cs_turb_model_t Struct Reference
Turbulence model general options descriptor. More...
#include <cs_turbulence_model.h>
+ Collaboration diagram for cs_turb_model_t:
Data Fields
int iturb
int itytur
int hybrid_turb
int type
int order
Members of this turbulence model are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
Field Documentation
◆ hybrid_turb
hybrid_turb
Type of hybrid turbulence model
  • 0: No model
  • 1: Detached Eddy Simulation
  • 2: Delayed Detached Eddy Simulation
  • 3: Scale Adaptive Model (Menter et al.)
◆ iturb
iturb
turbulence model
  • CS_TURB_NONE: no turbulence model (laminar flow)
  • CS_TURB_MIXING_LENGTH: mixing length model
  • CS_TURB_K_EPSILON: standard $ k-\varepsilon $ model
  • CS_TURB_K_EPSILON_LIN_PROD: $ k-\varepsilon $ model with Linear Production (LP) correction
  • CS_TURB_K_EPSILON_LS: Launder-Sharma $ k-\varepsilon $ model
  • CS_TURB_K_EPSILON_QUAD: Baglietto et al. quadratic $ k-\varepsilon $ model
  • CS_TURB_RIJ_EPSILON_LRR: $ R_{ij}-\epsilon $ (LRR)
  • CS_TURB_RIJ_EPSILON_SSG: $ R_{ij}-\epsilon $ (SSG)
  • CS_TURB_RIJ_EPSILON_EBRSM: $ R_{ij}-\epsilon $ (EBRSM)
  • CS_TURB_LES_SMAGO_CONST: LES (constant Smagorinsky model)
  • CS_TURB_LES_SMAGO_DYN: LES ("classical" dynamic Smagorisky model)
  • CS_TURB_LES_WALE: LES (WALE)
  • CS_TURB_V2F_PHI: v2f phi-model
  • CS_TURB_V2F_BL_V2K: v2f $ BL-v^2-k $
  • CS_TURB_K_OMEGA: $ k-\omega $ SST
  • CS_TURB_SPALART_ALLMARAS: Spalart-Allmaras model
◆ itytur
itytur
class of turbulence model (integer value iturb/10, deprecated)
◆ order
int order
◆ type
type
Type of modelling
  • CS_TURB_NONE: No model
  • CS_TURB_RANS: RANS
  • CS_TURB_LES: LES
  • CS_TURB_HYBRID: Hybrid RANS LES
