#include "cs_defs.h"#include "cs_halo.h"#include "cs_numbering.h"#include "cs_halo_perio.h"#include "cs_matrix_assembler.h"
Include dependency graph for cs_matrix.h:Go to the source code of this file.
| struct | cs_matrix_row_info_t |
| typedef struct _cs_matrix_structure_t | cs_matrix_structure_t |
| typedef struct _cs_matrix_t | cs_matrix_t |
| typedef struct _cs_matrix_variant_t | cs_matrix_variant_t |
| cs_matrix_structure_t * | cs_matrix_structure_create (cs_matrix_type_t type, bool have_diag, cs_lnum_t n_rows, cs_lnum_t n_cols_ext, cs_lnum_t n_edges, const cs_lnum_2_t *edges, const cs_halo_t *halo, const cs_numbering_t *numbering) |
| Create a matrix structure. More... | |
| cs_matrix_structure_t * | cs_matrix_structure_create_msr (cs_matrix_type_t type, bool transfer, bool have_diag, cs_lnum_t n_rows, cs_lnum_t n_cols_ext, cs_lnum_t **row_index, cs_lnum_t **col_id, const cs_halo_t *halo, const cs_numbering_t *numbering) |
| Create a matrix structure based on a MSR connectivity definition. More... | |
| cs_matrix_structure_t * | cs_matrix_structure_create_msr_shared (bool have_diag, bool direct_assmbly, cs_lnum_t n_rows, cs_lnum_t n_cols_ext, const cs_lnum_t *row_index, const cs_lnum_t *col_id, const cs_halo_t *halo, const cs_numbering_t *numbering) |
| Create an MSR matrix structure sharing an existing connectivity definition. More... | |
| cs_matrix_structure_t * | cs_matrix_structure_create_from_assembler (cs_matrix_type_t type, cs_matrix_assembler_t *ma) |
| Create a matrix structure using a matrix assembler. More... | |
| void | cs_matrix_structure_destroy (cs_matrix_structure_t **ms) |
| Destroy a matrix structure. More... | |
| cs_matrix_t * | cs_matrix_create (const cs_matrix_structure_t *ms) |
| Create a matrix container using a given structure. More... | |
| cs_matrix_t * | cs_matrix_create_from_assembler (cs_matrix_type_t type, cs_matrix_assembler_t *ma) |
| Create a matrix directly from assembler. More... | |
| cs_matrix_t * | cs_matrix_create_by_copy (cs_matrix_t *src) |
| Create a matrix container by copying another. More... | |
| cs_matrix_t * | cs_matrix_create_by_local_restrict (const cs_matrix_t *src) |
| Create a matrix based on the local restriction of a base matrix. More... | |
| void | cs_matrix_destroy (cs_matrix_t **matrix) |
| cs_matrix_type_t | cs_matrix_get_type (const cs_matrix_t *matrix) |
| Return matrix type. More... | |
| cs_lnum_t | cs_matrix_get_n_columns (const cs_matrix_t *matrix) |
| Return number of columns in a matrix. More... | |
| cs_lnum_t | cs_matrix_get_n_rows (const cs_matrix_t *matrix) |
| Return number of rows in matrix. More... | |
| cs_lnum_t | cs_matrix_get_n_entries (const cs_matrix_t *matrix) |
| Return number of entries in matrix. More... | |
| const cs_lnum_t * | cs_matrix_get_diag_block_size (const cs_matrix_t *matrix) |
| Return matrix diagonal block sizes. More... | |
| const cs_lnum_t * | cs_matrix_get_extra_diag_block_size (const cs_matrix_t *matrix) |
| Return matrix extra-diagonal block sizes. More... | |
| const cs_halo_t * | cs_matrix_get_halo (const cs_matrix_t *matrix) |
| Return pointer to matrix halo structure. More... | |
| cs_matrix_fill_type_t | cs_matrix_get_fill_type (bool symmetric, const cs_lnum_t *diag_block_size, const cs_lnum_t *extra_diag_block_size) |
