Structure and routines handling the specific settings related to a cs_equation_t structure. More...
#include "cs_advection_field.h"#include "cs_param_cdo.h"#include "cs_param_sles.h"#include "cs_hodge.h"#include "cs_property.h"#include "cs_xdef.h"
Include dependency graph for cs_equation_param.h:Go to the source code of this file.
| struct | cs_equation_param_t |
| Set of parameters to handle an unsteady convection-diffusion-reaction equation with term sources. More... | |
Macros | |
Flags specifying which term is needed for an equation. | |
| #define | CS_EQUATION_LOCKED (1 << 0) /* 1 */ |
| Parameters for setting an equation are not modifiable anymore. More... | |
| #define | CS_EQUATION_UNSTEADY (1 << 1) /* 2 */ |
| Unsteady term is needed. More... | |
| #define | CS_EQUATION_CONVECTION (1 << 2) /* 4 */ |
| Convection term is needed. More... | |
| #define | CS_EQUATION_DIFFUSION (1 << 3) /* 8 */ |
| Diffusion term is needed. A scalar-/vector-valued Laplacian with div .grad. More... | |
| #define | CS_EQUATION_CURLCURL (1 << 4) /* 16 */ |
| The term related to the curl-curl operator is needed. More... | |
| #define | CS_EQUATION_GRADDIV (1 << 5) /* 32 */ |
| The term related to the grad-div operator is needed. More... | |
| #define | CS_EQUATION_REACTION (1 << 6) /* 64 */ |
| Reaction term is needed. More... | |
| #define | CS_EQUATION_FORCE_VALUES (1 << 7) /* 128 */ |
| Add an algebraic manipulation to set the value of a given set of interior degrees of freedom. More... | |
| #define | CS_EQUATION_USER_HOOK (1 << 8) /* 256 */ |
| Activate a user hook to get a fine control of the discretization process during the cellwise building of the linear system Need to match the cs_equation_user_hook_t prototype. More... | |
Flags specifying which extra operation is needed for an equation. | |
| #define | CS_EQUATION_POST_BALANCE (1 << 0) /* 1 */ |
| Compute and postprocess the equation balance. More... | |
| #define | CS_EQUATION_POST_PECLET (1 << 1) /* 2 */ |
| Compute and postprocess the Peclet number. More... | |
| #define | CS_EQUATION_POST_UPWIND_COEF (1 << 2) /* 4 */ |
| Postprocess the value of the upwinding coefficient. More... | |
| #define | CS_EQUATION_POST_NORMAL_FLUX (1 << 3) /* 8 */ |
| Postprocess the value of the normal flux across the boundary faces. More... | |
Flags to handle the enforcement of degrees of freedom (DoFs) | |
| #define | CS_EQUATION_ENFORCE_BY_CELLS (1 << 0) /* 1 */ |
| Definition of a selection of DoFs to enforce using a cell selection. More... | |
| #define | CS_EQUATION_ENFORCE_BY_DOFS (1 << 1) /* 2 */ |
| Definition of a selection of DoFs. More... | |
| #define | CS_EQUATION_ENFORCE_BY_REFERENCE_VALUE (1 << 2) /* 4 */ |
| Assign to all the selected DoFs the same value. This value is stored in enforcement_ref_value. More... | |
| cs_equation_param_t * | cs_equation_create_param (const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc) |
| Create a cs_equation_param_t structure. More... | |
| void | cs_equation_copy_param_from (const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fid) |
| Copy the settings from one cs_equation_param_t structure to another one. The name is not copied. More... | |
| void | cs_equation_clear_param (cs_equation_param_t *eqp) |
| Free the contents of a cs_equation_param_t. More... | |
| cs_equation_param_t * | cs_equation_free_param (cs_equation_param_t *eqp) |
| Free a cs_equation_param_t. More... | |
| void | cs_equation_set_param (cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval) |
| Set a parameter attached to a keyname in a cs_equation_param_t structure. More... | |
| void | cs_equation_param_set_sles (cs_equation_param_t *eqp) |
| Set parameters for initializing SLES structures used for the resolution of the linear system. Settings are related to this equation. More... | |
| void | cs_equation_param_last_stage (cs_equation_param_t *eqp) |
| Last modification of the cs_equation_param_t structure before launching the computation. More... | |
| void | cs_equation_param_log (const cs_equation_param_t *eqp) |
| Print the detail of a cs_equation_param_t structure. More... | |
| bool | cs_equation_param_has_robin_bc (const cs_equation_param_t *eqp) |
| Ask if the parameter settings of the equation has requested the treatment of Robin boundary conditions. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_value (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val) |
| Define the initial condition for the unknown related to this equation This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here a constant value is set to all the entities belonging to the given mesh location. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_qov (cs_equation_param_t *eqp, const char *z_name, double quantity) |
| Define the initial condition for the unknown related to this equation This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the value related to all the entities belonging to the given mesh location is such that the integral over these cells returns the requested quantity. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define the initial condition for the unknown related to this equation. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set according to an analytical function. More... | |
| void | cs_equation_add_xdef_bc (cs_equation_param_t *eqp, cs_xdef_t *xdef) |
