1 #ifndef __CS_NAVSTO_PARAM_H__ 2 #define __CS_NAVSTO_PARAM_H__ 51 #define CS_NAVSTO_STREAM_EQNAME "streamfunction_eq" 1047 const char *keyval);
void cs_navsto_param_transfer(const cs_navsto_param_t *nsp, cs_equation_param_t *eqp)
Apply the numerical settings defined for the Navier-Stokes system to an equation related to this syst...
Definition: cs_navsto_param.c:1145
Definition: cs_navsto_param.h:961
void cs_navsto_param_log(const cs_navsto_param_t *nsp)
Summary of the main cs_navsto_param_t structure.
Definition: cs_navsto_param.c:1204
Definition: cs_navsto_param.h:958
Definition: cs_navsto_param.h:963
cs_property_t * lam_viscosity
Definition: cs_navsto_param.h:595
void cs_navsto_set_outlets(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to outlets into the set of parameters for the manag...
Definition: cs_navsto_param.c:1798
Definition: cs_navsto_param.h:941
Definition: cs_navsto_param.h:942
cs_navsto_param_sles_t * sles_param
Definition: cs_navsto_param.h:662
Definition: cs_navsto_param.h:944
int n_velocity_ic_defs
Definition: cs_navsto_param.h:720
Definition: cs_navsto_param.h:343
Definition: cs_advection_field.h:149
Definition: cs_navsto_param.h:953
void cs_navsto_add_oseen_field(cs_navsto_param_t *nsp, cs_adv_field_t *adv_fld)
Add a advection field for the Oseen problem.
Definition: cs_navsto_param.c:2364
cs_navsto_param_t * cs_navsto_param_create(const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag)
Create a new structure to store all numerical parameters related to the resolution of the Navier-Stok...
Definition: cs_navsto_param.c:494
Definition: cs_navsto_param.h:137
cs_real_t reference_pressure
Definition: cs_navsto_param.h:800
Definition: cs_navsto_param.h:950
Definition: cs_navsto_param.h:525
Definition: cs_navsto_param.h:134
bool velocity_ic_is_owner
Definition: cs_navsto_param.h:719
Definition: cs_navsto_param.h:531
Definition: cs_navsto_param.h:350
Definition: cs_navsto_param.h:397
Structure storing the parameters for solving the Navier-Stokes system.
Definition: cs_navsto_param.h:405
Definition: cs_equation_param.h:202
Definition: cs_navsto_param.h:345
Definition: cs_navsto_param.h:85
cs_xdef_t ** pressure_ic_defs
Definition: cs_navsto_param.h:739
cs_xdef_t * cs_navsto_add_velocity_ic_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define the initial condition for the velocity unknowns. This definition can be done on a specified me...
Definition: cs_navsto_param.c:1529
Definition: cs_navsto_param.h:960
Definition: cs_navsto_param.h:336
cs_xdef_t * cs_navsto_add_source_term_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
Define a new source term structure defined by an analytical function.
Definition: cs_navsto_param.c:2274
Definition: cs_navsto_param.h:136
cs_real_t il_algo_rtol
Definition: cs_navsto_param.h:429
cs_xdef_t * cs_navsto_set_velocity_inlet_by_dof_func(cs_navsto_param_t *nsp, const char *z_name, cs_dof_func_t *func, void *func_input)
Define the velocity field for an inlet boundary using a DoF function.
Definition: cs_navsto_param.c:2204
Definition: cs_navsto_param.h:176
Definition: cs_defs.h:495
Definition: cs_navsto_param.h:937
Definition: cs_navsto_param.h:135
cs_quadrature_type_t qtype
Definition: cs_navsto_param.h:657
Definition: cs_navsto_param.h:378
Definition: cs_navsto_param.h:954
int il_algo_verbosity
Definition: cs_navsto_param.h:451
cs_xdef_t * cs_navsto_add_source_term_by_array(cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, cs_lnum_t *index)
Define a new source term structure defined by an array.
Definition: cs_navsto_param.c:2338
Definition: cs_navsto_param.h:376
Definition: cs_navsto_param.h:947
cs_real_t gd_scale_coef
Definition: cs_navsto_param.h:619
Definition: cs_navsto_param.h:347
Definition: cs_navsto_param.h:956
void cs_navsto_set_fixed_walls(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to a fixed wall into the set of parameters for the ...
Definition: cs_navsto_param.c:1700
cs_property_t * mass_density
Definition: cs_navsto_param.h:581
int n_pressure_ic_defs
Definition: cs_navsto_param.h:738
Definition: cs_navsto_param.h:945
cs_property_t * tot_viscosity
Definition: cs_navsto_param.h:589
cs_flag_t cs_navsto_param_post_flag_t
cs_xdef_t * cs_navsto_add_source_term_by_val(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val)
Define a new source term structure defined by a constant value.
Definition: cs_navsto_param.c:2308
void cs_navsto_param_set(cs_navsto_param_t *nsp, cs_navsto_key_t key, const char *keyval)
Set a parameter attached to a keyname in a cs_navsto_param_t structure.
