cs_source_term.h File Reference
#include "cs_cdo_local.h"
#include "cs_param_types.h"
#include "cs_quadrature.h"
#include "cs_xdef.h"
+ Include dependency graph for cs_source_term.h:
Data Structures
struct  cs_source_term_boussinesq_t
 Structure storing the parameters related to the Boussinesq source term. More...
Macros
#define CS_N_MAX_SOURCE_TERMS   8
Typedefs
typedef void() cs_source_term_cellwise_t(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. More...
void cs_source_term_set_shared_pointers (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
 Set shared pointers to main domain members. More...
void cs_source_term_set_default_flag (cs_param_space_scheme_t scheme, cs_flag_t *state_flag, cs_flag_t *meta_flag)
 Set the default flag related to a source term according to the numerical scheme chosen for discretizing an equation. More...
void cs_source_term_set_reduction (cs_xdef_t *st, cs_flag_t flag)
 Set advanced parameters which are defined by default in a source term structure. More...
cs_flag_t cs_source_term_get_flag (const cs_xdef_t *st)
 Get metadata related to the given source term structure. More...
cs_eflag_t cs_source_term_init (cs_param_space_scheme_t space_scheme, const int n_source_terms, cs_xdef_t *const *source_terms, cs_source_term_cellwise_t *compute_source[], cs_flag_t *sys_flag, cs_mask_t *source_mask[])
 Initialize data to build the source terms. More...
void cs_source_term_compute_cellwise (const int n_source_terms, cs_xdef_t *const *source_terms, const cs_cell_mesh_t *cm, const cs_mask_t *source_mask, cs_source_term_cellwise_t *compute_source[], cs_real_t time_eval, void *input, cs_cell_builder_t *cb, cs_real_t *result)
 Compute the local contributions of source terms in a cell. More...
void cs_source_term_pvsp_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar potential defined at primal vertices by a constant value. A discrete Hodge operator has to be computed before this call and given as input parameter. More...
void cs_source_term_pvsp_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar potential defined at primal vertices by an analytical function. A discrete Hodge operator has to be computed before this call and given as input parameter. More...
void cs_source_term_dcsd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by a value. More...
void cs_source_term_dcvd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a vector-valued density defined at dual cells by a value. More...
void cs_source_term_dcsd_by_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an array. More...
void cs_source_term_dcsd_by_dof_func (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by a DoF function. More...
void cs_source_term_dcsd_bary_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an analytical function. Use the barycentric approximation as quadrature to evaluate the integral. Exact for linear function. More...
void cs_source_term_dcsd_q1o1_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an analytical function. Use a the barycentric approximation as quadrature to evaluate the integral. Exact for linear function. More...
void cs_source_term_dcsd_q10o2_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an analytical function. Use a ten-point quadrature rule to evaluate the integral. Exact for quadratic function. More...
void cs_source_term_dcsd_q5o3_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an analytical function. Use a five-point quadrature rule to evaluate the integral. Exact for cubic function. This function may be expensive since many evaluations are needed. Please use it with care. More...
void cs_source_term_vcsp_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar potential defined at primal vertices and cells by a constant value. A discrete Hodge operator has to be computed before this call and given as input parameter. More...
void cs_source_term_vcsp_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar potential defined at primal vertices and cells by an analytical function. A discrete Hodge operator has to be computed before this call and given as input parameter. More...
void cs_source_term_pcsd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density (sd) defined on primal cells by a value. Case of face-based schemes. More...
void cs_source_term_pcsd_by_dof_func (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a density defined on primal cells by a DoF function. Case of face-based schemes. More...
void cs_source_term_pcvd_by_dof_func (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a density defined on primal cells by a DoF function. Case of vector-valued face-based schemes. More...
void cs_source_term_pcvd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it the given array of values. Case of a vector-valued density (vd) defined on primal cells by a value. Case of face-based schemes. More...
void cs_source_term_pcsd_bary_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at primal cells by an analytical function. Use the barycentric approximation as quadrature to evaluate the integral. Exact for linear function. Case of face-based schemes. More...
void cs_source_term_pcsd_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution of a source term for a cell and add it to the given array of values. Case of a scalar density (sd) defined on primal cells by an analytic function. More...
void cs_source_term_pcsd_by_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at primal cells by an array. More...
void cs_source_term_pcvd_bary_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a vector-valued density defined at primal cells by an analytical function. Use the barycentric approximation as quadrature to evaluate the integral. Exact for linear function. Case of face-based schemes. More...
void cs_source_term_pcvd_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution of a source term for a cell and add it to the given array of values. Case of a vector average (va) defined on primal cells by an analytic function. More...
void cs_source_term_pcvd_by_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution of a source term for a cell and add it to the given array of values. Case of a vector density (vd) defined on primal cells by an array. More...
void cs_source_term_hhosd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution of a source term for a cell and add it to the given array of values. Case of a scalar density (sd) defined on primal cells by a value. Case of HHO schemes. More...
void cs_source_term_hhosd_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution of a source term for a cell and add it to the given array of values. Case of a scalar density (sd) defined on primal cells by an analytic function. Case of HHO schemes. More...
void cs_source_term_hhovd_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution of a source term for a cell and add it to the given array of values. Case of a vector field (vd) defined on primal cells by an analytic function. Case of HHO schemes. More...
void cs_source_term_dfsf_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
 Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar flux defined at dual faces by a constant value. More...
