#include "cs_cdo_connect.h"#include "cs_cdo_quantities.h"#include "cs_equation_param.h"#include "cs_equation_common.h"#include "cs_field.h"#include "cs_mesh.h"#include "cs_restart.h"#include "cs_time_step.h"
Include dependency graph for cs_equation.h:Go to the source code of this file.
| int | cs_equation_get_n_equations (void) |
| Retrieve the number of equations. More... | |
| cs_equation_t * | cs_equation_by_name (const char *eqname) |
| Find the cs_equation_t structure with name eqname Return NULL if not find. More... | |
| cs_equation_t * | cs_equation_by_field_name (const char *field_name) |
| Return the pointer to a cs_equation_t structure thanks to the field name of the variable field associated to a cs_equation_t structure. More... | |
| bool | cs_equation_has_field_name (const cs_equation_t *eq, const char *fld_name) |
| Check if the asociated field to a cs_equation_t structure has name equal to fld_name. More... | |
| cs_equation_param_t * | cs_equation_param_by_name (const char *eqname) |
| Return the cs_equation_param_t structure associated to a cs_equation_t structure thanks to the equation name. More... | |
| cs_equation_param_t * | cs_equation_param_by_field_name (const char *field_name) |
| Return the cs_equation_param_t structure related to a cs_equation_t structure thanks to the field name of the variable field associated to a cs_equation_t structure. More... | |
| cs_equation_param_t * | cs_equation_get_param (const cs_equation_t *eq) |
| Return the cs_equation_param_t structure associated to a cs_equation_t structure. More... | |
| cs_equation_t * | cs_equation_by_id (int eq_id) |
| Find the cs_equation_t structure with id eq_id Return NULL if not find. More... | |
| const char * | cs_equation_get_name (const cs_equation_t *eq) |
| Return the name related to the given cs_equation_t structure. More... | |
| int | cs_equation_get_id (const cs_equation_t *eq) |
| Return the id number related to the given cs_equation_t structure. More... | |
| cs_field_t * | cs_equation_get_field (const cs_equation_t *eq) |
| Return the field structure associated to a cs_equation_t structure. More... | |
| int | cs_equation_get_field_id (const cs_equation_t *eq) |
| Return the id related to the variable field structure associated to the cs_equation_t structure. More... | |
| const cs_range_set_t * | cs_equation_get_range_set (const cs_equation_t *eq) |
| Return the range set structure associated to a cs_equation_t structure. More... | |
| cs_gnum_t | cs_equation_get_global_n_dofs (const cs_equation_t *eq, const cs_cdo_quantities_t *cdoq) |
| Return the global number of degrees of freedom associated to this cs_equation_t structure. More... | |
| cs_field_t * | cs_equation_get_boundary_flux (const cs_equation_t *eq) |
| Return the field structure for the (normal) boundary flux associated to a cs_equation_t structure. More... | |
| cs_flag_t | cs_equation_get_flag (const cs_equation_t *eq) |
| Return the flag associated to an equation. More... | |
| void | cs_equation_set_flag (cs_equation_t *eq, cs_flag_t flag) |
| Redefine the flag associated to an equation. More... | |
| void | cs_equation_add_user_hook (cs_equation_t *eq, void *context, cs_equation_user_hook_t *func) |
| Add a user hook to enable an advanced user to get a fine control of the cellwise system building. Only for an advanced usage. The context may be set to NULL if there is no need to get additional information. More... | |
| cs_equation_builder_t * | cs_equation_get_builder (const cs_equation_t *eq) |
| Return the cs_equation_builder_t structure associated to a cs_equation_t structure. Only for an advanced usage. More... | |
| void * | cs_equation_get_scheme_context (const cs_equation_t *eq) |
| Return a pointer to a structure useful to handle low-level operations for the given equation. More... | |
| bool | cs_equation_is_steady (const cs_equation_t *eq) |
| Return true is the given equation is steady otherwise false. More... | |
| bool | cs_equation_uses_new_mechanism (const cs_equation_t *eq) |
