cs_xdef_eval.h File Reference
#include "cs_cdo_connect.h"
#include "cs_quadrature.h"
#include "cs_xdef.h"
+ Include dependency graph for cs_xdef_eval.h:
Typedefs
typedef void() cs_xdef_eval_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) More...
void cs_xdef_eval_scalar_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a scalar-valued quantity for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_vector_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a vector-valued quantity for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_symtens_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a tensor-valued quantity for a list of elements with symmetric storage. This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_tensor_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a tensor-valued quantity for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_scalar_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a scalar-valued quantity with only a time-dependent variation for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_vector_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a vector-valued quantity with only a time-dependent variation for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_symtens_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a tensor-valued quantity with a symmetric storage and with only a time-dependent variation for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_tensor_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a tensor-valued quantity with only a time-dependent variation for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_at_cells_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity defined at cells using an analytic function This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_at_b_faces_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity defined at border faces using an analytic function This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_at_vertices_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity defined at vertices using an analytic function This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_at_cells_by_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity defined at primal cells using a function associated to dof (dof = degrees of freedom). This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_at_vertices_by_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity defined at vertices using a function associated to dof (dof = degrees of freedom). This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_at_b_faces_by_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity defined at boundary faces using a function associated to dof (dof = degrees of freedom). This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_scalar_at_cells_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a scalar-valued quantity at cells defined by an array. Array is assumed to be interlaced. This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_nd_at_cells_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a nd-valued quantity at cells defined by an array. Array is assumed to be interlaced. This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_at_vertices_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity defined at vertices using an array This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_cell_by_field (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity inside a cell defined using a field This function complies with the generic function type defined as cs_xdef_eval_t. More...
void cs_xdef_eval_avg_at_b_faces_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, int dim, cs_real_t *eval)
 Evaluate a quantity defined at border faces using an analytic function. More...
Typedef Documentation
◆ cs_xdef_eval_t
[in]n_eltsnumber of elements to consider
[in]elt_idslist of element ids
[in]dense_outputperform an indirection for output (true/false)
[in]contextNULL or pointer to a context structure
[in,out]evalarray storing the result (must be allocated)
◆ cs_xdef_eval_at_b_faces_by_analytic()
void cs_xdef_eval_at_b_faces_by_analytic ( cs_lnum_t  n_elts,
const cs_lnum_t elt_ids,
bool  dense_output,
const cs_mesh_t mesh,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_at_b_faces_by_dof_func()
void cs_xdef_eval_at_b_faces_by_dof_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_at_cells_by_analytic()
void cs_xdef_eval_at_cells_by_analytic ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_at_cells_by_dof_func()
void cs_xdef_eval_at_cells_by_dof_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_at_vertices_by_analytic()
void cs_xdef_eval_at_vertices_by_analytic ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_at_vertices_by_array()
void cs_xdef_eval_at_vertices_by_array ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_at_vertices_by_dof_func()
void cs_xdef_eval_at_vertices_by_dof_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_avg_at_b_faces_by_analytic()
void cs_xdef_eval_avg_at_b_faces_by_analytic ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
int  dim,
cs_real_t eval
[in]qtypequadrature type
[in]dimdimension of the analytic function return
◆ cs_xdef_eval_cell_by_field()
void cs_xdef_eval_cell_by_field ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_nd_at_cells_by_array()
void cs_xdef_eval_nd_at_cells_by_array ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_scalar_at_cells_by_array()
void cs_xdef_eval_scalar_at_cells_by_array ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_scalar_at_cells_by_time_func()
void cs_xdef_eval_scalar_at_cells_by_time_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_scalar_by_val()
void cs_xdef_eval_scalar_by_val ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_symtens_at_cells_by_time_func()
void cs_xdef_eval_symtens_at_cells_by_time_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_symtens_by_val()
void cs_xdef_eval_symtens_by_val ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_tensor_at_cells_by_time_func()
void cs_xdef_eval_tensor_at_cells_by_time_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_tensor_by_val()
void cs_xdef_eval_tensor_by_val ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_vector_at_cells_by_time_func()
void cs_xdef_eval_vector_at_cells_by_time_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
◆ cs_xdef_eval_vector_by_val()
void cs_xdef_eval_vector_by_val ( cs_lnum_t  n_elts,
bool  dense_output,
void *  context,
cs_real_t eval
