cs_cdofb_monolithic_sles.h File Reference
#include "cs_navsto_param.h"
+ Include dependency graph for cs_cdofb_monolithic_sles.h:
Data Structures
struct  cs_cdofb_monolithic_sles_t
cs_cdofb_monolithic_sles_tcs_cdofb_monolithic_sles_create (void)
 Create an empty cs_cdofb_monolithic_sles_t structure. More...
void cs_cdofb_monolithic_sles_init (cs_lnum_t n_cells, cs_lnum_t n_faces, cs_cdofb_monolithic_sles_t *msles)
 Allocate and initialize the rhs. More...
void cs_cdofb_monolithic_sles_reset (cs_cdofb_monolithic_sles_t *msles)
 Reset to zero rhs and clean the cs_sles_t structure. More...
void cs_cdofb_monolithic_sles_clean (cs_cdofb_monolithic_sles_t *msles)
 Free a part of the structure. More...
void cs_cdofb_monolithic_sles_free (cs_cdofb_monolithic_sles_t **p_msles)
 Free memory related to cs_cdofb_monolithic_sles_t structure. More...
void cs_cdofb_monolithic_sles_set_shared (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_range_set_t *rset)
 Set pointers to shared structures. More...
void cs_cdofb_monolithic_set_sles (cs_navsto_param_t *nsp, void *context)
 Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to couple the system. No mesh information is available at this stage. nsp is not declared as cnost to avoid compilation warnings but it should be modified at this stage. More...
int cs_cdofb_monolithic_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
 Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-based approach. The full system is treated as one block and then sent to PETSc. More...
int cs_cdofb_monolithic_by_blocks_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
 Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-based approach. The system is split into blocks to enable more efficient preconditioning techniques. More...
int cs_cdofb_monolithic_gkb_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
 Use the GKB algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes and Navier-Stokes with a monolithic coupling. More...
int cs_cdofb_monolithic_uzawa_cg_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
 Use the preconditioned Uzawa-CG algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes, Oseen and Navier-Stokes with a monolithic coupling This algorithm is based on Koko's paper "Uzawa conjugate gradient method for the Stokes problem: Matlab implementation with P1-iso-P2/ P1 finite element". More...
int cs_cdofb_monolithic_uzawa_n3s_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
 Use the preconditioned Uzawa-CG algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes, Oseen and Navier-Stokes with a monolithic coupling This algorithm is based on the EDF report H-E40-1991-03299-FR devoted the numerical algorithms used in the code N3S. Specifically a Cahout-Chabard preconditioning is used to approximate the Schur complement. More...
int cs_cdofb_monolithic_uzawa_al_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
 Use the Uzawa algorithm with an Augmented Lagrangian technique to solve the saddle-point problem arising from CDO-Fb schemes for Stokes, Oseen and Navier-Stokes with a monolithic coupling. More...
int cs_cdofb_monolithic_uzawa_al_incr_solve (const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, cs_cdofb_monolithic_sles_t *msles)
 Use the Uzawa algorithm with an Augmented Lagrangian technique in an incremental way to solve the saddle-point problem arising from CDO-Fb schemes for Stokes, Oseen and Navier-Stokes with a monolithic coupling. More...
◆ cs_cdofb_monolithic_by_blocks_solve()
int cs_cdofb_monolithic_by_blocks_solve ( const cs_navsto_param_t nsp,
const cs_equation_param_t eqp,
cs_cdofb_monolithic_sles_t msles
[in,out]mslespointer to a cs_cdofb_monolithic_sles_t structure
the (cumulated) number of iterations of the solver
◆ cs_cdofb_monolithic_gkb_solve()
int cs_cdofb_monolithic_gkb_solve ( const cs_navsto_param_t nsp,
the cumulated number of iterations of the solver
◆ cs_cdofb_monolithic_set_sles()
void cs_cdofb_monolithic_set_sles ( cs_navsto_param_t nsp,
void *  context
[in,out]contextpointer to a context structure cast on-the-fly
◆ cs_cdofb_monolithic_sles_clean()
void cs_cdofb_monolithic_sles_clean ( cs_cdofb_monolithic_sles_t msles)
[in,out]mslespointer to the structure to clean
◆ cs_cdofb_monolithic_sles_create()
cs_cdofb_monolithic_sles_t* cs_cdofb_monolithic_sles_create ( void  )
a pointer to a newly allocated structure
◆ cs_cdofb_monolithic_sles_free()
void cs_cdofb_monolithic_sles_free ( cs_cdofb_monolithic_sles_t **  p_msles)
[in,out]p_mslesdouble pointer to the structure to free
◆ cs_cdofb_monolithic_sles_init()
void cs_cdofb_monolithic_sles_init ( cs_lnum_t  n_cells,
cs_lnum_t  n_faces,
[in]n_cellslocal number of cells
[in]n_faceslocal number of faces
[in,out]mslespointer to the structure to reset
◆ cs_cdofb_monolithic_sles_reset()
void cs_cdofb_monolithic_sles_reset ( cs_cdofb_monolithic_sles_t msles)
◆ cs_cdofb_monolithic_sles_set_shared()
void cs_cdofb_monolithic_sles_set_shared ( const cs_cdo_connect_t connect,
const cs_range_set_t rset
[in]connectpointer to cdo connectivities
[in]quantpointer to additional mesh quantities
[in]rsetpointer to a cs_range_set_t structure
◆ cs_cdofb_monolithic_solve()
int cs_cdofb_monolithic_solve ( const cs_navsto_param_t nsp,
◆ cs_cdofb_monolithic_uzawa_al_incr_solve()
int cs_cdofb_monolithic_uzawa_al_incr_solve ( const cs_navsto_param_t nsp,
◆ cs_cdofb_monolithic_uzawa_al_solve()
int cs_cdofb_monolithic_uzawa_al_solve ( const cs_navsto_param_t nsp,
◆ cs_cdofb_monolithic_uzawa_cg_solve()
int cs_cdofb_monolithic_uzawa_cg_solve ( const cs_navsto_param_t nsp,
◆ cs_cdofb_monolithic_uzawa_n3s_solve()
int cs_cdofb_monolithic_uzawa_n3s_solve ( const cs_navsto_param_t nsp,
