condli.f90 File Reference
Translation of the boundary conditions given by cs_user_boundary_conditions in a form that fits to the solver. More...
Functions/Subroutines
subroutine condli (nvar, nscal, iterns, isvhb, itrale, italim, itrfin, ineefl, itrfup, cofale, xprale, icodcl, isostd, dt, rcodcl, visvdr, hbord, theipb)
subroutine set_dirichlet_scalar (coefa, cofaf, coefb, cofbf, pimp, hint, hext)
subroutine set_dirichlet_vector (coefa, cofaf, coefb, cofbf, pimpv, hint, hextv)
subroutine set_dirichlet_tensor (coefa, cofaf, coefb, cofbf, pimpts, hint, hextts)
subroutine set_dirichlet_vector_aniso (coefa, cofaf, coefb, cofbf, pimpv, hint, hextv)
subroutine set_neumann_scalar (coefa, cofaf, coefb, cofbf, dimp, hint)
subroutine set_neumann_vector (coefa, cofaf, coefb, cofbf, qimpv, hint)
subroutine set_neumann_tensor (coefa, cofaf, coefb, cofbf, qimpts, hint)
subroutine set_neumann_vector_aniso (coefa, cofaf, coefb, cofbf, qimpv, hint)
subroutine set_generalized_sym_vector (coefa, cofaf, coefb, cofbf, pimpv, qimpv, hint, normal)
subroutine set_generalized_sym_vector_aniso (coefa, cofaf, coefb, cofbf, pimpv, qimpv, hint, normal)
subroutine set_generalized_dirichlet_vector (coefa, cofaf, coefb, cofbf, pimpv, qimpv, hint, normal)
subroutine set_generalized_dirichlet_vector_aniso (coefa, cofaf, coefb, cofbf, pimpv, qimpv, hint, normal)
subroutine set_convective_outlet_scalar (coefa, cofaf, coefb, cofbf, pimp, cfl, hint)
subroutine set_convective_outlet_vector (coefa, cofaf, coefb, cofbf, pimpv, cflv, hint)
subroutine set_convective_outlet_tensor (coefa, cofaf, coefb, cofbf, pimpts, cflts, hint)
subroutine set_convective_outlet_vector_aniso (coefa, cofaf, coefb, cofbf, pimpv, cflv, hint)
subroutine set_affine_function_scalar (coefa, cofaf, coefb, cofbf, pinf, ratio, hint)
subroutine set_neumann_conv_h_neumann_diff_scalar (coefa, cofaf, coefb, cofbf, dimp, hint)
subroutine set_affine_function_conv_neumann_diff_scalar (coefa, cofaf, coefb, cofbf, pinf, ratio, dimp)
subroutine set_total_flux (coefa, cofaf, coefb, cofbf, hext, dimp)
subroutine set_dirichlet_conv_neumann_diff_scalar (coefa, cofaf, coefb, cofbf, pimp, dimp)
subroutine set_dirichlet_conv_neumann_diff_vector (coefa, cofaf, coefb, cofbf, pimpv, qimpv)
subroutine set_dirichlet_conv_neumann_diff_tensor (coefa, cofaf, coefb, cofbf, pimpts, qimpts)
subroutine condli_ini (nvar, nscal, itrale, icodcl, isostd, dt, rcodcl)
 Initialisation of boundary condition arrays. More...
The values at a boundary face $ \fib $ stored in the face center $ \centf $ of the variable $ P $ and its diffusive flux $ Q $ are written as:
\[ P_\centf = A_P^g + B_P^g P_\centi \]
and
\[ Q_\centf = -\left(A_P^f + B_P^f P_\centi\right) \]
where $ P_\centi $ is the value of the variable $ P $ at the neighboring cell.
Warning:
  • if we consider an increment of a variable, the boundary conditions read:
    \[ \delta P_\centf = B_P^g \delta P_\centi \]
    and
    \[ \delta Q_\centf = -B_P^f \delta P_\centi \]
  • for a vector field such as the veclocity $ \vect{u} $ the boundary conditions may read:
    \[ \vect{u}_\centf = \vect{A}_u^g + \tens{B}_u^g \vect{u}_\centi \]
    and
    \[ \vect{Q}_\centf = -\left(\vect{A}_u^f + \tens{B}_u^f \vect{u}_\centi\right) \]
    where $ \tens{B}_u^g $ and $ \tens{B}_u^f $ are 3x3 tensor matrix which coupled veclocity components next to a boundary.
