55 #define CS_FIELD_INTENSIVE (1 << 0) 58 #define CS_FIELD_EXTENSIVE (1 << 1) 63 #define CS_FIELD_VARIABLE (1 << 2) 66 #define CS_FIELD_PROPERTY (1 << 3) 69 #define CS_FIELD_POSTPROCESS (1 << 4) 72 #define CS_FIELD_ACCUMULATOR (1 << 5) 75 #define CS_FIELD_USER (1 << 6) 78 #define CS_FIELD_CDO (1 << 7) 533 double default_value,
555 const char *default_value,
581 const void *default_value,
Definition: cs_field.c:2991
const char * cs_field_get_key_str(const cs_field_t *f, int key_id)
Return a string for a given key associated with a field.
Definition: cs_field.c:3293
int cs_field_set_key_int(cs_field_t *f, int key_id, int value)
Assign a integer value for a given key to a field.
Definition: cs_field.c:2943
Definition: cs_field.h:153
Definition: cs_field.c:2497
void cs_field_init_bc_coeffs(cs_field_t *f)
Initialize boundary condition coefficients arrays.
Definition: cs_field.c:1945
cs_real_t * b
Definition: cs_field.h:109
int location_id
Definition: cs_field.h:134
Definition: cs_field.h:125
const char * cs_glob_field_comp_name_6[]
void cs_field_log_defs(void)
Print info relative to all field definitions to log file.
Definition: cs_field.c:3624
int cs_field_define_key_str(const char *name, const char *default_value, int type_flag)
Define a key for a string value by its name and return an associated id.
Definition: cs_field.c:2626
int cs_field_key_flag(int key_id)
Get the type flag associated with a given key id.
Definition: cs_field.c:2789
int dim
Definition: cs_field.h:132
const char * cs_glob_field_comp_name_3[]
void cs_field_map_values(cs_field_t *f, cs_real_t *val, cs_real_t *val_pre)
Map existing value arrays to field descriptor.
Definition: cs_field.c:1744
const void * cs_field_get_key_struct(const cs_field_t *f, int key_id, void *s)
Return a structure for a given key associated with a field.
Definition: cs_field.c:3414
Definition: cs_defs.h:495
bool cs_field_is_key_set(const cs_field_t *f, int key_id)
Query if a given key has been set for a field.
Definition: cs_field.c:2835
cs_real_t * val_pre
Definition: cs_field.h:149
void cs_field_allocate_values(cs_field_t *f)
Allocate arrays for field values.
Definition: cs_field.c:1713
Definition: cs_field.h:91
void cs_field_log_all_key_vals(bool log_defaults)
Print info relative to all given field keys to log file.
Definition: cs_field.c:4234
int cs_field_lock_key(cs_field_t *f, int key_id)
Lock a field relative to a given key.
Definition: cs_field.c:2898
int cs_field_define_sub_key(const char *name, int parent_id)
Define a sub key.
Definition: cs_field.c:2731
void cs_field_allocate_or_map_all(void)
Allocate arrays for all defined fields based on their location.
Definition: cs_field.c:2283
int cs_field_key_id_try(const char *name)
Return an id associated with a given key name if present.
Definition: cs_field.c:2524
cs_real_t * val
Definition: cs_field.h:146
const char * cs_glob_field_comp_name_9[]
void cs_field_define_keys_base(void)
Define base keys.
Definition: cs_field.c:4265
cs_real_t * hext
Definition: cs_field.h:118
Definition: cs_defs.h:307
int cs_field_set_key_double(cs_field_t *f, int key_id, double value)
Assign a floating point value for a given key to a field.
Definition: cs_field.c:3123
Field boundary condition descriptor (for variables)
Definition: cs_field.h:104
void cs_field_component_id_by_name(const char *name, int *f_id, int *c_id)
Return the id of a defined field and an associated component based on a component name...
Definition: cs_field.c:2408
void cs_field_destroy_all(void)
Destroy all defined fields.
Definition: cs_field.c:2226
const char * name
Definition: cs_field.h:127
Definition: cs_field.h:95
void cs_field_key_disable_setup_log(int key_id)
Disable logging setup values associated with a given key.
Definition: cs_field.c:2813
void cs_field_log_key_vals(int key_id, bool log_defaults)
Print info relative to a given field key to log file.
Definition: cs_field.c:4110
cs_real_t * bd
Definition: cs_field.h:113
cs_real_t ** vals
Definition: cs_field.h:138
Definition: cs_field.h:92
Definition: cs_field.h:97
cs_real_t * bf
Definition: cs_field.h:111
int type
Definition: cs_field.h:130
int cs_field_set_key_str(cs_field_t *f, int key_id, const char *str)
Assign a character string for a given key to a field.
