243 if (fabs(h1_info.
coef - h2_info.
coef) > 0)
void cs_hodge_epfd_cost_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal edges to dua...
Definition: cs_hodge.c:3244
void cs_hodge_edfp_cost_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. Hodge op. from dual edges to prima...
Definition: cs_hodge.c:3694
Definition: cs_hodge.h:86
void cs_hodge_edfp_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from dual edges to primal...
Definition: cs_hodge.c:3634
void cs_hodge_compute_wbs_surfacic(const cs_face_mesh_t *fm, cs_sdm_t *hf)
Compute the hodge operator related to a face (i.e. a mass matrix with unity property) using a Whitney...
Definition: cs_hodge.c:4229
bool inv_pty
Definition: cs_hodge.h:168
Definition: cs_hodge.h:83
void cs_hodge_vb_cost_get_iso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc ...
Definition: cs_hodge.c:1932
cs_hodge_type_t type
Definition: cs_hodge.h:170
void cs_hodge_fb_voro_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc a...
Definition: cs_hodge.c:1873
cs_hodge_compute_t * cs_hodge_get_func(const char *calling_func, const cs_hodge_param_t hp)
Retrieve a function pointer to compute a discrete Hodge operator.
Definition: cs_hodge.c:1390
Structure storing the evaluation of a property and its related data.
Definition: cs_property.h:178
void cs_hodge_vpcd_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal vertices to d...
Definition: cs_hodge.c:3126
Definition: cs_defs.h:495
void cs_hodge_fped_cost_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal faces to dua...
Definition: cs_hodge.c:3494
void cs_hodge_edfp_cost_get_opt(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:3765
void cs_hodge_free(cs_hodge_t **p_hodge)
Free a cs_hodge_t structure.
Definition: cs_hodge.c:1332
Definition: cs_hodge.h:89
void cs_hodge_vb_cost_get_aniso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:1986
Set of local quantities and connectivities related to a mesh cell This is a key structure for all cel...
Definition: cs_cdo_local.h:159
void cs_hodge_set_property_value_cw(const cs_cell_mesh_t *cm, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge)
Set the property value (scalar- or tensor-valued) related to a discrete Hodge operator inside a cell ...
Definition: cs_hodge.c:1672
void cs_hodge_vb_bubble_get_iso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic Bubble algo. The computed matrix is stored in cb->lo...
Definition: cs_hodge.c:2040
void cs_hodge_vb_voro_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2397
cs_hodge_t ** cs_hodge_init_context(const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen)
Create and initialize an array of pointers to a cs_hodge_t structures. This array is of size the numb...
Definition: cs_hodge.c:1293
Definition: cs_hodge.h:137
Structure associated to a discrete Hodge operator.
Definition: cs_hodge.h:189
void cs_hodge_fped_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal faces to dual...
Definition: cs_hodge.c:3434
Definition: cs_defs.h:307
void cs_hodge_edfp_bubble_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from dual edges to pri...
Definition: cs_hodge.c:3833
void cs_hodge_fped_bubble_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from primal faces to d...
Definition: cs_hodge.c:3566
void() cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a discrete Hodge operator or a related operator (such as the stiffmess matrix) for a given cell...
Definition: cs_hodge.h:213
void cs_hodge_vpcd_wbs_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using WBS algo. Hodge op. from primal vertices to dual ...
Definition: cs_hodge.c:3009
void cs_hodge_vcb_wbs_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the WBS algo. This function is specific for verte...
Definition: cs_hodge.c:2885
double coef
Definition: cs_hodge.h:172
void cs_hodge_vb_ocs2_get_aniso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the Orthogonal Consistent/Sub-Stabilization decomposition (OCS2)...
Definition: cs_hodge.c:2150
Definition: cs_field_pointer.h:134
void cs_hodge_free_context(cs_hodge_t ***p_hodges)
Free a set of cs_hodge_t structures.
Definition: cs_hodge.c:1357
Definition: cs_hodge.h:130
Definition: cs_hodge.h:91
void cs_hodge_vcb_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the Voronoi algo. This leads to a diagonal operat...
Definition: cs_hodge.c:2819
void cs_hodge_epfd_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal edges to dual...
Definition: cs_hodge.c:3179
void cs_hodge_fb_cost_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:1750
void cs_hodge_fb_bubble_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic COST algo. with the usage of bubble stabilization...
Definition: cs_hodge.c:1812
void cs_hodge_vb_wbs_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic WBS algo. WBS standing for Whitney Barycentric Subdi...
Definition: cs_hodge.c:2488
cs_hodge_type_t
Type of discrete Hodge operators.
Definition: cs_hodge.h:81
Definition: cs_hodge.h:131
void cs_hodge_set_property_value(const cs_lnum_t c_id, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge)
Definition: cs_hodge.c:1591
void cs_hodge_vcb_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2608
cs_hodge_algo_t
Type of algorithm to build a discrete Hodge operator.
Definition: cs_hodge.h:128
Set of local and temporary buffers useful for building the algebraic system with a cellwise process...
Definition: cs_cdo_local.h:69
void cs_hodge_epfd_bubble_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. with a bubble stabilization. The discrete Hodge operator is stored in hodge->matrix Hodge op. from primal edges to dual faces. This function is specific for vertex-based schemes.
Definition: cs_hodge.c:3318
Definition: cs_hodge.h:133
Definition: cs_hodge.h:134
cs_hodge_t * cs_hodge_create(const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen)
Create and initialize a pointer to a cs_hodge_t structure.
Definition: cs_hodge.c:1229
Definition: cs_defs.h:301
void cs_hodge_epfd_ocs2_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the Orthogonal Consistent/Sub-Stabilization decom...
Definition: cs_hodge.c:3386
void cs_hodge_vb_cost_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2194
const cs_hodge_param_t * param
Definition: cs_hodge.h:192
void cs_hodge_circulation_from_flux(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t flux[], cs_real_t circul[])
Compute cellwise a discrete hodge operator in order to define a circulation array from a flux array...
Definition: cs_hodge.c:4123
cs_property_data_t * pty_data
Definition: cs_hodge.h:194
cs_sdm_t * matrix
Definition: cs_hodge.h:195
Definition: cs_defs.h:496
Definition: cs_hodge.h:135
unsigned short int cs_flag_t
Definition: cs_defs.h:309
Definition: cs_hodge.h:88
Definition: cs_hodge.h:132
void cs_hodge_matvec(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t in_vals[], cs_real_t t_eval, cs_real_t result[])
Compute cellwise a discrete hodge operator and multiple it with a vector.
Definition: cs_hodge.c:3903
void cs_hodge_fb_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator on a given cell which is equivalent of a mass matrix. It relies on a CO+ST algo. and is specific to CDO-Fb schemes. The discrete Hodge operator is stored in hodge->matrix.
Definition: cs_hodge.c:2742
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:227
cs_hodge_algo_t algo
Definition: cs_hodge.h:171
Definition: cs_hodge.h:85
Definition: cs_hodge.h:84
void cs_hodge_param_log(const char *prefix, const cs_property_t *property, const cs_hodge_param_t hp)
Output the settings related to a cs_hodge_param_t structure.
Definition: cs_hodge.c:1526
Structure storing all metadata/parameters related to the usage of a discrete Hodge operator...
Definition: cs_hodge.h:165
void cs_hodge_copy_parameters(const cs_hodge_param_t *h_ref, cs_hodge_param_t *h_cpy)
Copy the set of parameters associated to a discrete Hodge operator to another one.
Definition: cs_hodge.c:1565
Definition: cs_hodge.h:87
void cs_hodge_vb_bubble_get_aniso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2094
