cs_navsto_param_sles_t Struct Reference
Structure storing the parameters for solving the Navier-Stokes system. More...
#include <cs_navsto_param.h>
+ Collaboration diagram for cs_navsto_param_sles_t:
Data Fields
cs_navsto_sles_t strategy
cs_navsto_schur_approx_t schur_approximation
Inner and linear algorithm
Set of parameters to drive the resolution of the (inner) linear system
cs_real_t il_algo_rtol
cs_real_t il_algo_atol
cs_real_t il_algo_dtol
int n_max_il_algo_iter
int il_algo_verbosity
Non-linear algorithm
Set of parameters to drive the resolution of the non-linearity arising from the Navier–Stokes system
cs_navsto_nl_algo_t nl_algo
cs_real_t nl_algo_rtol
cs_real_t nl_algo_atol
cs_real_t nl_algo_dtol
int n_max_nl_algo_iter
int nl_algo_verbosity
Block preconditioning or Schur complement approximation
Set of parameters to drive the resolution of the pressure-related block. This is often a Schur complement approximation to B.A^-1.Bt
cs_param_sles_tschur_sles_param
Field Documentation
◆ il_algo_atol
il_algo_atol
Similar to il_algo_rtol but in the case of an absolute tolerance factor.
◆ il_algo_dtol
il_algo_dtol
Similar to il_algo_rtol but in the case of a divergence tolerance factor. (default 1e3)
◆ il_algo_rtol
il_algo_rtol
Relative tolerance factor of the linear and inner system used to solve either the Oseen or the Stokes system. This algorithm is for instance an Uzawa or GKB algorithm. This is incorporated in a non-linear process in case of Navier–Stokes equations.
◆ il_algo_verbosity
il_algo_verbosity
Level of verbosity related to the inner linear system
Level of verbosity related to the non-linear algorithm
◆ n_max_il_algo_iter
n_max_il_algo_iter
Maximal number of iterations to solve the inner linear system
◆ n_max_nl_algo_iter
n_max_nl_algo_iter
Maximal number of iterations for the Picard algorithm used to handle the non-linearity arising from the advection term.
◆ nl_algo
nl_algo
Type of algorithm used to tackle the non-linearity
◆ nl_algo_atol
nl_algo_atol
Absolute tolerance factor used in the algorithm used for tackling the non-linearity.
◆ nl_algo_dtol
nl_algo_dtol
Divergence tolerance factor used in the algorithm used for tackling the non-linearity.
◆ nl_algo_rtol
nl_algo_rtol
Relative tolerance factor used in the algorithm used for tackling the non-linearity.
◆ nl_algo_verbosity
◆ schur_approximation
◆ schur_sles_param
cs_param_sles_t* schur_sles_param
◆ strategy
strategy
Choice of strategy for solving the Navier–Stokes system