Definition: cs_field.c:3241
bool cs_field_is_key_locked(const cs_field_t *f, int key_id)
Query if a given key has been locked for a field.
Definition: cs_field.c:2866
Definition: cs_field.h:93
void cs_field_allocate_bc_coeffs(cs_field_t *f, bool have_flux_bc, bool have_mom_bc, bool have_conv_bc, bool have_exch_bc)
Allocate boundary condition coefficients arrays.
Definition: cs_field.c:1797
cs_field_t * cs_field_create(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Create a field descriptor.
Definition: cs_field.c:1548
int cs_field_set_key_int_bits(cs_field_t *f, int key_id, int mask)
Set integer bits matching a mask to 1 for a given key for a field.
Definition: cs_field.c:3062
int cs_field_clear_key_int_bits(cs_field_t *f, int key_id, int mask)
Set integer bits matching a mask to 0 for a given key for a field.
Definition: cs_field.c:3093
int cs_field_id_by_name(const char *name)
Return the id of a defined field based on its name.
Definition: cs_field.c:2387
int id
Definition: cs_field.h:129
cs_real_t * ad
Definition: cs_field.h:112
void cs_field_destroy_all_keys(void)
Destroy all defined field keys and associated values.
Definition: cs_field.c:2757
void * cs_field_get_key_struct_ptr(cs_field_t *f, int key_id)
Return a pointer to a simple structure for a given key to a field.
Definition: cs_field.c:3487
void cs_field_set_values(cs_field_t *f, cs_real_t c)
Set current field values to the given constant.
Definition: cs_field.c:2141
int cs_field_define_key_double(const char *name, double default_value, int type_flag)
Define a key for an floating point value by its name and return an associated id. ...
Definition: cs_field.c:2589
cs_real_t * bc
Definition: cs_field.h:115
Definition: cs_field.c:2338
int n_time_vals
Definition: cs_field.h:136
int cs_field_n_fields(void)
Definition: cs_field.c:1528
const char * cs_field_get_label(const cs_field_t *f)
Return a label associated with a field.
Definition: cs_field.c:4291
Definition: cs_defs.h:496
cs_real_t * ac
Definition: cs_field.h:114
Definition: cs_field.h:96
int cs_field_set_key_struct(cs_field_t *f, int key_id, void *s)
Assign a simple structure for a given key to a field.
Definition: cs_field.c:3362
void cs_field_set_n_time_vals(cs_field_t *f, int n_time_vals)
Change the number of time values managed by a field.
Definition: cs_field.c:1652
cs_field_t * cs_field_find_or_create(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Return a field matching a given name and attributes, creating it if necessary.
Definition: cs_field.c:1592
void cs_field_log_key_defs(void)
Print info relative to all key definitions to log file.
Definition: cs_field.c:3957
cs_real_t * af
Definition: cs_field.h:110
int location_id
Definition: cs_field.h:106
cs_real_t * hint
Definition: cs_field.h:117
void cs_field_log_fields(int log_keywords)
Print info relative to all defined fields to log file.
Definition: cs_field.c:3896
void cs_field_log_info(const cs_field_t *f, int log_keywords)
Print info relative to a given field to log file.
Definition: cs_field.c:3762
void cs_field_current_to_previous(cs_field_t *f)
Copy current field values to previous values if applicable.
Definition: cs_field.c:2168
Return a pointer to a field based on its name if present.
Definition: cs_field.c:2364
void() cs_field_clear_key_struct_t(void *t)
Definition: cs_field.h:178
Definition: cs_field.h:94
int cs_field_define_key_struct(const char *name, const void *default_value, cs_field_log_key_struct_t *log_func, cs_field_log_key_struct_t *log_func_default, cs_field_clear_key_struct_t *clear_func, size_t size, int type_flag)
Define a key for a structure value by its name and return an associated id.
Definition: cs_field.c:2678
bool is_owner
Definition: cs_field.h:156
Definition: cs_field.c:2314
double cs_field_get_key_double(const cs_field_t *f, int key_id)
Return a floating point value for a given key associated with a field.
Definition: cs_field.c:3171
int cs_field_define_key_int(const char *name, int default_value, int type_flag)
Define a key for an integer value by its name and return an associated id.
Definition: cs_field.c:2552
cs_field_error_type_t
Definition: cs_field.h:89
cs_real_t * a
Definition: cs_field.h:108
const void * cs_field_get_key_struct_const_ptr(const cs_field_t *f, int key_id)
Return a read-only pointer to a simple structure for a given key to a field.
Definition: cs_field.c:3565
void() cs_field_log_key_struct_t(const void *t)
Definition: cs_field.h:168