| cs_equation_t * | cs_equation_add (const char *eqname, const char *varname, cs_equation_type_t eqtype, int dim, cs_param_bc_type_t default_bc) |
| Add a new equation structure and set a first set of parameters. More... | |
| cs_equation_t * | cs_equation_add_user (const char *eqname, const char *varname, int dim, cs_param_bc_type_t default_bc) |
| Add a new user equation structure and set a first set of parameters. More... | |
| void | cs_equation_destroy_all (void) |
| Destroy all cs_equation_t structures. More... | |
| bool | cs_equation_needs_steady_state_solve (void) |
| Check if a steady-state computation is requested according to the setting. More... | |
| void | cs_equation_log_monitoring (void) |
| Print a synthesis of the monitoring information in the performance file. More... | |
| void | cs_equation_get_count (int *n_equations, int *n_predef_equations, int *n_user_equations) |
| Get the count of equations of each macro type. More... | |
| void | cs_equation_log_setup (void) |
| Summarize all cs_equation_t structures. More... | |
| void | cs_equation_set_default_param (cs_equation_key_t key, const char *keyval) |
| Set a parameter attached to a keyname for the default settigns. More... | |
| void | cs_equation_set_sles (void) |
| Setup the linear algebra requirements. More... | |
| void | cs_equation_set_shared_structures (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t hho_scheme_flag) |
| Set shared structures among the activated class of discretization schemes. More... | |
| void | cs_equation_unset_shared_structures (cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t hho_scheme_flag) |
| Release shared structures among the activated class of discretization schemes. More... | |
| void | cs_equation_set_range_set (const cs_cdo_connect_t *connect) |
| Assign a cs_range_set_t structures for synchronization when computing in parallel mode. More... | |
| bool | cs_equation_set_functions (void) |
| Assign a set of pointer functions for managing the cs_equation_t structure during the computation After this call, parameters related to an equation are set once for all. More... | |
| void | cs_equation_create_fields (void) |
| Create a field structure related to all cs_equation_t structures. More... | |
| void | cs_equation_initialize (const cs_mesh_t *mesh, const cs_time_step_t *ts, const cs_cdo_quantities_t *quant, cs_cdo_connect_t *connect) |
| Allocate and initialize the builder of the algebraic system. Set the initialize condition to all variable fields associated to each cs_equation_t structure. More... | |
| void | cs_equation_solve_steady_state (const cs_mesh_t *mesh, cs_equation_t *eq) |
| Build and then solve the linear system for this equation when the goal is to find the steady state. More... | |
| void | cs_equation_solve (bool cur2prev, const cs_mesh_t *mesh, cs_equation_t *eq) |
| Build and then solve the linear system for an equation with an unsteady term. More... | |
| void | cs_equation_build_system (const cs_mesh_t *mesh, cs_equation_t *eq) |
| Build the linear system for this equation. More... | |
| void | cs_equation_solve_deprecated (cs_equation_t *eq) |
| Solve the linear system for this equation. More... | |
| cs_property_t * | cs_equation_get_diffusion_property (const cs_equation_t *eq) |
| Return a pointer to the cs_property_t structure associated to the diffusion term for this equation (NULL if not activated). More... | |
| cs_property_t * | cs_equation_get_time_property (const cs_equation_t *eq) |
| Return a pointer to the cs_property_t structure associated to the unsteady term for this equation (NULL if not activated). More... | |
| cs_property_t * | cs_equation_get_reaction_property (const cs_equation_t *eq, const int reaction_id) |
| Return a pointer to the cs_property_t structure associated to the reaction term with id equal to reaction_id and related to this equation. More... | |
| cs_param_time_scheme_t | cs_equation_get_time_scheme (const cs_equation_t *eq) |
| Return the type of numerical scheme used for the discretization in time. More... | |
| cs_real_t | cs_equation_get_theta_time_val (const cs_equation_t *eq) |
