1 #ifndef __CS_CDOFB_NAVSTO_H__ 2 #define __CS_CDOFB_NAVSTO_H__ 107 for (
short int f = 0; f < cm->
n_fc; f++) {
113 _div_f[0] = i_f * pfq.
unitv[0];
114 _div_f[1] = i_f * pfq.
unitv[1];
115 _div_f[2] = i_f * pfq.
unitv[2];
void cs_cdofb_navsto_define_builder(cs_real_t t_eval, const cs_navsto_param_t *nsp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, const cs_cdo_bc_face_t *pr_bc, const cs_boundary_type_t *bf_type, cs_cdofb_navsto_builder_t *nsb)
Set the members of the cs_cdofb_navsto_builder_t structure.
Definition: cs_cdofb_navsto.c:290
time step descriptor
Definition: cs_time_step.h:64
void cs_cdofb_block_dirichlet_wsym(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account a Dirichlet BCs on the three velocity components. For instance for a velocity inlet...
Definition: cs_cdofb_navsto.c:1441
int cs_boundary_type_t
Definition: cs_boundary.h:69
cs_cdofb_navsto_builder_t cs_cdofb_navsto_create_builder(const cs_navsto_param_t *nsp, const cs_cdo_connect_t *connect)
Create and allocate a local NavSto builder when Fb schemes are used.
Definition: cs_cdofb_navsto.c:236
Definition: cs_advection_field.h:149
void cs_cdofb_navsto_rescale_pressure_to_ref(const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, cs_real_t values[])
Update the pressure field in order to get a field with a mean-value equal to the reference value...
Definition: cs_cdofb_navsto.c:791
Definition: cs_field.h:125
void cs_cdofb_symmetry(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account a symmetric boundary (treated as a sliding BCs on the three velocity components...
Definition: cs_cdofb_navsto.c:1538
Definition: cs_equation_param.h:202
void cs_cdofb_navsto_add_grad_div(short int n_fc, const cs_real_t zeta, const cs_real_t div[], cs_sdm_t *mat)
Add the grad-div part to the local matrix (i.e. for the current cell)
Definition: cs_cdofb_navsto.c:525
void cs_cdofb_navsto_extra_op(const cs_navsto_param_t *nsp, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *ts, const cs_adv_field_t *adv_field, const cs_real_t *mass_flux, const cs_real_t *u_cell, const cs_real_t *u_face)
Perform extra-operation related to Fb schemes when solving Navier-Stokes.
Definition: cs_cdofb_navsto.c:887
cs_real_t * pressure_bc_val
Definition: cs_cdofb_navsto.h:79
Structure storing the evaluation of a property and its related data.
Definition: cs_property.h:178
Definition: cs_mesh_adjacencies.h:67
Definition: cs_defs.h:495
double meas
Definition: cs_cdo_quantities.h:118
void cs_cdofb_navsto_boussinesq_source_term(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Get the source term for computing the Boussinesq approximation This relies on the prototype associate...
Definition: cs_cdofb_navsto.c:1685
cs_real_t rho_c
Definition: cs_cdofb_navsto.h:71
void cs_cdofb_block_dirichlet_pena(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdofb_navsto.c:1293
Set of local quantities and connectivities related to a mesh cell This is a key structure for all cel...
Definition: cs_cdo_local.h:159
void cs_cdofb_navsto_free_builder(cs_cdofb_navsto_builder_t *nsb)
Destroy the given cs_cdofb_navsto_builder_t structure.
Definition: cs_cdofb_navsto.c:266
Definition: cs_navsto_param.h:540
cs_real_t * div_op
Definition: cs_cdofb_navsto.h:74
Definition: cs_defs.h:307
Definition: cs_cdo_local.h:107
void cs_cdofb_navsto_init_pressure(const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, cs_field_t *pr)
Initialize the pressure values.
Definition: cs_cdofb_navsto.c:595
short int * f_sgn
Definition: cs_cdo_local.h:192
cs_real_t cs_cdofb_navsto_cell_divergence(const cs_lnum_t c_id, const cs_cdo_quantities_t *quant, const cs_adjacency_t *c2f, const cs_real_t *f_vals)
Compute the divergence of a cell using the cs_cdo_quantities_t structure.
Definition: cs_cdofb_navsto.c:488
void cs_cdofb_block_dirichlet_alge(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdofb_navsto.c:1193
void cs_cdofb_navsto_finalize(void)
Free allocated structures associated to this file.
Definition: cs_cdofb_navsto.c:426
short int n_fc
Definition: cs_cdo_local.h:189
Definition: cs_cdo_bc.h:88
void cs_cdofb_fixed_wall(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Take into account a wall BCs by a weak enforcement using Nitsche technique plus a symmetric treatment...
Definition: cs_cdofb_navsto.c:1642
Set of local and temporary buffers useful for building the algebraic system with a cellwise process...
Definition: cs_cdo_local.h:69
cs_quant_t * face
Definition: cs_cdo_local.h:195
void cs_cdofb_navsto_init_face_pressure(const cs_navsto_param_t *nsp, const cs_cdo_connect_t *connect, const cs_time_step_t *ts, cs_real_t *pr_f)
Initialize the pressure values when the pressure is defined at faces.
Definition: cs_cdofb_navsto.c:689
Definition: cs_cdo_quantities.h:116
Definition: cs_defs.h:301
double unitv[3]
Definition: cs_cdo_quantities.h:119
void cs_cdofb_navsto_mass_flux(const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, const cs_real_t *face_vel, cs_real_t *mass_flux)
Compute the mass flux playing the role of the advection field in the Navier-Stokes equations One cons...
Definition: cs_cdofb_navsto.c:447
Definition: cs_defs.h:496
void cs_cdofb_navsto_stream_source_term(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Get the source term for computing the stream function. This relies on the prototype associated to the...
Definition: cs_cdofb_navsto.c:1725
void cs_cdofb_block_dirichlet_weak(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Definition: cs_cdofb_navsto.c:1360
cs_boundary_type_t * bf_type
Definition: cs_cdofb_navsto.h:78
double precision, dimension(ncharm), save zeta
Definition: cpincl.f90:99
Definition: cs_cdofb_navsto.h:68
void cs_cdofb_navsto_set_zero_mean_pressure(const cs_cdo_quantities_t *quant, cs_real_t values[])
Update the pressure field in order to get a field with a zero-mean average.
Definition: cs_cdofb_navsto.c:829
