1 #ifndef __CS_EQUATION_BC_H__ 2 #define __CS_EQUATION_BC_H__ void cs_equation_compute_circulation_eb(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, cs_real_t *values)
Compute the values of the tangential component lying on the domain boundary. Kind of BCs used when Do...
Definition: cs_equation_bc.c:1353
void cs_equation_compute_neumann_sv(cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
Compute the values of the Neumann BCs when DoFs are scalar-valued and attached to vertices...
Definition: cs_equation_bc.c:1086
void() cs_cdo_apply_boundary_t(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Apply a boundary condition for a given face (inlet, outlet, wall, sliding wall, symmetry...)
Definition: cs_equation_bc.h:68
void cs_equation_fb_set_cell_bc(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Set the BC into a cellwise view of the current system. Case of Face-based schemes.
Definition: cs_equation_bc.c:532
Definition: cs_equation_param.h:202
void() cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Enforcement of a boundary condition (Dirichlet, Robin, sliding...)
Definition: cs_equation_bc.h:89
Structure storing the evaluation of a property and its related data.
Definition: cs_property.h:178
void cs_equation_set_edge_bc_flag(const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *edge_flag)
Define an array of flags for each edge collecting the flags of associated boundary faces...
Definition: cs_equation_bc.c:1024
Definition: cs_defs.h:495
Set of local quantities and connectivities related to a mesh cell This is a key structure for all cel...
Definition: cs_cdo_local.h:159
Structure associated to a discrete Hodge operator.
Definition: cs_hodge.h:189
Definition: cs_defs.h:307
Definition: cs_cdo_local.h:107
Definition: cs_field_pointer.h:134
Definition: cs_cdo_bc.h:88
void cs_equation_compute_dirichlet_vb(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_cell_builder_t *cb, cs_flag_t *bcflag, cs_real_t *values)
Compute the values of the Dirichlet BCs when DoFs are attached to vertices.
Definition: cs_equation_bc.c:622
void cs_equation_compute_dirichlet_fb(const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_real_t t_eval, cs_cell_builder_t *cb, cs_real_t *values)
Compute the values of the Dirichlet BCs when DoFs are attached to CDO face-based schemes.
Definition: cs_equation_bc.c:796
void cs_equation_set_vertex_bc_flag(const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *vflag)
Define an array of flags for each vertex collecting the flags of associated boundary faces...
Definition: cs_equation_bc.c:964
Set of local and temporary buffers useful for building the algebraic system with a cellwise process...
Definition: cs_cdo_local.h:69
void cs_equation_vb_set_cell_bc(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_flag_t vtx_bc_flag[], const cs_real_t dir_values[], cs_real_t t_eval, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Set the BC into a cellwise view of the current system. Case of vertex-based schemes.
Definition: cs_equation_bc.c:362
void cs_equation_compute_neumann_fb(cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
Compute the values of the Neumann BCs when DoFs are attached to faces.
Definition: cs_equation_bc.c:1176
void cs_equation_eb_set_cell_bc(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Set the BC into a cellwise view of the current system. Case of edge-based schemes.
Definition: cs_equation_bc.c:464
Definition: cs_defs.h:496
unsigned short int cs_flag_t
Definition: cs_defs.h:309
void cs_equation_init_boundary_flux_from_bc(cs_real_t t_eval, const cs_cdo_quantities_t *cdoq, const cs_equation_param_t *eqp, cs_real_t *values)
Set the values for the normal boundary flux stemming from the Neumann boundary conditions (zero is le...
Definition: cs_equation_bc.c:274
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:227
void cs_equation_compute_robin(cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *rob_values)
Compute the values of the Robin BCs.
Definition: cs_equation_bc.c:1263
Structure and routines handling the specific settings related to a cs_equation_t structure.