| Get matrix fill type, depending on block sizes. More... | |
| void | cs_matrix_set_coefficients (cs_matrix_t *matrix, bool symmetric, const cs_lnum_t *diag_block_size, const cs_lnum_t *extra_diag_block_size, const cs_lnum_t n_edges, const cs_lnum_2_t edges[], const cs_real_t *da, const cs_real_t *xa) |
| Set matrix coefficients defined relative to a "native" edge graph, sharing arrays with the caller when possible. More... | |
| void | cs_matrix_copy_coefficients (cs_matrix_t *matrix, bool symmetric, const cs_lnum_t *diag_block_size, const cs_lnum_t *extra_diag_block_size, const cs_lnum_t n_edges, const cs_lnum_2_t edges[], const cs_real_t *da, const cs_real_t *xa) |
| Set matrix coefficients, copying values to private arrays. More... | |
| void | cs_matrix_transfer_coefficients_msr (cs_matrix_t *matrix, bool symmetric, const cs_lnum_t *diag_block_size, const cs_lnum_t *extra_diag_block_size, const cs_lnum_t row_index[], const cs_lnum_t col_id[], cs_real_t **d_val, cs_real_t **x_val) |
| Set matrix coefficients in an MSR format, transfering the property of those arrays to the matrix. More... | |
| cs_matrix_assembler_values_t * | cs_matrix_assembler_values_init (cs_matrix_t *matrix, const cs_lnum_t *diag_block_size, const cs_lnum_t *extra_diag_block_size) |
| Create and initialize a CSR matrix assembler values structure. More... | |
| void | cs_matrix_release_coefficients (cs_matrix_t *matrix) |
| Release shared matrix coefficients. More... | |
| void | cs_matrix_copy_diagonal (const cs_matrix_t *matrix, cs_real_t *restrict da) |
| Copy matrix diagonal values. More... | |
| bool | cs_matrix_is_symmetric (const cs_matrix_t *matrix) |
| Query matrix coefficients symmetry. More... | |
| bool | cs_matrix_is_mapped_from_native (const cs_matrix_t *matrix) |
| Indicate whether coefficients were mapped from native face-based arrays. More... | |
| const cs_real_t * | cs_matrix_get_diagonal (const cs_matrix_t *matrix) |
| Get matrix diagonal values. More... | |
| const cs_real_t * | cs_matrix_get_extra_diagonal (const cs_matrix_t *matrix) |
| Get pointer to matrix extra-diagonal values in "native" format. More... | |
| void | cs_matrix_row_init (cs_matrix_row_info_t *r) |
| Initialize row info for a given matrix. More... | |
| void | cs_matrix_row_finalize (cs_matrix_row_info_t *r) |
| Finalize row info for a given matrix. More... | |
| void | cs_matrix_get_row (const cs_matrix_t *matrix, const cs_lnum_t row_id, cs_matrix_row_info_t *r) |
| Get row values for a given matrix. More... | |
| void | cs_matrix_get_native_arrays (const cs_matrix_t *matrix, bool *symmetric, cs_lnum_t *n_edges, const cs_lnum_2_t **edges, const cs_real_t **d_val, const cs_real_t **x_val) |
| Get arrays describing a matrix in native format. More... | |
| void | cs_matrix_get_csr_arrays (const cs_matrix_t *matrix, const cs_lnum_t **row_index, const cs_lnum_t **col_id, const cs_real_t **val) |
| Get arrays describing a matrix in CSR format. More... | |
| void | cs_matrix_get_msr_arrays (const cs_matrix_t *matrix, const cs_lnum_t **row_index, const cs_lnum_t **col_id, const cs_real_t **d_val, const cs_real_t **x_val) |
| Get arrays describing a matrix in MSR format. More... | |
| void | cs_matrix_apply_variant (cs_matrix_t *m, const cs_matrix_variant_t *mv) |