Definition: cs_navsto_param.c:737
cs_xdef_t * cs_navsto_add_velocity_ic_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val)
Definition: cs_navsto_param.c:1466
Definition: cs_navsto_param.h:528
cs_equation_param_t * cs_navsto_param_get_velocity_param(const cs_navsto_param_t *nsp)
Retrieve the cs_equation_param_t structure related to the velocity equation (momentum equation in mos...
Definition: cs_navsto_param.c:1347
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:155
Definition: cs_navsto_param.h:939
Definition: cs_navsto_param.h:946
cs_param_advection_strategy_t
Choice of how to handle the advection term in an equation.
Definition: cs_param_types.h:344
cs_turbulence_param_t * turbulence
Definition: cs_navsto_param.h:563
Definition: cs_navsto_param.h:540
Structure and routines handling the SLES settings stored inside a cs_param_sles_t structure...
cs_lnum_t n_solid_cells
Definition: cs_navsto_param.h:814
int n_max_il_algo_iter
Definition: cs_navsto_param.h:446
cs_xdef_t * cs_navsto_set_velocity_wall_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values)
Define the velocity field for a sliding wall boundary using a uniform value.
Definition: cs_navsto_param.c:1938
cs_xdef_t ** velocity_bc_defs
Definition: cs_navsto_param.h:771
cs_xdef_t * cs_navsto_set_velocity_inlet_by_array(cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, cs_lnum_t *index)
Define the velocity field for an inlet boundary using an array of values.
Definition: cs_navsto_param.c:2134
Definition: cs_defs.h:307
Definition: cs_navsto_param.h:344
cs_navsto_nl_algo_t
Type of algorithm used to tackle the non-linearity arising from the Navier-Stokes system...
Definition: cs_navsto_param.h:393
Definition: cs_navsto_param.h:948
int n_max_nl_algo_iter
Definition: cs_navsto_param.h:488
cs_real_t delta_thermal_tolerance
Definition: cs_navsto_param.h:668
Definition: cs_navsto_param.h:936
cs_real_t nl_algo_atol
Definition: cs_navsto_param.h:476
cs_param_advection_extrapol_t
Choice of how to extrapolate the advection field in the advection term.
Definition: cs_param_types.h:378
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:119
Definition: cs_navsto_param.h:84
cs_real_t nl_algo_dtol
Definition: cs_navsto_param.h:482
Definition: cs_navsto_param.h:181
cs_param_space_scheme_t
Definition: cs_param_types.h:172
Definition: cs_navsto_param.h:557
Definition: cs_navsto_param.h:375
Definition: cs_quadrature.h:52
Definition: cs_navsto_param.h:949
cs_real_t il_algo_atol
Definition: cs_navsto_param.h:435
cs_navsto_key_t
List of available keys for setting the parameters of the Navier-Stokes system.
Definition: cs_navsto_param.h:934
Definition: cs_navsto_param.h:938
void cs_navsto_set_reference_pressure(cs_navsto_param_t *nsp, cs_real_t pref)
Set the value to consider for the reference pressure.
Definition: cs_navsto_param.c:1440
Definition: cs_navsto_param.h:180
Generic function pointer for an evaluation relying on an analytic function elt_ids is optional...
Definition: cs_param_types.h:94
bool velocity_bc_is_owner
Definition: cs_navsto_param.h:769
cs_navsto_nl_algo_t nl_algo
Definition: cs_navsto_param.h:464
cs_param_time_scheme_t time_scheme
Definition: cs_navsto_param.h:628
const cs_boundary_t * boundaries
Definition: cs_navsto_param.h:752
Definition: cs_navsto_param.h:87
cs_xdef_t * cs_navsto_set_velocity_inlet_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values)
Define the velocity field for an inlet boundary using a uniform value.
Definition: cs_navsto_param.c:1998
cs_navsto_param_post_bit_t
Bit values for additional generic postprocessing related to the Navier-Stokes module. In what follows, w denotes the vorticity vector, u the velocity vector and k the kinetic energy defined by 1/2 * u u.
Definition: cs_navsto_param.h:174
Definition: cs_navsto_param.h:552
Definition: cs_navsto_param.h:691
Definition: cs_navsto_param.h:348
cs_param_advection_extrapol_t adv_extrapol
Definition: cs_navsto_param.h:651
Structure storing the parameters related to the resolution of the tubulence modelling. Several members are structures defined in cs_turbulence_model.h as a global variable. The prupose of this structure is to store all parameters in one place.
Definition: cs_cdo_turbulence.h:63
cs_xdef_t ** velocity_ic_defs
Definition: cs_navsto_param.h:721
cs_param_advection_form_t adv_form
Definition: cs_navsto_param.h:648
Definition: cs_navsto_param.h:338
cs_xdef_t * cs_navsto_add_pressure_ic_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val)
Define the initial condition for the pressure unknowns. This definition can be done on a specified me...
