34 #if defined(HAVE_CONFIG_H) 35 # include "cs_config.h" 49 #if defined(ENABLE_NLS) && defined(HAVE_GETTEXT) 52 # define _(String) dgettext(PACKAGE, String) 54 # define N_(String) gettext_noop(String) 56 # define N_(String) String 66 # define _(String) (String) 67 # define N_(String) String 68 # define textdomain(String) (String) 69 # define gettext(String) (String) 70 # define dgettext(Domain,String) (String) 71 # define dcgettext(Domain,String,Type) (String) 72 # define bindtextdomain(Domain, Directory) (Domain) 84 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI) 88 # if !defined(MPI_VERSION) 89 # define MPI_VERSION 1 94 # define MPI_INFO_NULL 0 99 #if defined(HAVE_OPENMP) 111 #if !defined(__STDC_VERSION__) 112 # define __STDC_VERSION__ 1989 120 #if (__STDC_VERSION__ < 199901L) 122 # if defined(__GNUC__) 123 # define inline __inline__ 124 # define restrict __restrict__ 134 # ifndef HAVE_RESTRICT 163 #elif HAVE_INTTYPES_H 164 # include <inttypes.h> 171 #if defined(HAVE_SYS_TYPES_H) 172 #include <sys/types.h> 178 # include <stdbool.h> 182 # define _Bool signed char; 190 # define __bool_true_false_are_defined 1 195 #if !defined(HAVE_INT32_T) 196 # if (SIZEOF_INT == 4) 198 # elif (SIZEOF_SHORT == 4) 199 typedef short int32_t;
207 #if !defined(HAVE_INT64_T) 208 # if (SIZEOF_INT == 8) 210 # elif (SIZEOF_LONG == 8) 211 typedef long int64_t;
212 # elif (HAVE_LONG_LONG == 8) 213 typedef long long int64_t;
221 #if !defined(HAVE_UINT32_T) 222 # if (SIZEOF_INT == 4) 223 typedef unsigned uint32_t;
224 # elif (SIZEOF_SHORT == 4) 225 typedef unsigned short uint32_t;
233 #if !defined(HAVE_UINT64_T) 234 # if (SIZEOF_INT == 8) 235 typedef unsigned uint64_t;
236 # elif (SIZEOF_LONG == 8) 237 typedef unsigned long uint64_t;
238 # elif (HAVE_LONG_LONG) 239 typedef unsigned long long uint64_t;
284 #if defined(HAVE_LONG_GNUM) 285 #if (SIZEOF_LONG == 8) 287 #elif (SIZEOF_LONG_LONG == 8) 298 #if defined(HAVE_LONG_LNUM) 363 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI) 365 # define CS_MPI_REAL MPI_DOUBLE 369 # if defined(HAVE_LONG_GNUM) 370 # if (SIZEOF_LONG == 8) 371 # define CS_MPI_GNUM MPI_UNSIGNED_LONG 372 # elif (SIZEOF_LONG_LONG == 8) 373 # if defined(MPI_UNSIGNED_LONG_LONG) 374 # define CS_MPI_GNUM MPI_UNSIGNED_LONG_LONG 375 # elif defined(MPI_LONG_LONG) 376 # define CS_MPI_GNUM MPI_LONG_LONG 379 # if !defined(CS_MPI_GNUM) 383 # define CS_MPI_GNUM MPI_UNSIGNED 388 # if defined(HAVE_LONG_LNUM) 389 # define CS_MPI_LNUM MPI_LONG 391 # define CS_MPI_LNUM MPI_INT 394 # define CS_MPI_EFLAG MPI_UNSIGNED 395 # define CS_MPI_FLAG MPI_UNSIGNED_SHORT 396 # define CS_MPI_COORD MPI_DOUBLE 403 #if defined(HAVE_LONG_GNUM) 404 # define CS_GNUM_TYPE CS_UINT64 405 #elif (SIZEOF_INT == 8) 406 # define CS_GNUM_TYPE CS_UINT64 408 # define CS_GNUM_TYPE CS_UINT32 411 #if defined(HAVE_LONG_LNUM) 412 # if (SIZEOF_LONG == 8) 413 # define CS_LNUM_TYPE CS_INT64 415 # define CS_LNUM_TYPE CS_INT32 418 # if (SIZEOF_INT == 8) 419 # define CS_LNUM_TYPE CS_INT64 421 # define CS_LNUM_TYPE CS_INT32 425 #if (SIZEOF_INT == 8) 426 # define CS_INT_TYPE CS_INT64 428 # define CS_INT_TYPE CS_INT32 431 #if (SIZEOF_INT == 8) 432 # define CS_UINT_TYPE CS_UINT64 434 # define CS_UINT_TYPE