| void | cs_matrix_vector_multiply (cs_halo_rotation_t rotation_mode, const cs_matrix_t *matrix, cs_real_t *restrict x, cs_real_t *restrict y) |
| Matrix.vector product y = A.x. More... | |
| void | cs_matrix_vector_multiply_nosync (const cs_matrix_t *matrix, const cs_real_t *x, cs_real_t *restrict y) |
| Matrix.vector product y = A.x with no prior halo update of x. More... | |
| void | cs_matrix_exdiag_vector_multiply (cs_halo_rotation_t rotation_mode, const cs_matrix_t *matrix, cs_real_t *restrict x, cs_real_t *restrict y) |
| Matrix.vector product y = (A-D).x. More... | |
| void | cs_matrix_pre_vector_multiply_sync (cs_halo_rotation_t rotation_mode, const cs_matrix_t *matrix, cs_real_t *x) |
| void | cs_matrix_csr_assembler_values_init (void *matrix_p, const cs_lnum_t db_size[4], const cs_lnum_t eb_size[4]) |
| Function for initialization of CSR matrix coefficients using local row ids and column indexes. More... | |
| void | cs_matrix_csr_assembler_values_add (void *matrix_p, cs_lnum_t n, cs_lnum_t stride, const cs_lnum_t row_id[], const cs_lnum_t col_idx[], const cs_real_t vals[]) |
| Function pointer for addition to CSR matrix coefficients using local row ids and column indexes. More... | |
| void | cs_matrix_msr_assembler_values_init (void *matrix_p, const cs_lnum_t db_size[4], const cs_lnum_t eb_size[4]) |
| Function for initialization of MSR matrix coefficients using local row ids and column indexes. More... | |
| void | cs_matrix_msr_assembler_values_add (void *matrix_p, cs_lnum_t n, cs_lnum_t stride, const cs_lnum_t row_id[], const cs_lnum_t col_idx[], const cs_real_t vals[]) |
| Function pointer for addition to MSR matrix coefficients using local row ids and column indexes. More... | |
| void | cs_matrix_variant_build_list (const cs_matrix_t *m, int *n_variants, cs_matrix_variant_t **m_variant) |
| Build list of variants for tuning or testing. More... | |
| cs_matrix_variant_t * | cs_matrix_variant_create (cs_matrix_t *m) |
| Build matrix variant. More... | |
| void | cs_matrix_variant_destroy (cs_matrix_variant_t **mv) |
| Destroy a matrix variant structure. More... | |
| void | cs_matrix_variant_apply (cs_matrix_t *m, cs_matrix_variant_t *mv) |
| Apply a variant to a given matrix. More... | |
| void | cs_matrix_variant_set_func (cs_matrix_variant_t *mv, const cs_numbering_t *numbering, cs_matrix_fill_type_t fill_type, int ed_flag, const char *func_name) |
| Select the sparse matrix-vector product function to be used by a matrix variant for a given fill type. More... | |
| cs_matrix_type_t | cs_matrix_variant_type (const cs_matrix_variant_t *mv) |
| Get the type associated with a matrix variant. More... | |
| const char * | cs_matrix_type_name [] |
| const char * | cs_matrix_type_fullname [] |
| const char * | cs_matrix_fill_type_name [] |
| typedef struct _cs_matrix_structure_t cs_matrix_structure_t |
| typedef struct _cs_matrix_t cs_matrix_t |
| typedef struct _cs_matrix_variant_t cs_matrix_variant_t |
| enum cs_matrix_type_t |
| void cs_matrix_apply_variant | ( | cs_matrix_t * | m, |
| const cs_matrix_variant_t * | mv | ||
| cs_matrix_assembler_values_t* cs_matrix_assembler_values_init | ( | cs_matrix_t * | matrix, |
| const cs_lnum_t * | diag_block_size, | ||
| const cs_lnum_t * | extra_diag_block_size | ||
The associated matrix's structure must have been created using cs_matrix_structure_create_from_assembler.
