cs_turbulence_param_t Struct Reference
Structure storing the parameters related to the resolution of the tubulence modelling. Several members are structures defined in cs_turbulence_model.h as a global variable. The prupose of this structure is to store all parameters in one place. More...
#include <cs_cdo_turbulence.h>
+ Collaboration diagram for cs_turbulence_param_t:
Data Fields
cs_turb_model_tmodel
cs_turb_rans_model_trans_param
cs_turb_les_model_tles_param
cs_turb_ref_values_treference_values
Field Documentation
◆ les_param
les_param
Main set of parameters to handle LES modelling. This structure is shared with the legacy part. LES means Large Eddy Simulation
◆ model
model
Main set of parameters to handle turbulence modelling. This structure is shared with the legacy part.
◆ rans_param
rans_param
Main set of parameters to handle RANS modelling. This structure is shared with the legacy part. RANS means Reynolds Average Navier-Stokes
◆ reference_values
reference_values
Set of reference values associated to the turbulence modelling
