1 #ifndef __CS_NAVSTO_SYSTEM_H__ 2 #define __CS_NAVSTO_SYSTEM_H__ 138 void *scheme_context);
time step descriptor
Definition: cs_time_step.h:64
void cs_navsto_system_compute(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Build, solve and update the Navier-Stokes system.
Definition: cs_navsto_system.c:1380
cs_field_t * enstrophy
Definition: cs_navsto_system.h:269
int cs_boundary_type_t
Definition: cs_boundary.h:69
cs_navsto_free_scheme_context_t * free_scheme_context
Definition: cs_navsto_system.h:322
bool cs_navsto_system_is_activated(void)
Check if the resolution of the Navier-Stokes system has been activated.
Definition: cs_navsto_system.c:216
Definition: cs_advection_field.h:149
Structure storing the parameters related to the resolution of the tubulence modelling. Several members are structures defined in cs_turbulence_model.h.
Definition: cs_cdo_turbulence.h:171
void cs_navsto_system_set_sles(void)
Define the settings for SLES related to the Navier-Stokes system.
Definition: cs_navsto_system.c:744
cs_navsto_param_coupling_t
Definition: cs_navsto_param.h:525
Definition: cs_field.h:125
void cs_navsto_system_set_solid_cells(cs_lnum_t n_solid_cells, cs_lnum_t solid_cell_ids[])
Set a solid zone related to the Navier-Stokes equations.
Definition: cs_navsto_system.c:1190
void *() cs_navsto_free_scheme_context_t(void *scheme_context)
Free the context structure related to a given discretization scheme for the resolution of the Navier-...
Definition: cs_navsto_system.h:102
void cs_navsto_system_finalize_setup(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Last step of the setup of the Navier-Stokes system.
Definition: cs_navsto_system.c:808
cs_navsto_compute_t * compute_steady
Definition: cs_navsto_system.h:340
Definition: cs_defs.h:495
cs_equation_t * cs_navsto_system_get_momentum_eq(void)
Retrieve a pointer to the equation related to the momentum equation.
Definition: cs_navsto_system.c:476
cs_navsto_init_values_t * init_velocity
Definition: cs_navsto_system.h:328
Routines to handle the cs_thermal_system_t structure. The temperature field is automatically defined ...
cs_flag_t cs_navsto_param_post_flag_t
Definition: cs_navsto_param.h:58
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:155
void() cs_navsto_compute_t(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Compute for the current time step the new state for the Navier-Stokes system. This means that equatio...
Definition: cs_navsto_system.h:136
Definition: cs_navsto_param.h:540
void cs_navsto_system_update(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Update variables and related quantities when a new state of the Navier-Stokes system has been compute...
Definition: cs_navsto_system.c:1235
cs_turbulence_t * turbulence
Definition: cs_navsto_system.h:215
Definition: cs_defs.h:307
void * scheme_context
Definition: cs_navsto_system.h:302
cs_equation_t * stream_function_eq
Definition: cs_navsto_system.h:282
cs_real_t * cs_navsto_get_mass_flux(bool previous)
Retrieve the mass flux array related to the Navier-Stokes system.
Definition: cs_navsto_system.c:538
void cs_navsto_system_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the Navier-Stokes system. The prototype of this function is fix...
Definition: cs_navsto_system.c:1529
cs_field_t * velocity
Definition: cs_navsto_system.h:192
cs_navsto_init_scheme_context_t * init_scheme_context
Definition: cs_navsto_system.h:315
cs_field_t * helicity
Definition: cs_navsto_system.h:263
cs_navsto_param_t * cs_navsto_system_get_param(void)
Retrieve the structure storing the parameters for the Navier–Stokes system.
Definition: cs_navsto_system.c:457
cs_real_t * mass_flux_array_pre
Definition: cs_navsto_system.h:174
Definition: cs_navsto_system.h:167
cs_navsto_init_values_t * init_pressure
Definition: cs_navsto_system.h:334
cs_field_t * pressure
Definition: cs_navsto_system.h:198
Structure managing the Navier-Stokes system.
Definition: cs_navsto_system.h:149
void cs_navsto_system_update_model(bool with_thermal)
Update the flag associated to the modelling options.
Definition: cs_navsto_system.c:233
void cs_navsto_system_compute_steady_state(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Build, solve and update the Navier-Stokes system in case of a steady-state approach.
Definition: cs_navsto_system.c:1265
void() cs_navsto_init_values_t(const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, cs_field_t *field)
According to the model, coupling algorithm and the space discretization, initialize the field values ...
Definition: cs_navsto_system.h:118
cs_thermal_system_t * thm
Definition: cs_navsto_system.h:222
cs_boundary_type_t * bf_type
Definition: cs_navsto_system.h:179
cs_field_t * kinetic_energy
Definition: cs_navsto_system.h:251
void cs_navsto_system_extra_op(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *ts)
Predefined extra-operations for the Navier-Stokes system.
Definition: cs_navsto_system.c:1463
cs_navsto_param_t * param
Definition: cs_navsto_system.h:154
void cs_navsto_system_initialize(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
Initialize the scheme context structure used to build the algebraic system. This is done after the se...
Definition: cs_navsto_system.c:1124
cs_navsto_system_t * cs_navsto_system_activate(const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag)
Allocate and initialize the Navier-Stokes (NS) system.
Definition: cs_navsto_system.c:275
Definition: cs_defs.h:301
Definition: cs_navsto_system.h:346
void *() cs_navsto_init_scheme_context_t(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nscc)
Allocate and initialize the context structure related to a given discretization scheme for the resolu...
Definition: cs_navsto_system.h:82
cs_adv_field_t * cs_navsto_get_adv_field(void)
Retrieve the advection field structure (the mass flux) related to the Navier-Stokes system...
Definition: cs_navsto_system.c:517
Structure and routines handling the Maxwell module dedicated to the resolution of electro-magnetic eq...
cs_field_t * vorticity
Definition: cs_navsto_system.h:257
Definition: cs_defs.h:496
cs_maxwell_t * mxl
Definition: cs_navsto_system.h:229
cs_adv_field_t * adv_field
Definition: cs_navsto_system.h:160
Definition: cs_thermal_system.h:145
void cs_navsto_system_log_setup(void)
Summary of the main cs_navsto_system_t structure.
Definition: cs_navsto_system.c:1655
cs_field_t * velocity_gradient
Definition: cs_navsto_system.h:274
void cs_navsto_system_init_setup(void)
Start setting-up the Navier-Stokes system At this stage, numerical settings should be completely dete...
Definition: cs_navsto_system.c:560
Describe the system of equations related to the Navier-Stokes to be solved.
Definition: cs_navsto_param.h:81
void * coupling_context
Definition: cs_navsto_system.h:295
void cs_navsto_system_destroy(void)
Free the main structure related to the Navier-Stokes system.
Definition: cs_navsto_system.c:387
cs_flag_t cs_navsto_param_model_flag_t
Definition: cs_navsto_param.h:57
cs_field_t * velocity_divergence
Definition: cs_navsto_system.h:244