Block sizes are defined by an optional array of 4 values: 0: useful block size, 1: vector block extents, 2: matrix line extents, 3: matrix line*column extents
| [in,out] | matrix | pointer to matrix structure |
| [in] | diag_block_size | block sizes for diagonal, or NULL |
| [in] | extra_diag_block_size | block sizes for extra diagonal, or NULL |
| void cs_matrix_copy_coefficients | ( | cs_matrix_t * | matrix, |
| bool | symmetric, | ||
| const cs_lnum_t * | extra_diag_block_size, | ||
| const cs_lnum_t | n_edges, | ||
| const cs_lnum_2_t | edges[], | ||
| const cs_real_t * | da, | ||
| const cs_real_t * | xa | ||
With private arrays, the matrix becomes independant from the arrays passed as arguments.
| [in] | symmetric | indicates if matrix coefficients are symmetric |
| [in] | n_edges | local number of graph edges |
| [in] | edges | edges (row <-> column) connectivity |
| [in] | da | diagonal values (NULL if zero) |
| [in] | xa | extradiagonal values (NULL if zero) casts as: xa[n_edges] if symmetric, xa[n_edges][2] if non symmetric |
| void cs_matrix_copy_diagonal | ( | const cs_matrix_t * | matrix, |
| cs_real_t *restrict | da | ||
In case of matrixes with block diagonal coefficients, only the true diagonal values are copied.
| [in] | matrix | pointer to matrix structure |
| [out] | da | diagonal (pre-allocated, size: n_rows*block_size) |
| cs_matrix_t* cs_matrix_create | ( | const cs_matrix_structure_t * | ms | ) |
Note that the matrix container maps to the assigned structure, so it must be destroyed before that structure.
| [in] | ms | associated matrix structure |
| cs_matrix_t* cs_matrix_create_by_copy | ( | cs_matrix_t * | src | ) |
If assigned, coefficients are not copied.
| [in] | src | reference matrix structure |
| cs_matrix_t* cs_matrix_create_by_local_restrict | ( | const cs_matrix_t * | src | ) |
Coefficients are copied. Some coefficients may be shared with the parent matrix, so the base matrix must not be destroyed before the restriction matrix.
| cs_matrix_t* cs_matrix_create_from_assembler | ( | cs_matrix_type_t | type, |
| cs_matrix_assembler_t * | ma | ||
Only CSR and MSR formats are handled.
| [in] | type | type of matrix considered |
| [in] | ma | pointer to matrix assembler structure |
| void cs_matrix_csr_assembler_values_add | ( | void * | matrix_p, |
| cs_lnum_t | n, | ||
| cs_lnum_t | stride, | ||
| const cs_lnum_t | row_id[], | ||
| const cs_lnum_t | col_idx[], | ||
| const cs_real_t | vals[] | ||
Values whose associated row index is negative should be ignored; Values whose column index is -1 are assumed to be assigned to a separately stored diagonal. Other indexes shoudl be valid.
| [in,out] | matrix_p | untyped pointer to matrix description structure |
| [in] | n | number of values to add |
| [in] | stride | associated data block size |
| [in] | row_id | associated local row ids |
| [in] | col_idx | associated local column indexes |
| [in] | vals | pointer to values (size: n*stride) |
| void cs_matrix_csr_assembler_values_init | ( | void * | matrix_p, |
| const cs_lnum_t | db_size[4], | ||
| const cs_lnum_t | eb_size[4] | ||
| [in] | db_size | optional diagonal block sizes |
| [in] | eb_size | optional extra-diagonal block sizes |
| void cs_matrix_destroy | ( | cs_matrix_t ** | matrix | ) |
| void cs_matrix_exdiag_vector_multiply | ( | cs_halo_rotation_t | rotation_mode, |
| const cs_matrix_t * | matrix, | ||
| cs_real_t *restrict | x, | ||
| cs_real_t *restrict | y | ||
This function includes a halo update of x prior to multiplication by A.
| [in,out] | x | multipliying vector values (ghost values updated) |
| [out] | y | resulting vector |
| void cs_matrix_get_csr_arrays | ( | const cs_matrix_t * | matrix, |
| const cs_lnum_t ** | row_index, | ||
| const cs_lnum_t ** | col_id, | ||
| const cs_real_t ** | val | ||
This function only works for an CSR matrix (i.e. there is no automatic conversion from another matrix type).