| Set a boundary condition from an existing cs_xdef_t structure The lifecycle of the cs_xdef_t structure is now managed by the current cs_equation_param_t structure. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_value (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_real_t *values) |
| Define and initialize a new structure to set a boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_array (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, cs_lnum_t *index) |
| cs_xdef_t * | cs_equation_add_bc_by_analytic (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define and initialize a new structure to set a boundary condition related to the given equation param structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_dof_func (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Define and initialize a new structure to set a boundary condition related to the given cs_equation_param_t structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More... | |
| cs_xdef_t * | cs_equation_find_bc (cs_equation_param_t *eqp, const char *z_name) |
| Return pointer to existing boundary condition definition structure for the given equation param structure and zone. More... | |
| void | cs_equation_remove_bc (cs_equation_param_t *eqp, const char *z_name) |
| Remove boundary condition from the given equation param structure for a given zone. More... | |
| void | cs_equation_add_sliding_condition (cs_equation_param_t *eqp, const char *z_name) |
| Define and initialize a new structure to set a sliding boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More... | |
| void | cs_equation_add_diffusion (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the Laplacian operator for the equation associated to the given cs_equation_param_t structure Laplacian means div-grad (either for vector-valued or scalar-valued equations) More... | |
| void | cs_equation_add_curlcurl (cs_equation_param_t *eqp, cs_property_t *property, int inversion) |
| Associate a new term related to the curl-curl operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_graddiv (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the grad-div operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_time (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the time derivative operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_advection (cs_equation_param_t *eqp, cs_adv_field_t *adv_field) |
| Associate a new term related to the advection operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_advection_scaling_property (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a scaling property to the advection. More... | |
| int | cs_equation_add_reaction (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the reaction operator for the equation associated to the given cs_equation_param_t structure. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_val (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a constant value. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an analytical function. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a DoF function. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_array (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, cs_lnum_t *index) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an array. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_value (cs_equation_param_t *eqp, const char *z_name, double *val) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant value. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_qov (cs_equation_param_t *eqp, const char *z_name, double *quantity) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant quantity distributed over the associated zone's volume. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using an analytical function. More... | |
| void | cs_equation_enforce_vertex_dofs (cs_equation_param_t *eqp, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_value[], const cs_real_t elt_values[]) |
| Add an enforcement of the value of degrees of freedom located at mesh vertices. The spatial discretization scheme for the given equation has to be CDO-Vertex based or CDO-Vertex+Cell-based schemes. More... | |
| void | cs_equation_enforce_value_on_cell_selection (cs_equation_param_t *eqp, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_value[], const cs_real_t elt_values[]) |
| Add an enforcement of the value related to the degrees of freedom associated to the list of selected cells. More... | |
| #define CS_EQUATION_CONVECTION (1 << 2) /* 4 */ |
| #define CS_EQUATION_CURLCURL (1 << 4) /* 16 */ |
| #define CS_EQUATION_DIFFUSION (1 << 3) /* 8 */ |
| #define CS_EQUATION_ENFORCE_BY_CELLS (1 << 0) /* 1 */ |
| #define CS_EQUATION_ENFORCE_BY_DOFS (1 << 1) /* 2 */ |
| #define CS_EQUATION_ENFORCE_BY_REFERENCE_VALUE (1 << 2) /* 4 */ |
| #define CS_EQUATION_FORCE_VALUES (1 << 7) /* 128 */ |
| #define CS_EQUATION_GRADDIV (1 << 5) /* 32 */ |
| #define CS_EQUATION_LOCKED (1 << 0) /* 1 */ |
| #define CS_EQUATION_POST_BALANCE (1 << 0) /* 1 */ |
| #define CS_EQUATION_POST_NORMAL_FLUX (1 << 3) /* 8 */ |
| #define CS_EQUATION_POST_PECLET (1 << 1) /* 2 */ |
| #define CS_EQUATION_POST_UPWIND_COEF (1 << 2) /* 4 */ |
| #define CS_EQUATION_REACTION (1 << 6) /* 64 */ |
| #define CS_EQUATION_UNSTEADY (1 << 1) /* 2 */ |
| #define CS_EQUATION_USER_HOOK (1 << 8) /* 256 */ |
| enum cs_equation_key_t |
List of available keys for setting the parameters of an equation.