Please refer to the boundary conditions section of the theory guide for more informations, as well as the condli section.
◆ condli()
subroutine condli ( integer  nvar,
integer  nscal,
integer  iterns,
integer  isvhb,
integer  itrale,
integer  italim,
integer  itrfin,
integer  ineefl,
integer  itrfup,
double precision, dimension(:,:), pointer  cofale,
double precision, dimension(:), pointer  xprale,
integer, dimension(:,:), pointer  icodcl,
integer, dimension(nfabor+1)  isostd,
double precision, dimension(:), pointer  dt,
double precision, dimension(:,:,:), pointer  rcodcl,
double precision, dimension(:), pointer  visvdr,
double precision, dimension(:), pointer  hbord,
double precision, dimension(:), pointer  theipb
[in]nvartotal number of variables
[in]nscaltotal number of scalars
[in]iternsiteration number on Navier-Stokes equations
[in]isvhbindicator to save exchange coeffient at the walls
[in]itraleALE iteration number
[in]italimfor ALE
[in]itrfinfor ALE
[in]ineeflfor ALE
[in]itrfupfor ALE
[in]cofalework array for FSI
[in]xpralework array for FSI
[in,out]icodclface boundary condition code:
  • 1 Dirichlet
  • 2 Radiative outlet
  • 3 Neumann
  • 4 sliding and $ \vect{u} \cdot \vect{n} = 0 $
  • 5 smooth wall and $ \vect{u} \cdot \vect{n} = 0 $
  • 6 rough wall and $ \vect{u} \cdot \vect{n} = 0 $
  • 9 free inlet/outlet (input mass flux blocked to 0)
  • 10 Boundary value related to the next cell value by an affine function
  • 11 Generalized Dirichlet for vectors
  • 12 Dirichlet boundary value related to the next cell value by an affine function for the advection operator and Neumann for the diffusion operator
  • 13 Dirichlet for the advection operator and Neumann for the diffusion operator
  • 14 Generalized symmetry for vectors (used for Marangoni effects modeling)
  • 15 Neumann for the advection operator and homogeneous Neumann for the diffusion operator (walls with hydro. pressure for the compressible module)
[in,out]isostdindicator for standard outlet and reference face index
[in]dttime step (per cell)
[in,out]rcodclboundary condition values:
  • rcodcl(1) value of the dirichlet
  • rcodcl(2) value of the exterior exchange coefficient (infinite if no exchange)
  • rcodcl(3) value flux density (negative if gain) in w/m2 or roughness in m if icodcl=6
    1. for the velocity $ (\mu+\mu_T) \gradv \vect{u} \cdot \vect{n} $
    2. for the pressure $ \Delta t \grad P \cdot \vect{n} $
    3. for a scalar $ cp \left( K + \dfrac{K_T}{\sigma_T} \right) \grad T \cdot \vect{n} $
[out]visvdrviscosite dynamique ds les cellules de bord apres amortisst de v driest
[out]hbordcoefficients d'echange aux bords
[out]theipbboundary temperature in $ \centip $ (more exaclty the energetic variable)
◆ condli_ini()
subroutine condli_ini ( integer  nvar,
integer  nscal,
integer  itrale,
integer, dimension(nfabor,nvar)  icodcl,
double precision, dimension(nfabor,nvar,3)  rcodcl
[in,out]icodclface boundary condition code (see condli)
◆ set_affine_function_conv_neumann_diff_scalar()
subroutine set_affine_function_conv_neumann_diff_scalar ( double precision  coefa,
double precision  cofaf,
double precision  coefb,
double precision  cofbf,
double precision  pinf,
double precision  ratio,
double precision  dimp
[out]coefaexplicit BC coefficient for gradients
[out]cofafexplicit BC coefficient for diffusive flux
[out]coefbimplicit BC coefficient for gradients
[out]cofbfimplicit BC coefficient for diffusive flux
[in]pinfaffine part
[in]ratiolinear part
[in]dimpFlux value to impose
◆ set_affine_function_scalar()
subroutine set_affine_function_scalar ( double precision  coefa,
double precision  hint
[in]pinfaffine part
[in]hintinternal exchange coefficient
◆ set_convective_outlet_scalar()
subroutine set_convective_outlet_scalar ( double precision  coefa,
double precision  pimp,