Matrix block sizes can be obtained by cs_matrix_get_diag_block_size() and cs_matrix_get_extra_diag_block_size().
| [out] | row_index | CSR row index |
| [out] | col_id | CSR column id |
| [out] | val | values |
| const cs_lnum_t* cs_matrix_get_diag_block_size | ( | const cs_matrix_t * | matrix | ) |
Block sizes are defined by a array of 4 values: 0: useful block size, 1: vector block extents, 2: matrix line extents, 3: matrix line*column extents
| const cs_real_t* cs_matrix_get_diagonal | ( | const cs_matrix_t * | matrix | ) |
In case of matrixes with block diagonal coefficients, a pointer to the complete block diagonal is returned.
| const cs_lnum_t* cs_matrix_get_extra_diag_block_size | ( | const cs_matrix_t * | matrix | ) |
| const cs_real_t* cs_matrix_get_extra_diagonal | ( | const cs_matrix_t * | matrix | ) |
This function only functions if the coefficients were mapped from native coefficients using cs_matrix_set_coefficients(), in which case the pointer returned is the same as the one passed to that function.
It is used in the current multgrid code, but should be removed as soon as the dependency to the native format is removed.
| cs_matrix_fill_type_t cs_matrix_get_fill_type | ( | bool | symmetric, |
| const cs_halo_t* cs_matrix_get_halo | ( | const cs_matrix_t * | matrix | ) |
| void cs_matrix_get_msr_arrays | ( | const cs_matrix_t * | matrix, |
| const cs_real_t ** | d_val, | ||
| const cs_real_t ** | x_val | ||
This function only works for an MSR matrix (i.e. there is no automatic conversion from another matrix type).
| [out] | row_index | MSR row index |
| [out] | col_id | MSR column id |
| [out] | d_val | diagonal values |
| [out] | x_val | extra-diagonal values |
| cs_lnum_t cs_matrix_get_n_columns | ( | const cs_matrix_t * | matrix | ) |
| cs_lnum_t cs_matrix_get_n_entries | ( | const cs_matrix_t * | matrix | ) |
When the block size is > 1, the number reported is the number of entry blocks, not individual entries.
| cs_lnum_t cs_matrix_get_n_rows | ( | const cs_matrix_t * | matrix | ) |
| void cs_matrix_get_native_arrays | ( | const cs_matrix_t * | matrix, |
| bool * | symmetric, | ||
| cs_lnum_t * | n_edges, | ||
| const cs_lnum_2_t ** | edges, | ||
This function works for matrix in native format.
| [out] | symmetric | true if symmetric |
| [out] | n_edges | number of associated faces |
| [out] | edges | edges (symmetric row <-> column) connectivity |
| void cs_matrix_get_row | ( | const cs_matrix_t * | matrix, |
| const cs_lnum_t | row_id, | ||
| cs_matrix_row_info_t * | r | ||
This function may not work for all matrix types.
In the case of blocked matrixes, the true (non-blocked) values are returned.