CS_UINT32 437 #define CS_FLAG_TYPE CS_UINT16 438 #define CS_EFLAG_TYPE CS_UINT_TYPE 439 #define CS_REAL_TYPE CS_DOUBLE 440 #define CS_COORD_TYPE CS_DOUBLE 446 #define CS_THR_MIN 128 451 #define CS_CL_SIZE 64 457 #define CS_ABS(a) ((a) < 0 ? -(a) : (a)) 458 #define CS_MIN(a,b) ((a) < (b) ? (a) : (b)) 459 #define CS_MAX(a,b) ((a) > (b) ? (a) : (b)) 481 #define CS_UNUSED(x) (void)(x) 482 #define CS_NO_WARN_IF_UNUSED(x) (void)(x) 491 #if defined(__cplusplus) 492 # define BEGIN_C_DECLS extern "C" { 493 # define END_C_DECLS } 495 # define BEGIN_C_DECLS 508 #if !defined (__hpux) 509 #define CS_PROCF(x, y) x##_ 511 #define CS_PROCF(x, y) x 521 #if defined (__uxpv__) 522 #define CS_ARGF_SUPP_CHAINE 524 #define CS_ARGF_SUPP_CHAINE , ... 542 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI) 555 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI) 580 return ((i > 0) ? ((i-1)/m+1)*m : 0);
MPI_Comm cs_glob_mpi_comm
Definition: cs_defs.c:179
cs_datatype_t
Definition: cs_defs.h:260
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
cs_lnum_t cs_lnum_3_t[3]
Definition: cs_defs.h:314
cs_real_t cs_real_333_t[3][3][3]
Definition: cs_defs.h:331
Definition: cs_defs.h:268
cs_real_t cs_real_2_t[2]
Definition: cs_defs.h:319
Definition: cs_defs.h:267
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:322
Definition: cs_defs.h:469
cs_real_t cs_real_34_t[3][4]
Definition: cs_defs.h:333
cs_real_t cs_real_66_t[6][6]
6x6 matrix of floating-point values
Definition: cs_defs.h:328
char cs_byte_t
Definition: cs_defs.h:308
cs_interlace_t
Definition: cs_defs.h:467
Definition: cs_defs.h:262
cs_coord_t cs_coord_3_t[3]
Definition: cs_defs.h:316
cs_real_t cs_real_99_t[9][9]
Definition: cs_defs.h:329
int cs_glob_n_ranks
Definition: cs_defs.c:175
cs_real_66_t cs_real_662_t[2]
Definition: cs_defs.h:341
Definition: cs_defs.h:270
double cs_coord_t
Definition: cs_defs.h:305
cs_real_t cs_real_4_t[4]
vector of 4 floating-point values
Definition: cs_defs.h:321
Definition: cs_defs.h:307
Definition: cs_defs.h:353
Definition: cs_defs.h:470
Definition: cs_defs.h:344
cs_real_t cs_real_9_t[9]
Definition: cs_defs.h:324
Definition: cs_defs.h:264
cs_real_t cs_real_10_t[10]
Definition: cs_defs.h:325
double meas
Definition: cs_defs.h:355
int cs_glob_n_threads
Definition: cs_defs.c:172
MPI_Datatype cs_datatype_to_mpi[]
Definition: cs_defs.c:157
const char cs_empty_string[]
Definition: cs_defs.c:129
cs_real_33_t cs_real_332_t[2]
vector of 2 3x3 matrices of floating-point values
Definition: cs_defs.h:339
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:313
Definition: cs_defs.h:269
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:320
const size_t cs_datatype_size[]
Definition: cs_defs.c:133
Definition: cs_defs.h:301
cs_real_t cs_real_69_t[6][9]
Definition: cs_defs.h:337
Definition: cs_defs.h:263
unsigned short int cs_flag_t
Definition: cs_defs.h:309
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:327
const char * cs_datatype_name[]
Definition: cs_defs.c:143
cs_real_t cs_real_63_t[6][3]
Definition: cs_defs.h:335
int id
Definition: cs_defs.h:347
Definition: cs_defs.h:266
Definition: cs_defs.h:265
int cs_glob_rank_id
Definition: cs_defs.c:174
double val
Definition: cs_defs.h:346
