Structure and routines handling the Maxwell module dedicated to the resolution of electro-magnetic equations. More...
Include dependency graph for cs_maxwell.h:Go to the source code of this file.
Macros | |
| #define | CS_MAXWELL_ESTATIC_EQNAME "electrostatic" |
| #define | CS_MAXWELL_EFIELD_NAME "electric_field" |
| #define | CS_MAXWELL_DFIELD_NAME "electric_induction" |
| #define | CS_MAXWELL_MSTATIC_EQNAME "magnetostatic" |
| #define | CS_MAXWELL_MFIELD_NAME "magnetic_field" |
| #define | CS_MAXWELL_BFIELD_NAME "magnetic_induction" |
| #define | CS_MAXWELL_JEFFECT_NAME "joule_effect" |
Flags specifying the modelling for the Maxwell module | |
These fields are considered: H (A/m) the magnetic field E (V/m) the electric field B (Vs/m^2) the magnetic induction or magnetic flux density D (As/m^2) the electric induction or electric flux density Moreover, one considers rho_e the electric charge density j the electric source current (or current for short) One assumes a quasi-static approximation of the maxwell equations i.e. ones solves the Ampere equation: curl(H) = j and one solves the Faraday equation: curl(E) = -partial_t B | |
| #define | CS_MAXWELL_MODEL_ELECTROSTATIC (1 << 0) /* 1 */ |
| Solve the equation -div(epsilon grad(phi)) = rho_e + BCs which results from div(D) = rho_e, D = epsilon E and E = -grad(phi) More... | |
| #define | CS_MAXWELL_MODEL_MAGNETOSTATIC (1 << 1) /* 2 */ |
| Solve the system curl(H) = j, div(mu H) = 0 + BCs which yields curl( 1/mu curl(A)) = j and div(A) = 0 (Coulomb gauge) + BCs if one sets: mu.H = curl(A) More... | |
Flags specifying options for the Maxwell module | |
| #define | CS_MAXWELL_A_PHI_FORMULATION (1 << 0) /* 1 */ |
| Vector-valued potential (A) and scalar-valued potential (phi) are introduced to solve the Maxwell equations. One introduces the following identities: curl(A) = B and E = -partial_t A - grad(phi) More... | |
| #define | CS_MAXWELL_JOULE_EFFECT (1 << 1) /* 2 */ |
| Take into account the Joule effect. More... | |
| bool | cs_maxwell_is_activated (void) |
| Test if the computation of Maxwell equations is activated. More... | |
| cs_maxwell_t * | cs_maxwell_activate (cs_flag_t model, cs_flag_t options) |
| Activate the future computation of the Maxwell equations. More... | |
| cs_maxwell_t * | cs_maxwell_destroy_all (void) |
| Free the main structure related to the Maxwell module. More... | |
| void | cs_maxwell_init_setup (void) |
| Setup equations/properties related to the Maxwell module. More... | |
| void | cs_maxwell_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Finalize the setup stage for equations related to the Maxwell module. More... | |
| void | cs_maxwell_log_setup (void) |
| Log a summary of the Maxwell module. More... | |
| void | cs_maxwell_compute_steady_state (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Solve if needed the steady-state equations related to the Maxwell module. More... | |
| void | cs_maxwell_compute (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Solve equations related to the Maxwell module. More... | |
| void | cs_maxwell_update (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, bool cur2prev) |
| Update/initialize the Maxwell module according to the settings. More... | |
| void | cs_maxwell_extra_op (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Predefined extra-operations for the Maxwell module. More... | |
| void | cs_maxwell_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step) |
| Predefined post-processing output for the Maxwell module. Prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More... | |
| #define CS_MAXWELL_A_PHI_FORMULATION (1 << 0) /* 1 */ |
| #define CS_MAXWELL_BFIELD_NAME "magnetic_induction" |
| #define CS_MAXWELL_DFIELD_NAME "electric_induction" |
| #define CS_MAXWELL_EFIELD_NAME "electric_field" |
| #define CS_MAXWELL_ESTATIC_EQNAME "electrostatic" |
| #define CS_MAXWELL_JEFFECT_NAME "joule_effect" |
| #define CS_MAXWELL_JOULE_EFFECT (1 << 1) /* 2 */ |
| #define CS_MAXWELL_MFIELD_NAME "magnetic_field" |
| #define CS_MAXWELL_MODEL_ELECTROSTATIC (1 << 0) /* 1 */ |
| #define CS_MAXWELL_MODEL_MAGNETOSTATIC (1 << 1) /* 2 */ |
| #define CS_MAXWELL_MSTATIC_EQNAME "magnetostatic" |
| [in] | model | type of modelling |
| [in] | options | flag to handle optional parameters |
| void cs_maxwell_compute | ( | const cs_mesh_t * | mesh, |
| void cs_maxwell_compute_steady_state | ( | const cs_mesh_t * | mesh, |
| cs_maxwell_t* cs_maxwell_destroy_all | ( | void | ) |
| void cs_maxwell_extra_op | ( | const cs_cdo_connect_t * | connect, |
| void cs_maxwell_extra_post | ( | void * | input, |
| int | mesh_id, | ||
| int | cat_id, | ||
| int | ent_flag[5], | ||
| cs_lnum_t | n_cells, | ||
| cs_lnum_t | n_i_faces, | ||
| cs_lnum_t | n_b_faces, | ||
| void cs_maxwell_finalize_setup | ( | const cs_cdo_connect_t * | connect, |
| void cs_maxwell_init_setup | ( | void | ) |
| bool cs_maxwell_is_activated | ( | void | ) |
| void cs_maxwell_log_setup | ( | void | ) |
| void cs_maxwell_update | ( | const cs_mesh_t * | mesh, |
| bool | cur2prev | ||