The row information structure must have been previously initialized using cs_matrix_row_init, and should be finalized using using cs_matrix_row_finalize, so as to free buffers it may have built for certain matrix formats.
| [in] | row_id | id of row to query |
| [in,out] | r | row info structure |
| cs_matrix_type_t cs_matrix_get_type | ( | const cs_matrix_t * | matrix | ) |
Return matrix type.
| bool cs_matrix_is_mapped_from_native | ( | const cs_matrix_t * | matrix | ) |
| bool cs_matrix_is_symmetric | ( | const cs_matrix_t * | matrix | ) |
| void cs_matrix_msr_assembler_values_add | ( | void * | matrix_p, |
| cs_lnum_t | n, | ||
| void cs_matrix_msr_assembler_values_init | ( | void * | matrix_p, |
| void cs_matrix_pre_vector_multiply_sync | ( | cs_halo_rotation_t | rotation_mode, |
| cs_real_t * | x | ||
| void cs_matrix_release_coefficients | ( | cs_matrix_t * | matrix | ) |
Pointers to mapped coefficients are set to NULL, while coefficient copies owned by the matrix are not modified.
This simply ensures the matrix does not maintain pointers to nonexistant data.
| void cs_matrix_row_finalize | ( | cs_matrix_row_info_t * | r | ) |
| void cs_matrix_row_init | ( | cs_matrix_row_info_t * | r | ) |
| [out] | r | row info structure |
| void cs_matrix_set_coefficients | ( | cs_matrix_t * | matrix, |
With shared arrays, the matrix becomes unusable if the arrays passed as arguments are not be modified (its coefficients should be unset first to mark this).
Depending on current options and initialization, values will be copied or simply mapped.
| cs_matrix_structure_t* cs_matrix_structure_create | ( | cs_matrix_type_t | type, |
| bool | have_diag, | ||
| cs_lnum_t | n_rows, | ||
| cs_lnum_t | n_cols_ext, | ||
| const cs_lnum_2_t * | edges, | ||
| const cs_halo_t * | halo, | ||
| const cs_numbering_t * | numbering | ||
Note that the structure created usually maps to the given existing cell global number, face -> cell connectivity arrays, and cell halo structure, so it must be destroyed before they are freed (usually along with the code's main face -> cell structure).
Note that the resulting matrix structure will contain either a full or an empty main diagonal, and that the extra-diagonal structure is always symmetric (though the coefficients my not be, and we may choose a matrix format that does not exploit this symmetry). If the edges connectivity argument is NULL, the matrix will be purely diagonal.
| [in] | have_diag | indicates if the diagonal structure contains nonzeroes |
| [in] | n_rows | local number of rows |
| [in] | n_cols_ext | number of local + ghost columns |
| [in] | n_edges | local number of (undirected) graph edges |
| [in] | edges | edges (symmetric row <-> column) connectivity |
| [in] | halo | halo structure associated with cells, or NULL |
| [in] | numbering | vectorization or thread-related numbering info, or NULL |
| cs_matrix_structure_t* cs_matrix_structure_create_from_assembler | ( | cs_matrix_type_t | type, |
| cs_matrix_structure_t* cs_matrix_structure_create_msr | ( | cs_matrix_type_t | type, |
| bool | transfer, | ||
col_id is sorted row by row during the creation of this structure.
In case the property of the row index and col_id arrays are transferred to the structure, the arrays pointers passed as arguments are set to NULL, to help ensure the caller does not use the original arrays directly after this call.
| [in] | transfer | transfer property of row_index and col_id if true, map them otherwise |
| [in] | have_diag | indicates if the structure includes the diagonal (should be the same for all rows) |
| [in] | n_cols_ext | local number of columns + ghosts |
| [in] | row_index | pointer to index on rows |
| [in,out] | col_id | pointer to array of colum ids related to the row index |
| [in] | halo | halo structure for synchronization, or NULL |
| cs_matrix_structure_t* cs_matrix_structure_create_msr_shared | ( | bool | have_diag, |
| bool | direct_assembly, | ||
| const cs_lnum_t * | row_index, | ||
| const cs_lnum_t * | col_id, | ||
Note that as the structure created maps to the given existing cell global number, face -> cell connectivity arrays, and cell halo structure, it must be destroyed before they are freed (usually along with the code's main face -> cell structure).
