Build an algebraic CDO vertex-based system for unsteady convection-diffusion-reaction of scalar-valued equations with source terms. More...
#include <bft_mem.h>
#include "cs_boundary_zone.h"
#include "cs_cdo_advection.h"
#include "cs_cdo_bc.h"
#include "cs_cdo_diffusion.h"
#include "cs_cdo_local.h"
#include "cs_cdovb_priv.h"
#include "cs_equation_bc.h"
#include "cs_equation_common.h"
#include "cs_evaluate.h"
#include "cs_hodge.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_post.h"
#include "cs_quadrature.h"
#include "cs_reco.h"
#include "cs_scheme_geometry.h"
#include "cs_search.h"
#include "cs_sles.h"
#include "cs_source_term.h"
#include "cs_timer.h"
#include "cs_cdovb_scaleq.h"
Macros | |
#define | CS_CDOVB_SCALEQ_DBG 0 |
#define | _dp3 cs_math_3_dot_product |
bool | cs_cdovb_scaleq_is_initialized (void) |
Check if the generic structures for building a CDO-Vb scheme are allocated. More... | |
void | cs_cdovb_scaleq_init_common (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_structure_t *ms) |
Allocate work buffer and general structures related to CDO vertex-based schemes Set shared pointers. More... | |
void | cs_cdovb_scaleq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb) |
Retrieve work buffers used for building a CDO system cellwise. More... | |
void | cs_cdovb_scaleq_finalize_common (void) |
Free work buffer and general structure related to CDO vertex-based schemes. More... | |
void * | cs_cdovb_scaleq_init_context (const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb) |
Initialize a cs_cdovb_scaleq_t structure storing data useful for building and managing such a scheme. More... | |
void * | cs_cdovb_scaleq_free_context (void *builder) |
Destroy a cs_cdovb_scaleq_t structure. More... | |
void | cs_cdovb_scaleq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued CDO-Vb schemes. More... | |
void | cs_cdovb_scaleq_solve_steady_state (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Build and solve the linear system arising from a scalar steady-state convection/diffusion/reaction equation with a CDO-Vb scheme One works cellwise and then process to the assembly. More... | |
void | cs_cdovb_scaleq_solve_implicit (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Build and solve the linear system arising from a scalar unsteady convection/diffusion/reaction equation with a CDO-Vb scheme Implicit time scheme is used to progress in time. One works cellwise and then process to the assembly. More... | |
void | cs_cdovb_scaleq_solve_theta (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Build and solve the linear system arising from a scalar unsteady convection/diffusion/reaction equation with a CDO-Vb scheme Theta time scheme is used to progress in time. One works cellwise and then process to the assembly. More... | |
cs_real_t * | cs_cdovb_scaleq_get_vertex_values (void *context, bool previous) |
Retrieve an array of values at mesh vertices for the variable field associated to the given context The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
cs_real_t * | cs_cdovb_scaleq_get_cell_values (void *context, bool previous) |
Compute an array of values at mesh cells by interpolating the variable field associated to the given context located at mesh vertices The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
cs_equation_balance_t * | cs_cdovb_scaleq_balance (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Compute the balance for an equation over the full computational domain between time t_cur and t_cur + dt_cur Case of scalar-valued CDO vertex-based scheme. More... | |
void | cs_cdovb_scaleq_boundary_diff_flux (const cs_real_t t_eval, const cs_equation_param_t *eqp, const cs_real_t *pdi, cs_equation_builder_t *eqb, void *context, cs_real_t *vf_flux) |
Compute for each vertex of a boundary face, the portion of diffusive flux across the boundary face. The surface attached to each vertex corresponds to the intersection of its dual cell (associated to a vertex of the face) with the face. Case of scalar-valued CDO-Vb schemes. More... | |
void | cs_cdovb_scaleq_flux_across_plane (const cs_real_t normal[], const cs_real_t *pdi, const cs_equation_param_t *eqp, int ml_id, cs_equation_builder_t *eqb, void *context, double *d_flux, double *c_flux) |
Compute the diffusive and convective flux across a list of faces Case of scalar-valued CDO-Vb schemes. More... | |
void | cs_cdovb_scaleq_diff_flux_in_cells (const cs_real_t *values, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux) |
Cellwise computation of an approximation of a constant diffusive flux (a vector) in each cell. Case of scalar-valued CDO-Vb schemes. More... | |