| Enumerator | |
| CS_EQKEY_ADV_EXTRAPOL | Choice in the way to extrapolate the advection field when building the advection operator
| CS_EQKEY_ADV_FORMULATION | Kind of formulation of the advective term. Available choices are:
| CS_EQKEY_ADV_SCHEME | Type of numerical scheme for the advective term. The available choices depend on the space discretization scheme.
| CS_EQKEY_ADV_STRATEGY | Strategy used to handle the advection term
| CS_EQKEY_ADV_UPWIND_PORTION | Value between 0 and 1 specifying the portion of upwind added to a centered discretization. |
| CS_EQKEY_AMG_TYPE | Specify which type of algebraic multigrid (AMG) to choose. Available choices are:
| CS_EQKEY_BC_ENFORCEMENT | Set the type of enforcement of the boundary conditions. Available choices are:
For HHO and CDO-Face based schemes, only the "penalization" and "algebraic" technique is available up to now. |
| CS_EQKEY_BC_QUADRATURE | Set the quadrature algorithm used for evaluating integral quantities on faces or volumes. Available choices are:
Remark: "higher" and "highest" implies automatically a subdivision into tetrahedra of each cell. |
| CS_EQKEY_BC_STRONG_PENA_COEFF | Set the value of the penalization coefficient when "penalization" is activated The default value is 1e12. cf. CS_PARAM_BC_ENFORCE_PENALIZED |
| CS_EQKEY_BC_WEAK_PENA_COEFF | Set the value of the penalization coefficient when "weak" or "weak_sym" is activated. The default value is 100. cf. CS_PARAM_BC_ENFORCE_WEAK_NITSCHE or CS_PARAM_BC_ENFORCE_WEAK_SYM |
| CS_EQKEY_DO_LUMPING | |
| CS_EQKEY_DOF_REDUCTION | Set how is defined each degree of freedom (DoF).
| CS_EQKEY_EXTRA_OP | Set the additional post-processing to perform. Available choices are:
| CS_EQKEY_HODGE_DIFF_ALGO | Set the algorithm used for building the discrete Hodge operator used in the diffusion term. Available choices are:
| CS_EQKEY_HODGE_DIFF_COEF | This key is only useful if CS_EQKEY_HODGE_{TIME, DIFF, REAC}_ALGO is set to "cost". keyval is either a name or a value:
| CS_EQKEY_HODGE_TIME_ALGO | Set the algorithm used for building the discrete Hodge operator used in the unsteady term. Available choices are:
| CS_EQKEY_HODGE_REAC_ALGO | Set the algorithm used for building the discrete Hodge operator used in the reaction term. Available choices are:
| CS_EQKEY_ITSOL | Specify the iterative solver for solving the linear system related to an equation. Avalaible choices are:
| CS_EQKEY_ITSOL_EPS | Tolerance factor for stopping the iterative processus for solving the linear system related to an equation
| CS_EQKEY_ITSOL_MAX_ITER | Maximum number of iterations for solving the linear system
| CS_EQKEY_ITSOL_RESNORM_TYPE | Normalized or not the residual before testing if one continues iterating for solving the linear system. This normalization is performed before applying the boundary conditions to avoid handling the penalization of Dirichlet boundary conditions. If the RHS norm is equal to zero, then the "vol_tot" option is used for rescaling the residual. Available choices are: "false" or "none" (default) "rhs" "weighted_rhs" or "weighted" "filtered_rhs" or "fieltered_rhs" |
| CS_EQKEY_OMP_ASSEMBLY_STRATEGY | Choice of the way to perform the assembly when OpenMP is active Available choices are:
| CS_EQKEY_PRECOND | Specify the preconditioner associated to an iterative solver. Available choices are:
| CS_EQKEY_SLES_VERBOSITY | Level of details written by the code for the resolution of the linear system
| CS_EQKEY_SOLVER_FAMILY | |
| CS_EQKEY_SPACE_SCHEME | Set the space discretization scheme. Available choices are:
| CS_EQKEY_TIME_SCHEME | Set the scheme for the temporal discretization. Available choices are:
| CS_EQKEY_TIME_THETA | Set a value betwwen 0 and 1 for the theta parameter when a "theta_scheme" is set for the time discretization. Only useful if CS_EQKEY_TIME_SCHEME is set to "theta_scheme".
