Structure and routines handling the SLES settings stored inside a cs_param_sles_t structure.
More...
| struct | cs_param_sles_t |
| | Structure storing all metadata related to the resolution of a linear system with an iterative solver. More...
◆ cs_equation_param_set_mumps_sles()
| void cs_equation_param_set_mumps_sles |
bool |
use_field_id, |
cs_param_sles_t * |
slesp |
Set parameters for initializing SLES structures used for the resolution of the linear system. Case of MUMPS's own solvers.
- Parameters
| [in] | use_field_id | if false use system name |
| [in,out] | slesp | pointer to a cs_param_sles_t structure |
◆ cs_equation_param_set_petsc_hypre_sles()
| void cs_equation_param_set_petsc_hypre_sles |
bool |
use_field_id, |
cs_param_sles_t * |
slesp |
Set parameters for initializing SLES structures used for the resolution of the linear system. Case of PETSc and Hypre families of solvers.
- Parameters
◆ cs_equation_param_set_saturne_sles()
| void cs_equation_param_set_saturne_sles |
bool |
use_field_id, |
cs_param_sles_t * |
slesp |
Set parameters for initializing SLES structures used for the resolution of the linear system. Case of saturne's own solvers.
- Parameters
◆ cs_param_sles_copy_from()
Copy a cs_param_sles_t structure from src to dst.
- Parameters
| [in] | src | reference cs_param_sles_t structure to copy |
| [in,out] | dst | copy of the reference at exit |
◆ cs_param_sles_create()
| cs_param_sles_t* cs_param_sles_create |
int |
field_id, |
const char * |
system_name |
Create a cs_param_sles_t structure and assign a default settings.
- Parameters
| [in] | field_id | id related to to the variable field or -1 |
| [in] | system_name | name of the system to solve or NULL |
- Returns
- a pointer to a cs_param_sles_t stucture
◆ cs_param_sles_free()
Free a cs_param_sles_t structure.
- Parameters
| [in,out] | slesp | pointer to a structure to free |
◆ cs_param_sles_log()
Log information related to the linear settings stored in the structure.
- Parameters
◆ cs_param_sles_set()
Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Sparse Linear Equation Solver)
- Parameters
| [in] | use_field_id | if false use system name to define a SLES |
- Returns
- an error code (-1 if a problem is encountered, 0 otherwise)