| Return the value of the theta parameter in theta time scheme discretization. More... | |
| cs_param_space_scheme_t | cs_equation_get_space_scheme (const cs_equation_t *eq) |
| Return the type of numerical scheme used for the discretization in space. More... | |
| int | cs_equation_get_space_poly_degree (const cs_equation_t *eq) |
| Return the max. degree used in the polynomial basis for the space discretization. More... | |
| int | cs_equation_get_var_dim (const cs_equation_t *eq) |
| Return the dimension of the variable solved by this equation. More... | |
| cs_equation_type_t | cs_equation_get_type (const cs_equation_t *eq) |
| Return the type of equation for the given equation structure. More... | |
| void | cs_equation_current_to_previous (const cs_equation_t *eq) |
| Apply the current to previous to all fields (and potentially arrays) related to an equation. This function fas to be called when a solve step is called with the parameter: cur2prev = false. More... | |
| void | cs_equation_get_cellwise_builders (const cs_equation_t *eq, cs_cell_sys_t **csys, cs_cell_builder_t **cb) |
| For a given equation, retrieve the related cellwise builder structures: cs_cell_builder_t and cs_cell_system_t structures. More... | |
| cs_real_t * | cs_equation_get_cell_values (const cs_equation_t *eq, bool previous) |
| For a given equation, retrieve an array of values related to each cell of the mesh for the unknowns. More... | |
| cs_real_t * | cs_equation_get_face_values (const cs_equation_t *eq, bool previous) |
| For a given equation, retrieve an array of values related to each face of the mesh for the unknowns. More... | |
| cs_real_t * | cs_equation_get_edge_values (const cs_equation_t *eq, bool previous) |
| For a given equation, retrieve an array of values related to each edge of the mesh for the unknowns. More... | |
| cs_real_t * | cs_equation_get_vertex_values (const cs_equation_t *eq, bool previous) |
| For a given equation, retrieve an array of values related to each vertex of the mesh for the unknowns. More... | |
| void | cs_equation_integrate_variable (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, cs_real_t *result) |
| Compute the integral over the domain of the variable field associated to the given equation. More... | |
| void | cs_equation_compute_boundary_diff_flux (cs_real_t t_eval, const cs_equation_t *eq, cs_real_t *diff_flux) |
| Compute the diffusive flux across all boundary faces According to the space discretization scheme, the size of the resulting array differs. For Vb and VCb schemes, this array relies on the bf2v adjacency. More... | |
| void | cs_equation_compute_flux_across_plane (const cs_equation_t *eq, const char *ml_name, const cs_real_3_t direction, cs_real_t *diff_flux, cs_real_t *conv_flux) |
| Compute the diffusive and convective flux across a plane defined by a mesh location structure attached to the name ml_name. More... | |
| void | cs_equation_compute_diff_flux_cellwise (const cs_equation_t *eq, cs_flag_t location, cs_real_t t_eval, cs_real_t *diff_flux) |
| Cellwise computation of the diffusive flux across all cell faces. Primal or dual faces are considered according to the space scheme. More... | |
| void | cs_equation_compute_vtx_field_gradient (const cs_equation_t *eq, cs_real_t *v_gradient) |
| Cellwise computation of the discrete gradient at vertices. More... | |
| void | cs_equation_compute_peclet (const cs_equation_t *eq, const cs_time_step_t *ts, cs_real_t peclet[]) |
| Compute and post-process Peclet number if requested. More... | |
| void | cs_equation_read_extra_restart (cs_restart_t *restart) |
| Write into the restart file additionnal arrays (not defined as fields) but useful for the checkpoint/restart process. More... | |
| void | cs_equation_write_extra_restart (cs_restart_t *restart) |
| void | cs_equation_post_balance (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *ts) |
| Predefined extra-operations related to all equations. More... | |
| void | cs_equation_extra_post (void) |