double precision  cfl,
[in]pimpFlux value to impose
[in]cflLocal Courant number used to convect
[in]hintInternal exchange coefficient
◆ set_convective_outlet_tensor()
subroutine set_convective_outlet_tensor ( double precision, dimension(6)  coefa,
double precision, dimension(6)  cofaf,
double precision, dimension(6,6)  coefb,
double precision, dimension(6,6)  cofbf,
double precision, dimension(6)  pimpts,
double precision, dimension(6)  cflts,
[in]pimptsDirichlet value to impose
[in]cfltsLocal Courant number used to convect
◆ set_convective_outlet_vector()
subroutine set_convective_outlet_vector ( double precision, dimension(3)  coefa,
double precision, dimension(3)  cofaf,
double precision, dimension(3,3)  coefb,
double precision, dimension(3,3)  cofbf,
double precision, dimension(3)  pimpv,
double precision, dimension(3)  cflv,
[in]pimpvDirichlet value to impose
[in]cflvLocal Courant number used to convect
◆ set_convective_outlet_vector_aniso()
subroutine set_convective_outlet_vector_aniso ( double precision, dimension(3)  coefa,
double precision, dimension(6)  hint
◆ set_dirichlet_conv_neumann_diff_scalar()
subroutine set_dirichlet_conv_neumann_diff_scalar ( double precision  coefa,
[in]pimpDirichlet value to impose
◆ set_dirichlet_conv_neumann_diff_tensor()
subroutine set_dirichlet_conv_neumann_diff_tensor ( double precision, dimension(6)  coefa,
double precision, dimension(6)  qimpts
[in]qimptsFlux value to impose
◆ set_dirichlet_conv_neumann_diff_vector()
subroutine set_dirichlet_conv_neumann_diff_vector ( double precision, dimension(3)  coefa,
double precision, dimension(3)  qimpv
[in]qimpvFlux value to impose
◆ set_dirichlet_scalar()
subroutine set_dirichlet_scalar ( double precision  coefa,
double precision  hint,
double precision  hext
[in]hextExternal exchange coefficient (10^30 by default)
◆ set_dirichlet_tensor()
subroutine set_dirichlet_tensor ( double precision, dimension(6)  coefa,
double precision, dimension(6)  hextts
[in]hexttsExternal exchange coefficient (10^30 by default)
◆ set_dirichlet_vector()
subroutine set_dirichlet_vector ( double precision, dimension(3)  coefa,
double precision, dimension(3)  hextv
[in]hextvExternal exchange coefficient (10^30 by default)
◆ set_dirichlet_vector_aniso()
subroutine set_dirichlet_vector_aniso ( double precision, dimension(3)  coefa,
double precision, dimension(6)  hint,
◆ set_generalized_dirichlet_vector()
subroutine set_generalized_dirichlet_vector ( double precision, dimension(3)  coefa,
double precision, dimension(3)  qimpv,
double precision, dimension(3)  normal
[in]pimpvDirichlet value to impose on the normal component
[in]qimpvFlux value to impose on the tangential components
[in]normalnormal
◆ set_generalized_dirichlet_vector_aniso()
subroutine set_generalized_dirichlet_vector_aniso ( double precision, dimension(3)  coefa,
[in]normalnormal
◆ set_generalized_sym_vector()
subroutine set_generalized_sym_vector ( double precision, dimension(3)  coefa,
[in]normalnormal
◆ set_generalized_sym_vector_aniso()
subroutine set_generalized_sym_vector_aniso ( double precision, dimension(3)  coefa,
[in]normalnormal
◆ set_neumann_conv_h_neumann_diff_scalar()
subroutine set_neumann_conv_h_neumann_diff_scalar ( double precision  coefa,
double precision  dimp,
◆ set_neumann_scalar()
subroutine set_neumann_scalar ( double precision  coefa,
◆ set_neumann_tensor()
subroutine set_neumann_tensor ( double precision, dimension(6)  coefa,
double precision, dimension(6)  qimpts,
◆ set_neumann_vector()
subroutine set_neumann_vector ( double precision, dimension(3)  coefa,
◆ set_neumann_vector_aniso()
subroutine set_neumann_vector_aniso ( double precision, dimension(3)  coefa,
◆ set_total_flux()
subroutine set_total_flux ( double precision  coefa,
double precision  hext,
[in]hextconvective flux to be imposed
