This structure is shared with the legacy part.
◆ post_flag
post_flag
Flag storing which predefined post-processing has to be done
◆ pressure_bc_defs
pressure_bc_defs
Pointers to the definitions of the boundary conditions associated to the pressure field.
◆ pressure_bc_is_owner
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t if an equation solves the pressure field.
◆ pressure_ic_defs
pressure_ic_defs
Pointers to the definitions of the initial conditions associated to the pressure. In order to force a zero-mean pressure, the code can compute the average of the resulting pressure and subtract it
◆ pressure_ic_is_owner
◆ qtype
qtype
A cs_quadrature_type_t indicating the type of quadrature to use in all routines involving quadratures
◆ reference_pressure
reference_pressure
Value of the reference pressure p0 (used for rescaling or during update of physical quantities). By default: 0.
◆ sles_param
sles_param
Set of choices to control the resolution of the Navier–Stokes system
◆ solid_cell_ids
solid_cell_ids
List on local cell ids where an enforcement to a zero velocity/zero mass flux has to be performed
◆ space_scheme
space_scheme
Discretization scheme for space
◆ theta
theta
Value of the parameter for the time scheme when a theta-scheme is used
◆ time_scheme
time_scheme
Discretization scheme for time
◆ tot_viscosity
tot_viscosity
Laminar viscosity + if needed the turbulent viscosity Pointer to cs_property_t associated to the diffusion term for the momentum equation
◆ turbulence
turbulence
Structure storing all information needed to set the turbulence modelling
◆ velocity_bc_defs
velocity_bc_defs
Array of pointers to the definition of boundary conditions for the velocity field
◆ velocity_bc_is_owner
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t Most of the time this should be false since an equation is associated to to the resolution of the velocity field (the momentum equation).
◆ velocity_ic_defs
velocity_ic_defs
Pointers to the definitions of the initial conditions associated to the velocity. The code does not check if the resulting initial velocity satisfies the divergence constraint.
◆ velocity_ic_is_owner
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a cs_equation_param_t structure dedicated to the momentum equation.
◆ verbosity
verbosity
Level of display of the information related to the Navier-Stokes system
