cs_cdo_local.h File Reference
#include "cs_cdo_connect.h"
#include "cs_flag.h"
#include "cs_param_cdo.h"
#include "cs_sdm.h"
+ Include dependency graph for cs_cdo_local.h:
Data Structures
struct  cs_cell_builder_t
 Set of local and temporary buffers useful for building the algebraic system with a cellwise process. This structure belongs to one thread. More...
struct  cs_cell_sys_t
 Set of arrays and local (small) dense matrices related to a mesh cell This is a key structure for building the local algebraic system. This structure belongs to one thread and only. More...
struct  cs_cell_mesh_t
 Set of local quantities and connectivities related to a mesh cell This is a key structure for all cellwise processes. This structure belongs to one thread and only. This structure used allows one to get a better memory locality. It maps the existing global mesh and other related structures into a more compact one dedicated to a cell. Arrays are allocated to the max number of related entities (e.g. n_max_vbyc or to n_max_ebyc). The cell-wise numbering is based on the c2v, c2e and c2f connectivity. More...
struct  cs_face_mesh_t
 Set of local quantities and connectivities related to a mesh face Structure used to get a better memory locality. Map existing structure into a more compact one dedicated to a face. Arrays are allocated to n_max_vbyf (= n_max_ebyf). Face-wise numbering is based on the f2e connectivity. More...
struct  cs_face_mesh_light_t
void cs_cdo_local_initialize (const cs_cdo_connect_t *connect)
 Allocate global structures used for build system with a cellwise or facewise process. More...
void cs_cdo_local_finalize (void)
 Free global structures related to cs_cell_mesh_t and cs_face_mesh_t structures. More...
cs_cell_sys_tcs_cell_sys_create (int n_max_dofbyc, int n_max_fbyc, int n_blocks, int *block_sizes)
 Allocate a cs_cell_sys_t structure. More...
void cs_cell_sys_reset (int n_fbyc, cs_cell_sys_t *csys)
 Reset all members related to BC and some other ones in a cs_cell_sys_t structure. More...
void cs_cell_sys_free (cs_cell_sys_t **p_csys)
 Free a cs_cell_sys_t structure. More...
void cs_cell_sys_dump (const char msg[], const cs_cell_sys_t *csys)
 Dump a local system for debugging purpose. More...
cs_cell_builder_tcs_cell_builder_create (void)
 Allocate cs_cell_builder_t structure. More...
void cs_cell_builder_free (cs_cell_builder_t **p_cb)
 Free a cs_cell_builder_t structure. More...
cs_cell_mesh_tcs_cell_mesh_create (const cs_cdo_connect_t *connect)
 Allocate and initialize a cs_cell_mesh_t structure. More...
cs_cell_mesh_tcs_cdo_local_get_cell_mesh (int mesh_id)
 Get a pointer to a cs_cell_mesh_t structure corresponding to mesh id. More...
void cs_cell_mesh_reset (cs_cell_mesh_t *cm)
 Initialize to invalid values a cs_cell_mesh_t structure. More...
void cs_cell_mesh_dump (const cs_cell_mesh_t *cm)
 Dump a cs_cell_mesh_t structure. More...
void cs_cell_mesh_free (cs_cell_mesh_t **p_cm)
 Free a cs_cell_mesh_t structure. More...
void cs_cell_mesh_build (cs_lnum_t c_id, cs_eflag_t build_flag, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_cell_mesh_t *cm)
 Define a cs_cell_mesh_t structure for a given cell id. According to the requested level, some quantities may not be defined;. More...
cs_face_mesh_tcs_face_mesh_create (short int n_max_vbyf)
 Allocate a cs_face_mesh_t structure. More...
cs_face_mesh_tcs_cdo_local_get_face_mesh (int mesh_id)
 Get a pointer to a cs_face_mesh_t structure corresponding to mesh id. More...
void cs_face_mesh_free (cs_face_mesh_t **p_fm)
 Free a cs_face_mesh_t structure. More...
void cs_face_mesh_build (cs_lnum_t c_id, cs_lnum_t f_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_face_mesh_t *fm)
 Define a cs_face_mesh_t structure for a given face/cell id. More...
void cs_face_mesh_build_from_cell_mesh (const cs_cell_mesh_t *cm, short int f, cs_face_mesh_t *fm)
 Define a cs_face_mesh_t structure for a given cell from a cs_cell_mesh_t structure. v_ids and e_ids are defined in the cell numbering given by cm. More...
cs_face_mesh_light_tcs_face_mesh_light_create (short int n_max_vbyf, short int n_max_vbyc)
 Allocate a cs_face_mesh_light_t structure. More...
cs_face_mesh_light_tcs_cdo_local_get_face_mesh_light (int mesh_id)
 Get a pointer to a cs_face_mesh_light_t structure corresponding to mesh id. More...
void cs_face_mesh_light_free (cs_face_mesh_light_t **p_fm)
 Free a cs_face_mesh_light_t structure. More...
void cs_face_mesh_light_build (const cs_cell_mesh_t *cm, short int f, cs_face_mesh_light_t *fm)
 Define a cs_face_mesh_light_t structure starting from a cs_cell_mesh_t structure. More...
int cs_cdo_local_d_buffer_size
double ** cs_cdo_local_d_buffer
cs_cell_mesh_t ** cs_cdo_local_cell_meshes
cs_face_mesh_t ** cs_cdo_local_face_meshes
cs_face_mesh_light_t ** cs_cdo_local_face_meshes_light
◆ cs_cdo_local_finalize()
void cs_cdo_local_finalize ( void  )
◆ cs_cdo_local_get_cell_mesh()
cs_cell_mesh_t* cs_cdo_local_get_cell_mesh ( int  mesh_id)
[in]mesh_idid in the array of pointer to cs_cell_mesh_t struct.