| Predefined extra-operations related to equations according to the type of numerical scheme (for the space discretization) More... | |
| cs_equation_t* cs_equation_add | ( | const char * | eqname, |
| const char * | varname, | ||
| cs_equation_type_t | eqtype, | ||
| int | dim, | ||
| cs_param_bc_type_t | default_bc | ||
| [in] | varname | name of the variable associated to this equation |
| [in] | eqtype | type of equation (user, predefined...) |
| [in] | dim | dimension of the unknow attached to this equation |
| [in] | default_bc | type of boundary condition set by default |
| cs_equation_t* cs_equation_add_user | ( | const char * | eqname, |
| int | dim, | ||
| void cs_equation_add_user_hook | ( | cs_equation_t * | eq, |
| void * | context, | ||
| cs_equation_user_hook_t * | func | ||
| [in,out] | eq | pointer to the cs_equation_t stucture to update |
| [in] | context | pointer to a structure for additional information |
| [in] | func | pointer to the user function |
| void cs_equation_build_system | ( | const cs_mesh_t * | mesh, |
| cs_equation_t * | eq | ||
| [in,out] | eq | pointer to a cs_equation_t structure |
| cs_equation_t* cs_equation_by_field_name | ( | const char * | field_name | ) |
| [in] | field_name | name of the field |
| cs_equation_t* cs_equation_by_id | ( | int | eq_id | ) |
| [in] | eq_id | id of the equation to find |
| cs_equation_t* cs_equation_by_name | ( | const char * | eqname | ) |
| [in] | eqname | name of the equation to find |
| void cs_equation_compute_boundary_diff_flux | ( | cs_real_t | t_eval, |
| const cs_equation_t * | eq, | ||
| cs_real_t * | diff_flux | ||
| [in] | t_eval | time at which one performs the property evaluation |
| [in] | eq | pointer to a cs_equation_t structure |
| [in,out] | diff_flux | value of the diffusive part of the flux |
| void cs_equation_compute_diff_flux_cellwise | ( | const cs_equation_t * | eq, |
| cs_flag_t | location, | ||
| cs_real_t | t_eval, | ||
| [in] | location | indicate where the flux has to be computed |
| [in,out] | diff_flux | value of the diffusive flux |
| void cs_equation_compute_flux_across_plane | ( | const cs_equation_t * | eq, |
| const char * | ml_name, | ||
| const cs_real_3_t | direction, | ||
| cs_real_t * | diff_flux, | ||
| cs_real_t * | conv_flux | ||
| [in] | ml_name | name of the related mesh location |
| [in] | direction | vector indicating in which direction flux is > 0 |
| [in,out] | conv_flux | value of the convective part of the flux |
| void cs_equation_compute_peclet | ( | const cs_equation_t * | eq, |
| cs_real_t | peclet[] | ||
| [in,out] | peclet | pointer to an array storing the resulting Peclet number in each cell |
| void cs_equation_compute_vtx_field_gradient | ( | const cs_equation_t * | eq, |
| cs_real_t * | v_gradient | ||
| [in,out] | v_gradient | gradient at vertices |
| void cs_equation_create_fields | ( | void | ) |
| void cs_equation_current_to_previous | ( | const cs_equation_t * | eq | ) |
| void cs_equation_destroy_all | ( | void | ) |
| void cs_equation_extra_post | ( | void | ) |
| cs_field_t* cs_equation_get_boundary_flux | ( | const cs_equation_t * | eq | ) |
| cs_equation_builder_t* cs_equation_get_builder | ( | const cs_equation_t * | eq | ) |
| cs_real_t* cs_equation_get_cell_values | ( | const cs_equation_t * | eq, |
| bool | previous | ||
| void cs_equation_get_cellwise_builders | ( | const cs_equation_t * | eq, |
| cs_cell_sys_t ** | csys, | ||
| [out] | cb | pointer to a pointer on a cs_cell_sys_t structure |
| [out] | csys | pointer to a pointer on a cs_cell_builder_t structure |
| void cs_equation_get_count | ( | int * | n_equations, |
| int * | n_predef_equations, | ||
| int * | n_user_equations | ||
| [out] | n_equations | total number of equations |
| [out] | n_predef_equations | number of predefined equations |
| [out] | n_user_equations | number of user equations |
| cs_property_t* cs_equation_get_diffusion_property | ( | const cs_equation_t * | eq | ) |
| cs_real_t* cs_equation_get_edge_values | ( | const cs_equation_t * | eq, |
| cs_real_t* cs_equation_get_face_values | ( | const cs_equation_t * | eq, |