void | cs_cdovb_scaleq_diff_flux_dfaces (const cs_real_t *values, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux) |
Cellwise computation of the diffusive flux accross dual faces (a scalar) in each cell. Case of scalar-valued CDO-Vb schemes. More... | |
void | cs_cdovb_scaleq_current_to_previous (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Operate a current to previous operation for the field associated to this equation and potentially for related fields/arrays. More... | |
void | cs_cdovb_scaleq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
Predefined extra-operations related to this equation. More... | |
#define _dp3 cs_math_3_dot_product |
#define CS_CDOVB_SCALEQ_DBG 0 |
cs_equation_balance_t* cs_cdovb_scaleq_balance | ( | const cs_equation_param_t * | eqp, |
cs_equation_builder_t * | eqb, | ||
void * | context | ||
[in] | eqp | pointer to a cs_equation_param_t structure |
[in,out] | eqb | pointer to a cs_equation_builder_t structure |
[in,out] | context | pointer to a scheme builder structure |
void cs_cdovb_scaleq_boundary_diff_flux | ( | const cs_real_t | t_eval, |
const cs_equation_param_t * | eqp, | ||
const cs_real_t * | pdi, | ||
void * | context, | ||
cs_real_t * | vf_flux | ||
[in] | t_eval | time at which one performs the evaluation |
[in] | pdi | pointer to an array of field values |
[in,out] | vf_flux | pointer to the values of the diffusive flux |
void cs_cdovb_scaleq_current_to_previous | ( | const cs_equation_param_t * | eqp, |
[in,out] | context | pointer to cs_cdovb_scaleq_t structure |
void cs_cdovb_scaleq_diff_flux_dfaces | ( | const cs_real_t * | values, |
cs_real_t | t_eval, | ||
cs_real_t * | diff_flux | ||
[in] | values | discrete values for the potential |
[in,out] | diff_flux | value of the diffusive flux |
void cs_cdovb_scaleq_diff_flux_in_cells | ( | const cs_real_t * | values, |
void cs_cdovb_scaleq_extra_post | ( | const cs_equation_param_t * | eqp, |
void cs_cdovb_scaleq_finalize_common | ( | void | ) |
void cs_cdovb_scaleq_flux_across_plane | ( | const cs_real_t | normal[], |
int | ml_id, | ||
double * | d_flux, | ||
double * | c_flux | ||
[in] | normal | indicate in which direction flux is > 0 |
[in] | ml_id | id related to a cs_mesh_location_t struct. |
[in,out] | context | pointer to data specific for this scheme |
[in,out] | d_flux | pointer to the value of the diffusive flux |
[in,out] | c_flux | pointer to the value of the convective flux |
void* cs_cdovb_scaleq_free_context | ( | void * | builder | ) |
[in,out] | builder | pointer to a cs_cdovb_scaleq_t structure |
void cs_cdovb_scaleq_get | ( | cs_cell_sys_t ** | csys, |
cs_cell_builder_t ** | cb | ||
[out] | csys | pointer to a pointer on a cs_cell_sys_t structure |
[out] | cb | pointer to a pointer on a cs_cell_builder_t structure |
cs_real_t* cs_cdovb_scaleq_get_cell_values | ( | void * | context, |
bool | previous | ||
[in,out] | context | pointer to a data structure cast on-the-fly |
[in] | previous | retrieve the previous state (true/false) |
cs_real_t* cs_cdovb_scaleq_get_vertex_values | ( | void * | context, |
void cs_cdovb_scaleq_init_common | ( | const cs_cdo_quantities_t * | quant, |
const cs_cdo_connect_t * | connect, | ||
const cs_time_step_t * | time_step, | ||
const cs_matrix_structure_t * | ms | ||
[in] | quant | additional mesh quantities struct. |
[in] | connect | pointer to a cs_cdo_connect_t struct. |
[in] | time_step | pointer to a time step structure |
[in] | ms | pointer to a cs_matrix_structure_t structure |
void* cs_cdovb_scaleq_init_context | ( | const cs_equation_param_t * | eqp, |
int | var_id, | ||
int | bflux_id, | ||
cs_equation_builder_t * | eqb | ||
[in] | var_id | id of the variable field |
[in] | bflux_id | id of the boundary flux field |
[in,out] | eqb | pointer to a cs_equation_builder_t struct. |
void cs_cdovb_scaleq_init_values | ( | cs_real_t | t_eval, |
const int | field_id, | ||
const cs_mesh_t * | mesh, | ||
[in] | t_eval | time at which one evaluates BCs |
[in] | field_id | id related to the variable field of this equation |
[in] | mesh | pointer to a cs_mesh_t structure |
[in,out] | context | pointer to the scheme context (cast on-the-fly) |
bool cs_cdovb_scaleq_is_initialized | ( | void | ) |
void cs_cdovb_scaleq_solve_implicit | ( | bool | cur2prev, |
[in] | cur2prev | true="current to previous" operation is performed |
[in] | field_id | id of the variable field related to this equation |
void cs_cdovb_scaleq_solve_steady_state | ( | bool | cur2prev, |
void cs_cdovb_scaleq_solve_theta | ( | bool | cur2prev, |