◆ cs_cdo_local_get_face_mesh()
cs_face_mesh_t* cs_cdo_local_get_face_mesh ( int  mesh_id)
[in]mesh_idid in the array of pointer to cs_face_mesh_t struct.
◆ cs_cdo_local_get_face_mesh_light()
cs_face_mesh_light_t* cs_cdo_local_get_face_mesh_light ( int  mesh_id)
[in]mesh_idid in the cs_face_mesh_light_t array
◆ cs_cdo_local_initialize()
void cs_cdo_local_initialize ( const cs_cdo_connect_t connect)
◆ cs_cell_builder_create()
cs_cell_builder_t* cs_cell_builder_create ( void  )
a pointer to the new allocated cs_cell_builder_t structure
◆ cs_cell_builder_free()
void cs_cell_builder_free ( cs_cell_builder_t **  p_cb)
[in,out]p_cbpointer of pointer to a cs_cell_builder_t struct
◆ cs_cell_mesh_build()
void cs_cell_mesh_build ( cs_lnum_t  c_id,
cs_cell_mesh_t cm
[in]c_idcell id
[in]build_flagindicate which members are really built
[in,out]cmpointer to a cs_cell_mesh_t structure to set
◆ cs_cell_mesh_create()
cs_cell_mesh_t* cs_cell_mesh_create ( const cs_cdo_connect_t connect)
a pointer to a new allocated cs_cell_mesh_t structure
◆ cs_cell_mesh_dump()
void cs_cell_mesh_dump ( const cs_cell_mesh_t cm)
◆ cs_cell_mesh_free()
void cs_cell_mesh_free ( cs_cell_mesh_t **  p_cm)
[in,out]p_cmpointer of pointer to a cs_cell_mesh_t structure
◆ cs_cell_mesh_reset()
void cs_cell_mesh_reset ( cs_cell_mesh_t cm)
◆ cs_cell_sys_create()
cs_cell_sys_t* cs_cell_sys_create ( int  n_max_dofbyc,
int  n_max_fbyc,
int  n_blocks,
int *  block_sizes
[in]n_max_dofbycmax number of entries
[in]n_max_fbycmax number of faces in a cell
[in]n_blocksnumber of blocks in a row/column
[in]block_sizessize of each block or NULL if n_blocks = 1 Specific treatment n_blocks = 1.
a pointer to a new allocated cs_cell_sys_t structure
[in]block_sizessize of each block or NULL. Specific treatment n_blocks = 1.
◆ cs_cell_sys_dump()
void cs_cell_sys_dump ( const char  msg[],
const cs_cell_sys_t csys
[in]msgassociated message to print
[in]csyspointer to a cs_cell_sys_t structure
◆ cs_cell_sys_free()
void cs_cell_sys_free ( cs_cell_sys_t **  p_csys)
[in,out]p_csyspointer of pointer to a cs_cell_sys_t struct.
◆ cs_cell_sys_reset()
void cs_cell_sys_reset ( int  n_fbyc,
cs_cell_sys_t csys
[in]n_fbycnumber of faces in a cell
[in,out]csyspointer to the cs_cell_sys_t struct to reset
◆ cs_face_mesh_build()
void cs_face_mesh_build ( cs_lnum_t  c_id,
cs_lnum_t  f_id,
cs_face_mesh_t fm
[in]c_idcell id
[in]f_idface id in the mesh structure
[in,out]fmpointer to a cs_face_mesh_t structure to set
◆ cs_face_mesh_build_from_cell_mesh()
void cs_face_mesh_build_from_cell_mesh ( const cs_cell_mesh_t cm,
short int  f,
cs_face_mesh_t fm
[in]cmpointer to the reference cs_cell_mesh_t structure
[in]fface id in the cs_cell_mesh_t structure
◆ cs_face_mesh_create()
cs_face_mesh_t* cs_face_mesh_create ( short int  n_max_vbyf)
[in]n_max_vbyfmax. number of vertices for a face
a pointer to a new allocated cs_face_mesh_t structure
[in]n_max_vbyfmax. number of vertices fir a face
◆ cs_face_mesh_free()
void cs_face_mesh_free ( cs_face_mesh_t **  p_fm)
[in,out]p_fmpointer of pointer to a cs_face_mesh_t structure
◆ cs_face_mesh_light_build()
void cs_face_mesh_light_build ( const cs_cell_mesh_t cm,
short int  f,
cs_face_mesh_light_t fm
[in,out]fmpointer to a cs_face_mesh_light_t structure to set
◆ cs_face_mesh_light_create()
cs_face_mesh_light_t* cs_face_mesh_light_create ( short int  n_max_vbyf,
[in]n_max_vbycmax. number of vertices for a cell
a pointer to a new allocated cs_face_mesh_light_t structure
◆ cs_face_mesh_light_free()
void cs_face_mesh_light_free ( cs_face_mesh_light_t **  p_fm)
[in,out]p_fmpointer of pointer to a cs_face_mesh_light_t struct.
◆ cs_cdo_local_cell_meshes
cs_cell_mesh_t** cs_cdo_local_cell_meshes
◆ cs_cdo_local_d_buffer
double** cs_cdo_local_d_buffer
◆ cs_cdo_local_d_buffer_size
◆ cs_cdo_local_face_meshes
cs_face_mesh_t** cs_cdo_local_face_meshes
◆ cs_cdo_local_face_meshes_light
cs_face_mesh_light_t** cs_cdo_local_face_meshes_light