◆ CS_N_MAX_SOURCE_TERMS
Typedef Documentation
◆ cs_source_term_cellwise_t
[in]sourcepointer to a cs_xdef_term_t structure
[in,out]inputpointer to an element cast on-the-fly (or NULL)
[in,out]valuespointer to the computed values
◆ cs_source_term_compute_cellwise()
void cs_source_term_compute_cellwise ( const int  n_source_terms,
cs_xdef_t *const *  source_terms,
const cs_cell_mesh_t cm,
const cs_mask_t source_mask,
cs_source_term_cellwise_t compute_source[],
void *  input,
cs_cell_builder_t cb,
cs_real_t result
[in]n_source_termsnumber of source terms
[in]source_termspointer to the definitions of source terms
[in]source_maskarray storing in a compact way which source term is defined in a given cell
[in]compute_sourcearray of function pointers
[in,out]resultarray storing the result of the evaluation
◆ cs_source_term_dcsd_bary_by_analytic()
void cs_source_term_dcsd_bary_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
[in]sourcepointer to a cs_xdef_t structure
◆ cs_source_term_dcsd_by_array()
void cs_source_term_dcsd_by_array ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_dcsd_by_dof_func()
void cs_source_term_dcsd_by_dof_func ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_dcsd_by_value()
void cs_source_term_dcsd_by_value ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_dcsd_q10o2_by_analytic()
void cs_source_term_dcsd_q10o2_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_dcsd_q1o1_by_analytic()
void cs_source_term_dcsd_q1o1_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_dcsd_q5o3_by_analytic()
void cs_source_term_dcsd_q5o3_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_dcvd_by_value()
void cs_source_term_dcvd_by_value ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_dfsf_by_value()
void cs_source_term_dfsf_by_value ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_get_flag()
cs_flag_t cs_source_term_get_flag ( const cs_xdef_t st)
[in,out]stpointer to a cs_xdef_t structure
the value of the flag related to this source term
◆ cs_source_term_hhosd_by_analytic()
void cs_source_term_hhosd_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_hhosd_by_value()
void cs_source_term_hhosd_by_value ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_hhovd_by_analytic()
void cs_source_term_hhovd_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_init()
cs_eflag_t cs_source_term_init ( cs_param_space_scheme_t  space_scheme,
cs_flag_t sys_flag,
cs_mask_t source_mask[]
[in]space_schemescheme used to discretize in space
[in,out]compute_sourcearray of function pointers
[in,out]sys_flagmetadata about the algebraic system
[in,out]source_maskpointer to an array storing in a compact way which source term is defined in a given cell
a flag which indicates what to build in a cell mesh structure
◆ cs_source_term_pcsd_bary_by_analytic()
void cs_source_term_pcsd_bary_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pcsd_by_analytic()
void cs_source_term_pcsd_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pcsd_by_array()
void cs_source_term_pcsd_by_array ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pcsd_by_dof_func()
void cs_source_term_pcsd_by_dof_func ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pcsd_by_value()
void cs_source_term_pcsd_by_value ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pcvd_bary_by_analytic()
void cs_source_term_pcvd_bary_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pcvd_by_analytic()
void cs_source_term_pcvd_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pcvd_by_array()
void cs_source_term_pcvd_by_array ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pcvd_by_dof_func()
void cs_source_term_pcvd_by_dof_func ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pcvd_by_value()
void cs_source_term_pcvd_by_value ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pvsp_by_analytic()
void cs_source_term_pvsp_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_pvsp_by_value()
void cs_source_term_pvsp_by_value ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_set_default_flag()
void cs_source_term_set_default_flag ( cs_param_space_scheme_t  scheme,
cs_flag_t state_flag,
cs_flag_t meta_flag
[in]schemenumerical scheme used for the discretization
[out]state_flagflag describing the status of the source term
[out]meta_flagadditional flags associated to a source term
◆ cs_source_term_set_reduction()
void cs_source_term_set_reduction ( cs_xdef_t st,
cs_flag_t  flag
[in]flagCS_FLAG_DUAL or CS_FLAG_PRIMAL
◆ cs_source_term_set_shared_pointers()
void cs_source_term_set_shared_pointers ( const cs_cdo_quantities_t quant,
const cs_cdo_connect_t connect
◆ cs_source_term_vcsp_by_analytic()
void cs_source_term_vcsp_by_analytic ( const cs_xdef_t source,
void *  input,
double *  values
◆ cs_source_term_vcsp_by_value()
void cs_source_term_vcsp_by_value ( const cs_xdef_t source,
void *  input,
double *  values
