1 #ifndef __CS_SOURCE_TERM_H__ 2 #define __CS_SOURCE_TERM_H__ 49 #define CS_N_MAX_SOURCE_TERMS 8 // Max number of source terms in an equation 171 const int n_source_terms,
cs_real_t * var
Definition: cs_source_term.h:66
void cs_source_term_dcsd_q5o3_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution for a cell related to a source term and add it to the given array of values...
Definition: cs_source_term.c:1583
cs_flag_t cs_source_term_get_flag(const cs_xdef_t *st)
Get metadata related to the given source term structure.
Definition: cs_source_term.c:467
void cs_source_term_pcvd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2192
cs_eflag_t cs_source_term_init(cs_param_space_scheme_t space_scheme, const int n_source_terms, cs_xdef_t *const *source_terms, cs_source_term_cellwise_t *compute_source[], cs_flag_t *sys_flag, cs_mask_t *source_mask[])
Initialize data to build the source terms.
Definition: cs_source_term.c:492
cs_real_t rho0
Definition: cs_source_term.h:63
void cs_source_term_hhovd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution of a source term for a cell and add it to the given array of values...
Definition: cs_source_term.c:2673
unsigned char cs_mask_t
Definition: cs_flag.h:143
void cs_source_term_dcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1194
void cs_source_term_pvsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:910
void cs_source_term_hhosd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2551
Definition: cs_defs.h:495
void cs_source_term_dcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1017
Set of local quantities and connectivities related to a mesh cell This is a key structure for all cel...
Definition: cs_cdo_local.h:159
void cs_source_term_dcsd_q10o2_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1381
cs_real_t beta
Definition: cs_source_term.h:64
void cs_source_term_dcsd_q1o1_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1300
Definition: cs_defs.h:307
void cs_source_term_pcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1794
void cs_source_term_dfsf_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2791
Definition: cs_param_types.h:172
void cs_source_term_set_reduction(cs_xdef_t *st, cs_flag_t flag)
Set advanced parameters which are defined by default in a source term structure.
Definition: cs_source_term.c:412
cs_real_t var0
Definition: cs_source_term.h:65
void cs_source_term_set_shared_pointers(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition: cs_source_term.c:344
Structure storing the parameters related to the Boussinesq source term.
Definition: cs_source_term.h:60
void cs_source_term_pcvd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1881
void cs_source_term_vcsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1736
void cs_source_term_pvsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:965
void cs_source_term_pcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution for a cell related to a source term and add it the given array of values...
Definition: cs_source_term.c:1931
void cs_source_term_dcsd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1099
void cs_source_term_pcsd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1833
void cs_source_term_hhosd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2422
Set of local and temporary buffers useful for building the algebraic system with a cellwise process...
Definition: cs_cdo_local.h:69
Definition: cs_xdef.h:154
void cs_source_term_dcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1058
void cs_source_term_pcsd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2020
void cs_source_term_set_default_flag(cs_param_space_scheme_t scheme, cs_flag_t *state_flag, cs_flag_t *meta_flag)
Set the default flag related to a source term according to the numerical scheme chosen for discretizi...
Definition: cs_source_term.c:364
void cs_source_term_pcvd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2242
Definition: cs_defs.h:496
unsigned short int cs_flag_t
Definition: cs_defs.h:309
void cs_source_term_compute_cellwise(const int n_source_terms, cs_xdef_t *const *source_terms, const cs_cell_mesh_t *cm, const cs_mask_t *source_mask, cs_source_term_cellwise_t *compute_source[], cs_real_t time_eval, void *input, cs_cell_builder_t *cb, cs_real_t *result)
Compute the local contributions of source terms in a cell.
Definition: cs_source_term.c:846
unsigned int cs_eflag_t
Definition: cs_flag.h:166
void cs_source_term_dcsd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1141
void cs_source_term_pcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1973
void cs_source_term_pcvd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2375
void cs_source_term_vcsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1681
void() cs_source_term_cellwise_t(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.h:85
void cs_source_term_pcsd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2148