| CS_EQKEY_VERBOSITY | Set the level of details written by the code for an equation. The higher the more detailed information is displayed.
| CS_EQKEY_N_KEYS | |
| enum cs_equation_type_t |
Type of equations managed by the solver.
| void cs_equation_add_advection | ( | cs_equation_param_t * | eqp, |
| cs_adv_field_t * | adv_field | ||
| [in,out] | eqp | pointer to a cs_equation_param_t structure |
| [in] | adv_field | pointer to a cs_adv_field_t structure |
| void cs_equation_add_advection_scaling_property | ( | cs_equation_param_t * | eqp, |
| cs_property_t * | property | ||
| [in] | property | pointer to a cs_property_t structure |
| cs_xdef_t* cs_equation_add_bc_by_analytic | ( | cs_equation_param_t * | eqp, |
| const cs_param_bc_type_t | bc_type, | ||
| const char * | z_name, | ||
| cs_analytic_func_t * | analytic, | ||
| void * | input | ||
| [in] | bc_type | type of boundary condition to add |
| [in] | z_name | name of the associated zone (if NULL or "" if all cells are considered) |
| [in] | analytic | pointer to an analytic function defining the value |
| cs_xdef_t* cs_equation_add_bc_by_array | ( | cs_equation_param_t * | eqp, |
| cs_flag_t | loc, | ||
| cs_real_t * | array, | ||
| bool | is_owner, | ||
| cs_lnum_t * | index | ||
| [in] | z_name | name of the related boundary zone |
| [in] | is_owner | transfer the lifecycle to the cs_xdef_t structure (true or false) |
| [in] | index | optional pointer to the array index |
| cs_xdef_t* cs_equation_add_bc_by_dof_func | ( | cs_equation_param_t * | eqp, |
| cs_flag_t | loc_flag, | ||
| void * | input | ||
| [in] | loc_flag | location where values are computed |
| [in] | func | pointer to cs_dof_func_t function |
| cs_xdef_t* cs_equation_add_bc_by_value | ( | cs_equation_param_t * | eqp, |
| cs_real_t * | values | ||
| [in] | values | pointer to a array storing the values |
| void cs_equation_add_curlcurl | ( | cs_equation_param_t * | eqp, |
| cs_property_t * | property, | ||
| int | inversion | ||
| [in] | inversion | 1: true, false otherwise |
| [in] | inversion | > 0: true, false otherwise |
| void cs_equation_add_diffusion | ( | cs_equation_param_t * | eqp, |
| void cs_equation_add_graddiv | ( | cs_equation_param_t * | eqp, |
| cs_xdef_t* cs_equation_add_ic_by_analytic | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | analytic | pointer to an analytic function |
| cs_xdef_t* cs_equation_add_ic_by_qov | ( | cs_equation_param_t * | eqp, |
| double | quantity | ||
| [in] | z_name | name of the associated zone (if NULL or "" all cells are considered) |
| [in] | quantity | quantity to distribute over the mesh location |
| cs_xdef_t* cs_equation_add_ic_by_value | ( | cs_equation_param_t * | eqp, |
| cs_real_t * | val | ||
| [in] | val | pointer to the value |
| int cs_equation_add_reaction | ( | cs_equation_param_t * | eqp, |
| void cs_equation_add_sliding_condition | ( | cs_equation_param_t * | eqp, |
| const char * | z_name | ||
| cs_xdef_t* cs_equation_add_source_term_by_analytic | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | func | pointer to an analytical function |
| cs_xdef_t* cs_equation_add_source_term_by_array | ( | cs_equation_param_t * | eqp, |
| cs_xdef_t* cs_equation_add_source_term_by_dof_func | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | loc_flag | location of element ids given as parameter |