| [in] | direct_assembly | true if each value corresponds to a unique face |
| [in] | row_index | index on rows |
| [in] | col_id | array of colum ids related to the row index |
| void cs_matrix_structure_destroy | ( | cs_matrix_structure_t ** | ms | ) |
| [in,out] | ms | pointer to matrix structure pointer |
| void cs_matrix_transfer_coefficients_msr | ( | cs_matrix_t * | matrix, |
| const cs_lnum_t | row_index[], | ||
If the matrix is also in MSR format, this avoids an extra copy. If it is in a different format, values are copied to the structure, and the original arrays freed. In any case, the arrays pointers passed as arguments are set to NULL, to help ensure the caller does not use the original arrays directly after this call.
| [in] | row_index | MSR row index (0 to n-1) |
| [in] | col_id | MSR column id (0 to n-1) |
| [in,out] | d_val | diagonal values (NULL if zero) |
| [in,out] | x_val | extradiagonal values (NULL if zero) |
| void cs_matrix_variant_apply | ( | cs_matrix_t * | m, |
| [in,out] | m | pointer to matrix |
| [in] | mv | pointer to matrix variant pointer |
| void cs_matrix_variant_build_list | ( | const cs_matrix_t * | m, |
| int * | n_variants, | ||
| cs_matrix_variant_t ** | m_variant | ||
The matrix coefficients should be assigned, so the fill type can be determined.
| [in] | m | associated matrix |
| [out] | n_variants | number of variants |
| [out] | m_variant | array of matrix variants |
| cs_matrix_variant_t* cs_matrix_variant_create | ( | cs_matrix_t * | m | ) |
The variant will initially use default matrix-vector functions, which can be later modified using cs_matrix_variant_set_func().
| [in] | m | pointer to matrix |
| void cs_matrix_variant_destroy | ( | cs_matrix_variant_t ** | mv | ) |
| [in,out] | mv | pointer to matrix variant pointer |
| void cs_matrix_variant_set_func | ( | cs_matrix_variant_t * | mv, |
| const cs_numbering_t * | numbering, | ||
| cs_matrix_fill_type_t | fill_type, | ||
| int | ed_flag, | ||
| const char * | func_name | ||
Currently, possible variant functions are:
CS_MATRIX_NATIVE (all fill types) default standard omp (for OpenMP with compatible numbering) omp_atomic (for OpenMP with atomics) vector (For vector machine with compatible numbering)
CS_MATRIX_CSR (for CS_MATRIX_SCALAR or CS_MATRIX_SCALAR_SYM) default standard mkl (with MKL)
CS_MATRIX_CSR_SYM (for CS_MATRIX_SCALAR_SYM) default standard mkl (with MKL)
CS_MATRIX_MSR (all fill types except CS_MATRIX_33_BLOCK) default standard mkl (with MKL, for CS_MATRIX_SCALAR or CS_MATRIX_SCALAR_SYM) omp_sched (For OpenMP with scheduling)
parameters: mv <-> Pointer to matrix variant numbering <– mesh numbering info, or NULL fill type <– matrix fill type to merge from ed_flag <– 0: with diagonal only, 1 exclude only; 2; both func_name <– function type name
| cs_matrix_type_t cs_matrix_variant_type | ( | const cs_matrix_variant_t * | mv | ) |
| [in] | mv | pointer to matrix variant structure |
| void cs_matrix_vector_multiply | ( | cs_halo_rotation_t | rotation_mode, |
| void cs_matrix_vector_multiply_nosync | ( | const cs_matrix_t * | matrix, |
| const cs_real_t * | x, | ||
This function does not include a halo update of x prior to multiplication by A, so it should be called only when the halo of x is known to already be up to date (in which case we avoid the performance penalty of a redundant update by using this variant of the matrix.vector product).
| [in] | x | multipliying vector values |
| const char* cs_matrix_fill_type_name[] |
| const char* cs_matrix_type_fullname[] |
| const char* cs_matrix_type_name[] |
