cs_time_step_t Struct Reference
time step descriptor More...
#include <cs_time_step.h>
+ Collaboration diagram for cs_time_step_t:
Data Fields
int is_variable
int is_local
int nt_prev
int nt_cur
int nt_max
int nt_ini
double t_prev
double t_cur
double t_max
double dt [3]
double dt_ref
double dt_next
Members of this time step are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
Field Documentation
◆ dt
double dt[3]
◆ dt_next
double dt_next
◆ dt_ref
dt_ref
Reference time step.
This is the time step value used in the case of a calculation run with a uniform and constant time step, i.e. idtvar =CS_TIME_STEP_CONSTANT (restart calculation or not). It is the value used to initialize the time step in the case of an initial calculation run with a non-constant time step (idtvar=CS_TIME_STEP_ADAPTATIVE or CS_TIME_STEP_LOCAL). It is also the value used to initialise the time step in the case of a restart calculation in which the type of time step has been changed (for instance, idtvar=CS_TIME_STEP_ADAPTATIVE in the new calculation and idtvar = CS_TIME_STEP_CONSTANT or CS_STEP_LOCAL_TIME in the previous calculation).
See Time step modification for examples.
◆ is_local
is_local
0 if time step is uniform in space, 0 if is is local (in which case the time value is only a reference)
◆ is_variable
is_variable
0 if time step is fixed in time, 1 otherwise
◆ nt_cur
nt_cur
current absolute time step number In case of restart, this is equal to nt_prev + number of new iterations.
◆ nt_ini
nt_ini
number of time step for initialization
◆ nt_max
nt_max
maximum absolute time step number For the restart calculations, nt_max takes into account the number of time steps of the previous calculations. For instance, after a first calculation of 3 time steps, a restart file of 2 time steps is realised by setting nt_max = 3+2 = 5
◆ nt_prev
nt_prev
Absolute time step number for previous calculation. In the case of a restart calculation, nt_prev is read from the restart file. Otherwise, it is initialised to 0 nt_prev is initialised automatically by the code, its value is not to be modified by the user.
◆ t_cur
t_cur
Current absolute time. For the restart calculations, t_cur takes into account the physical time of the previous calculations.
If the time step is uniform (idtvar = CS_TIME_STEP_CONSTANT or CS_ADAPTATIVE_TIME_STEP), t_cur increases of dt (value of the time step) at each iteration. If the time step is non-uniform (idtvar=CS_TIME_STEP_LOCAL), t_cur increases of dt_ref at each time step.
t_cur is initialised and updated automatically by the code, its value is not to be modified by the user.
◆ t_max
t_max
◆ t_prev
t_prev
Absolute time value for previous calculation. In the case of a restart calculation, t_prev is read from the restart file. Otherwise it is initialised to 0.
