cs_turb_rans_model_t Struct Reference
RANS turbulence model descriptor. More...
#include <cs_turbulence_model.h>
+ Collaboration diagram for cs_turb_rans_model_t:
Data Fields
int irccor
int itycor
int idirsm
int iclkep
int igrhok
int igrake
int igrari
int ikecou
int reinit_turb
int irijco
int irijnu
int irijrb
int irijec
int idifre
int iclsyr
int iclptr
double xlomlg
Members of this turbulence model are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
Field Documentation
◆ iclkep
iclkep
Indicates the clipping method used for $k$ and $\varepsilon$, for the $k-\epsilon$ and v2f models
  • 0: clipping in absolute value
  • 1: coupled clipping based on physical relationships
    Useful if and only if iturb = 20, 21 or 50 ( $k-\epsilon$ and v2f models). The results obtained with the method corresponding to iclkep =1 showed in some cases a substantial sensitivity to the values of the length scale almax.
    The option iclkep = 1 is therefore not recommended, and, if chosen, must be used cautiously.
◆ iclptr
iclptr
partial implicitation of wall BCs of $ \tens{R} $
  • 1: true
  • 0: false (default)
◆ iclsyr
iclsyr
partial implicitation of symmetry BCs of $ \tens{R} $
  • 1: true (default)
  • 0: false
◆ idifre
idifre
whole treatment of the diagonal part of the diffusion tensor of $ \tens{R} $ and $ \varepsilon $
  • 1: true (default)
  • 0: simplified treatment
◆ idirsm
idirsm
turbulent diffusion model for second moment closure
  • 0: scalar diffusivity (Shir model)
  • 1: tensorial diffusivity (Daly and Harlow model, default model)
◆ igrake
igrake
Indicates if the terms related to gravity are taken into account in the equations of $k-\epsilon$.
  • 1: true (default if $ \rho $ is variable)
  • 0: false Useful if and only if iturb = 20, 21, 50 or 60 and (gravity) $\ne$ (0,0,0) and the density is not uniform.
◆ igrari
igrari
Indicates if the terms related to gravity are taken into account in the equations of $R_{ij}-\epsilon$.
  • 0: false Useful if and only if iturb = 30 or 31 and (gravity) $\ne$ (0,0,0) ( $R_{ij}-\epsilon$ model with gravity) and the density is not uniform.
◆ igrhok
igrhok
Indicates if the term $\frac{2}{3}\grad \rho k$ is taken into account in the velocity equation.
  • 1: true
  • 0: false in the velocity Useful if and only if iturb = 20, 21, 50 or 60.
    This term may generate non-physical velocities at the wall. When it is not explicitly taken into account, it is implicitly included into the pressure.
◆ ikecou
ikecou
Indicates if the coupling of the source terms of $k$ and $\epsilon$ or $k$ and $\omega$ is taken into account or not.
  • 1: true,
  • 0: false
    If ikecou = 0 in $k-\epsilon$ model, the term in $\epsilon$ in the equation of $k$ is made implicit.
    ikecou is initialised to 0 if iturb = 21 or 60, and to 1 if iturb = 20.
    ikecou = 1 is forbidden when using the v2f model (iturb = 50).
    Useful if and only if iturb = 20, 21 or 60 ( $k-\epsilon$ and $k-\omega$ models)
◆ irccor
irccor
activation of rotation/curvature correction for an eddy viscosity turbulence models
  • 0: false
  • 1: true
◆ irijco
irijco
coupled solving of Rij
  • 1: true (default)
  • 0: false
◆ irijec
irijec
Indicates if the wall echo terms in $R_{ij}-\epsilon$ LRR model are taken into account:
  • 1: true,
    Useful if and only if iturb = 30 ( $R_{ij}-\epsilon$ LRR).
    It is not recommended to take these terms into account: they have an influence only near the walls, their expression is hardly justifiable according to some authors and, in the configurations studied with Code_Saturne, they did not bring any improvement in the results.
    In addition, their use induces an increase in the calculation time.
    The wall echo terms imply the calculation of the distance to the wall for every cell in the domain. See icdpar for potential restrictions due to this.
◆ irijnu
irijnu
pseudo eddy viscosity in the matrix of momentum equation to partially implicit $ \divv \left( \rho \tens{R} \right) $
  • 1: true
  • 0: false (default) The goal is to improve the stability of the calculation. The usefulness of irijnu = 1 has however not been clearly demonstrated.
    Since the system is solved in incremental form, this extra turbulent viscosity does not change the final solution for steady flows. However, for unsteady flows, the parameter nswrsm should be increased.
    Useful if and only if iturb = 30 or 31 ( $R_{ij}-\epsilon$ model).
◆ irijrb
irijrb
accurate treatment of $ \tens{R} $ at the boundary (see condli)
  • 1: true
◆ itycor
itycor
type of rotation/curvature correction for an eddy viscosity turbulence models
  • 1: Cazalbou correction (default when irccor = 1 and itytur = 2 or 5)
  • 2: Spalart-Shur correction (default when irccor = 1 and iturb = 60 or 70)
◆ reinit_turb
reinit_turb
Advanced re-init for EBRSM and k-omega models
  • 1: true
◆ xlomlg
xlomlg
mixing length for the mixing length model
Useful if and only if iturb= 10 (mixing length).