| cs_field_t* cs_equation_get_field | ( | const cs_equation_t * | eq | ) |
| int cs_equation_get_field_id | ( | const cs_equation_t * | eq | ) |
| cs_flag_t cs_equation_get_flag | ( | const cs_equation_t * | eq | ) |
| cs_gnum_t cs_equation_get_global_n_dofs | ( | const cs_equation_t * | eq, |
| int cs_equation_get_id | ( | const cs_equation_t * | eq | ) |
| int cs_equation_get_n_equations | ( | void | ) |
| const char* cs_equation_get_name | ( | const cs_equation_t * | eq | ) |
| cs_equation_param_t* cs_equation_get_param | ( | const cs_equation_t * | eq | ) |
| const cs_range_set_t* cs_equation_get_range_set | ( | const cs_equation_t * | eq | ) |
| cs_property_t* cs_equation_get_reaction_property | ( | const cs_equation_t * | eq, |
| const int | reaction_id | ||
| [in] | reaction_id | id related to this reaction term |
| void* cs_equation_get_scheme_context | ( | const cs_equation_t * | eq | ) |
| int cs_equation_get_space_poly_degree | ( | const cs_equation_t * | eq | ) |
| cs_param_space_scheme_t cs_equation_get_space_scheme | ( | const cs_equation_t * | eq | ) |
| cs_real_t cs_equation_get_theta_time_val | ( | const cs_equation_t * | eq | ) |
| cs_property_t* cs_equation_get_time_property | ( | const cs_equation_t * | eq | ) |
| cs_param_time_scheme_t cs_equation_get_time_scheme | ( | const cs_equation_t * | eq | ) |
| cs_equation_type_t cs_equation_get_type | ( | const cs_equation_t * | eq | ) |
| int cs_equation_get_var_dim | ( | const cs_equation_t * | eq | ) |
| cs_real_t* cs_equation_get_vertex_values | ( | const cs_equation_t * | eq, |
| bool cs_equation_has_field_name | ( | const cs_equation_t * | eq, |
| const char * | fld_name | ||
| [in] | eq | pointer to a cs_equation_t structure to test |
| [in] | fld_name | name of the field |
| void cs_equation_initialize | ( | const cs_mesh_t * | mesh, |
| cs_cdo_connect_t * | connect | ||
| [in,out] | connect | pointer to a cs_cdo_connect_t structure |
| void cs_equation_integrate_variable | ( | const cs_cdo_connect_t * | connect, |
| cs_real_t * | result | ||
| [in,out] | integral | result of the computation |
| bool cs_equation_is_steady | ( | const cs_equation_t * | eq | ) |
| void cs_equation_log_monitoring | ( | void | ) |
| void cs_equation_log_setup | ( | void | ) |
| bool cs_equation_needs_steady_state_solve | ( | void | ) |
| cs_equation_param_t* cs_equation_param_by_field_name | ( | const char * | field_name | ) |
| cs_equation_param_t* cs_equation_param_by_name | ( | const char * | eqname | ) |
| void cs_equation_post_balance | ( | const cs_mesh_t * | mesh, |
| void cs_equation_read_extra_restart | ( | cs_restart_t * | restart | ) |
| [in,out] | restart | pointer to a cs_restart_t structure |
| void cs_equation_set_default_param | ( | cs_equation_key_t | key, |
| const char * | keyval | ||
| void cs_equation_set_flag | ( | cs_equation_t * | eq, |
| cs_flag_t | flag | ||
| [in] | flag | new flag to set |
| bool cs_equation_set_functions | ( | void | ) |
| void cs_equation_set_range_set | ( | const cs_cdo_connect_t * | connect | ) |
| void cs_equation_set_shared_structures | ( | const cs_cdo_connect_t * | connect, |
| cs_flag_t | eb_scheme_flag, | ||
| cs_flag_t | fb_scheme_flag, | ||
| cs_flag_t | vb_scheme_flag, | ||
| cs_flag_t | vcb_scheme_flag, | ||
| cs_flag_t | hho_scheme_flag | ||
| [in] | quant | pointer to additional mesh quantities struct. |
| [in] | eb_scheme_flag | metadata for Eb schemes |
| [in] | fb_scheme_flag | metadata for Fb schemes |
| [in] | vb_scheme_flag | metadata for Vb schemes |
| [in] | vcb_scheme_flag | metadata for V+C schemes |
| [in] | hho_scheme_flag | metadata for HHO schemes |
| void cs_equation_set_sles | ( | void | ) |
| void cs_equation_solve | ( | bool | cur2prev, |
| void cs_equation_solve_deprecated | ( | cs_equation_t * | eq | ) |
| void cs_equation_solve_steady_state | ( | const cs_mesh_t * | mesh, |
| void cs_equation_unset_shared_structures | ( | cs_flag_t | vb_scheme_flag, |
| bool cs_equation_uses_new_mechanism | ( | const cs_equation_t * | eq | ) |
| void cs_equation_write_extra_restart | ( | cs_restart_t * | restart | ) |