| [in] | func | pointer to a DoF function |
| cs_xdef_t* cs_equation_add_source_term_by_val | ( | cs_equation_param_t * | eqp, |
| void cs_equation_add_time | ( | cs_equation_param_t * | eqp, |
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_analytic | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_qov | ( | cs_equation_param_t * | eqp, |
| double * | quantity | ||
| [in] | quantity | pointer to quantity to distribute over the zone |
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_value | ( | cs_equation_param_t * | eqp, |
| double * | val | ||
| void cs_equation_add_xdef_bc | ( | cs_equation_param_t * | eqp, |
| cs_xdef_t * | xdef | ||
| [in] | xdef | pointer to the cs_xdef_t structure to transfer |
| void cs_equation_clear_param | ( | cs_equation_param_t * | eqp | ) |
The cs_equation_param_t structure itself is not freed, but all its sub-structures are freed.
This is useful for equation parameters which are accessed through field keywords.
| [in,out] | eqp | pointer to a cs_equation_param_t |
| void cs_equation_copy_param_from | ( | const cs_equation_param_t * | ref, |
| cs_equation_param_t * | dst, | ||
| bool | copy_fid | ||
| [in] | ref | pointer to the reference cs_equation_param_t |
| [in,out] | dst | pointer to the cs_equation_param_t to update |
| [in] | copy_fid | copy also the field id or not |
| cs_equation_param_t* cs_equation_create_param | ( | const char * | name, |
| cs_equation_type_t | type, | ||
| int | dim, | ||
| cs_param_bc_type_t | default_bc | ||
| [in] | name | name of the equation |
| [in] | type | type of equation |
| [in] | dim | dim of the variable associated to this equation |
| [in] | default_bc | type of boundary condition set by default |
| void cs_equation_enforce_value_on_cell_selection | ( | cs_equation_param_t * | eqp, |
| cs_lnum_t | n_elts, | ||
| const cs_lnum_t | elt_ids[], | ||
| const cs_real_t | ref_value[], | ||
| const cs_real_t | elt_values[] | ||
One assumes that values are interlaced if eqp->dim > 1 ref_value or elt_values has to be defined. If both parameters are defined, one keeps the definition in elt_values
| [in] | n_elts | number of selected cells |
| [in] | elt_ids | list of cell ids |
| [in] | ref_value | ignored if NULL |
| [in] | elt_values | list of associated values, ignored if NULL |
| void cs_equation_enforce_vertex_dofs | ( | cs_equation_param_t * | eqp, |
| [in] | n_elts | number of vertices to enforce |
| [in] | elt_ids | list of vertices |
| cs_xdef_t* cs_equation_find_bc | ( | cs_equation_param_t * | eqp, |
| cs_equation_param_t* cs_equation_free_param | ( | cs_equation_param_t * | eqp | ) |
| [in] | eqp | pointer to a cs_equation_param_t |
| bool cs_equation_param_has_robin_bc | ( | const cs_equation_param_t * | eqp | ) |
| void cs_equation_param_last_stage | ( | cs_equation_param_t * | eqp | ) |
| void cs_equation_param_log | ( | const cs_equation_param_t * | eqp | ) |
| void cs_equation_param_set_sles | ( | cs_equation_param_t * | eqp | ) |
| void cs_equation_remove_bc | ( | cs_equation_param_t * | eqp, |
If no matching boundary condition is found, the function returns silently.
| void cs_equation_set_param | ( | cs_equation_param_t * | eqp, |
| cs_equation_key_t | key, | ||
| const char * | keyval | ||
