cs_field_t Struct Reference
Field descriptor. More...
#include <cs_field.h>
+ Collaboration diagram for cs_field_t:
Data Fields
const char * name
int id
int type
int dim
int location_id
int n_time_vals
cs_real_t ** vals
cs_real_tval
cs_real_tval_pre
cs_field_bc_coeffs_tbc_coeffs
bool is_owner
Members of this field are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
Field Documentation
◆ bc_coeffs
bc_coeffs
Boundary condition coefficients, for variable type fields
◆ dim
dim
Field dimension (usually 1 for scalar, 3 for vector, or 6 for symmetric tensor)
◆ id
id
Field id (based on order of field declaration, starting at 0)
◆ is_owner
is_owner
Ownership flag for values
◆ location_id
location_id
Id of matching mesh location
◆ n_time_vals
n_time_vals
Number of time values
◆ name
name
Canonical name
◆ type
type
Field type flag (sum of field mask constants, defining if a field is a variable, a property, ...)
◆ val
val
For each active location, pointer to matching values array
◆ val_pre
val_pre
For each active location, pointer to matching previous values array (only if n_time_vals > 1)
◆ vals
vals
vals[0][:] is a pointer to val vals[1][:] is a pointer to val_pre vals[p][:] is a pointer to p ith previous field values
