348 cs_get_vol_zone_id(
const char *z_name)
351 if (z_name != NULL) {
352 if (strlen(z_name) > 0) {
372 cs_get_bdy_zone_id(
const char *z_name)
375 if (z_name != NULL) {
376 if (strlen(z_name) > 0) {
400 assert(def->
dim == 1);
void cs_xdef_set_array_index(cs_xdef_t *d, cs_lnum_t *array_index)
In case of definition by array, set the index to get access to the array values.
Definition: cs_xdef.c:768
cs_xdef_t * cs_xdef_boundary_create(cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context)
Allocate and initialize a new cs_xdef_t structure based on boundary elements.
Definition: cs_xdef.c:273
cs_analytic_func_t * func
Definition: cs_xdef.h:256
cs_xdef_t * cs_xdef_timestep_create(cs_xdef_type_t type, cs_flag_t state, cs_flag_t meta, void *context)
Allocate and initialize a new cs_xdef_t structure for setting the time step.
Definition: cs_xdef.c:419
cs_quadrature_type_t cs_xdef_get_quadrature(cs_xdef_t *d)
Get the type of quadrature to use for evaluating the given description.
Definition: cs_xdef.c:816
cs_time_func_t * func
Definition: cs_xdef.h:317
cs_xdef_t * cs_xdef_free(cs_xdef_t *d)
Free a cs_xdef_t structure.
Definition: cs_xdef.c:486
void cs_xdef_set_input_context(cs_xdef_t *d, void *input)
In the case of a definition by an analytic function, a time function or a function relying on degrees...
Definition: cs_xdef.c:622
Definition: cs_xdef.h:118
Definition: cs_boundary_zone.c:726
int id
Definition: cs_zone.h:59
Definition: cs_xdef.h:140
cs_real_t * values
Definition: cs_xdef.h:235
Definition: cs_defs.h:495
Definition: cs_xdef.h:113
Context structure when a time step function is used for the definition.
Definition: cs_xdef.h:312
cs_xdef_free_input_t * free_input
Definition: cs_xdef.h:303
void cs_xdef_log(const char *prefix, const cs_xdef_t *d)
Output the settings related to a cs_xdef_t structure.
Definition: cs_xdef.c:872
const cs_zone_t * cs_volume_zone_by_name(const char *name)
Return a pointer to a volume zone based on its name if present.
Definition: cs_volume_zone.c:695
void * context
Definition: cs_xdef.h:198
cs_flag_t state
Definition: cs_xdef.h:193
Definition: cs_xdef.h:111
cs_xdef_type_t cs_xdef_get_type(const cs_xdef_t *d)
Retrieve the flag dedicated to the state.
Definition: cs_xdef.c:835
Definition: cs_xdef.h:142
Definition: cs_xdef.h:116
cs_xdef_t * cs_xdef_copy(cs_xdef_t *src)
copy a cs_xdef_t structure
Definition: cs_xdef.c:561
void cs_xdef_set_array(cs_xdef_t *d, bool is_owner, cs_real_t *array)
In case of definition by array, set the array after having added this definition. ...
Definition: cs_xdef.c:734
Definition: cs_xdef.h:328
int z_id
Definition: cs_xdef.h:281
cs_flag_t cs_xdef_get_state_flag(const cs_xdef_t *d)
Definition: cs_xdef.c:854
Definition: cs_defs.h:307
int dim
Definition: cs_xdef.h:188
cs_xdef_type_t type
Definition: cs_xdef.h:189
void * input
Definition: cs_xdef.h:298
Context structure when a definition by analytic function is used.
Definition: cs_xdef.h:246
Definition: cs_xdef.h:115
cs_xdef_support_t
Definition: cs_xdef.h:138
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:119
int z_id
Definition: cs_xdef.h:232
Definition: cs_quadrature.h:52
void cs_xdef_set_quadrature(cs_xdef_t *d, cs_quadrature_type_t qtype)
Set the type of quadrature to use for evaluating the given description.
Definition: cs_xdef.c:795
cs_flag_t loc
Definition: cs_xdef.h:234
Context structure when a definition by DoF function is used.
Definition: cs_xdef.h:276
Generic function pointer for an evaluation relying on an analytic function elt_ids is optional...
Definition: cs_param_types.h:94
cs_dof_func_t * func
Definition: cs_xdef.h:292
Definition: cs_xdef.h:196
cs_xdef_type_t
Definition: cs_xdef.h:108
Definition: cs_xdef.h:110
int z_id
Definition: cs_xdef.h:251
Definition: cs_xdef.h:117
void * input
Definition: cs_xdef.h:262
int stride
Definition: cs_xdef.h:233
Definition: cs_xdef.h:154
void cs_xdef_set_free_input_function(cs_xdef_t *d, cs_xdef_free_input_t *free_input)
In case of a definition by an analytic function, a time function or a function relying on degrees of ...
Definition: cs_xdef.c:679
Definition: cs_xdef.h:144
Definition: cs_defs.h:301
cs_xdef_support_t support
Definition: cs_xdef.h:191
Definition: cs_xdef.h:114
Definition: cs_defs.h:496
unsigned short int cs_flag_t
Definition: cs_defs.h:309
void() cs_time_func_t(double time, void *input, cs_real_t *retval)
Function which defines the evolution of a quantity according to the current time and any structure gi...
Definition: cs_param_types.h:137
Definition: cs_xdef.h:267
bool is_owner
Definition: cs_xdef.h:237
cs_flag_t meta
Definition: cs_xdef.h:194
Definition: cs_xdef.h:112
cs_lnum_t * index
Definition: cs_xdef.h:236
int z_id
Definition: cs_xdef.h:190
void * input
Definition: cs_xdef.h:323
Context structure when an array is used for the definition.
Definition: cs_xdef.h:207
const char * cs_xdef_type_get_name(cs_xdef_type_t xdef_type)
Retrieve a pointer to the cs_xdef_type's name string.
Definition: cs_xdef.c:1012
Definition: cs_xdef.h:120
Definition: cs_xdef.h:141
cs_xdef_t * cs_xdef_volume_create(cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context)
Allocate and initialize a new cs_xdef_t structure based on volumic elements.
Definition: cs_xdef.c:104
void *() cs_xdef_free_input_t(void *input)
Destroy an input data structure. Complex data structure can be used when a cs_xdef_t structure is def...
Definition: cs_xdef.h:70
cs_flag_t loc
Definition: cs_xdef.h:287