Definition: cs_navsto_param.c:1600
Definition: cs_navsto_param.h:952
bool pressure_ic_is_owner
Definition: cs_navsto_param.h:737
Definition: cs_navsto_param.h:959
Definition: cs_navsto_param.h:138
void cs_navsto_set_symmetries(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to a symmetry into the set of parameters for the ma...
Definition: cs_navsto_param.c:1748
Definition: cs_xdef.h:154
Definition: cs_navsto_param.h:339
cs_real_t theta
Definition: cs_navsto_param.h:629
Definition: cs_navsto_param.h:951
Definition: cs_navsto_param.h:395
cs_param_advection_strategy_t adv_strategy
Definition: cs_navsto_param.h:650
cs_xdef_t * cs_navsto_set_velocity_inlet_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
Define the velocity field for an inlet boundary using an analytical function.
Definition: cs_navsto_param.c:2060
Definition: cs_navsto_param.h:139
const char * cs_navsto_param_get_coupling_name(cs_navsto_param_coupling_t coupling)
Retrieve the name of the coupling algorithm.
Definition: cs_navsto_param.c:1412
cs_navsto_schur_approx_t schur_approximation
Definition: cs_navsto_param.h:415
cs_xdef_t * cs_navsto_add_pressure_ic_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Definition: cs_navsto_param.c:1649
cs_navsto_sles_t
High-level information about the way of settings the SLES for solving the Navier-Stokes system...
Definition: cs_navsto_param.h:334
cs_real_t il_algo_dtol
Definition: cs_navsto_param.h:441
Definition: cs_navsto_param.h:83
Definition: cs_navsto_param.h:337
bool pressure_bc_is_owner
Definition: cs_navsto_param.h:786
Definition: cs_navsto_param.h:341
Definition: cs_defs.h:301
cs_xdef_t ** pressure_bc_defs
Definition: cs_navsto_param.h:788
int n_pressure_bc_defs
Definition: cs_navsto_param.h:787
cs_navsto_param_model_bit_t
Bit values for additional physical modelling related to the Navier-Stokes system of equations...
Definition: cs_navsto_param.h:132
Definition: cs_defs.h:496
int nl_algo_verbosity
Definition: cs_navsto_param.h:493
Definition: cs_navsto_param.h:182
unsigned short int cs_flag_t
Definition: cs_defs.h:309
cs_navsto_param_t * cs_navsto_param_free(cs_navsto_param_t *param)
Free a cs_navsto_param_t structure.
Definition: cs_navsto_param.c:655
cs_param_dof_reduction_t
Definition: cs_param_types.h:199
Physical constants descriptor.
Definition: cs_physical_constants.h:51
int verbosity
Definition: cs_navsto_param.h:686
Definition: cs_navsto_param.h:346
cs_param_sles_t * schur_sles_param
Definition: cs_navsto_param.h:505
const char * cs_navsto_param_get_model_name(cs_navsto_param_model_t model)
Retrieve the name of the model system of equations.
Definition: cs_navsto_param.c:1383
int n_velocity_bc_defs
Definition: cs_navsto_param.h:770
Definition: cs_navsto_param.h:529
Definition: cs_navsto_param.h:527
Definition: cs_navsto_param.h:342
cs_param_advection_scheme_t
Definition: cs_param_types.h:311
cs_lnum_t * solid_cell_ids
Definition: cs_navsto_param.h:815
Definition: cs_navsto_param.h:179
Definition: cs_navsto_param.h:957
Definition: cs_navsto_param.h:177
Definition: cs_navsto_param.h:955
cs_param_dof_reduction_t dof_reduction_mode
Definition: cs_navsto_param.h:607
Definition: cs_navsto_param.h:943
Describe the system of equations related to the Navier-Stokes to be solved.
int n_max_outer_iter
Definition: cs_navsto_param.h:676
Definition: cs_param_types.h:234
Structure and routines handling the specific settings related to a cs_equation_t structure.
cs_navsto_sles_t strategy
Definition: cs_navsto_param.h:410
Strategy to build the Schur complement approximation. This appears in block preconditioning or uzawa ...
Definition: cs_navsto_param.h:373
Definition: cs_param_types.h:267
Definition: cs_navsto_param.h:940
cs_flag_t cs_navsto_param_model_flag_t
Definition: cs_navsto_param.h:57
cs_xdef_t * cs_navsto_set_pressure_bc_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values)
Set the pressure field on a boundary using a uniform value.
Definition: cs_navsto_param.c:1852
cs_physical_constants_t * phys_constants
Definition: cs_navsto_param.h:574
Structure storing all metadata related to the resolution of a linear system with an iterative solver...
Definition: cs_param_sles.h:62
cs_param_advection_scheme_t adv_scheme
Definition: cs_navsto_param.h:649
cs_real_t nl_algo_rtol
Definition: cs_navsto_param.h:470
Definition: cs_navsto_param.h:612
cs_param_space_scheme_t space_scheme
Definition: cs_navsto_param.h:634
Definition: cs_navsto_param.h:178
Definition: cs_navsto_param.h:340
