Here is a list of all variables with links to the structures/unions they belong to:
- s -
- s_das : cs_solidification_t
- saddle_param : cs_equation_param_t
- saddle_solver : cs_cdocb_scaleq_t
- save_if_modified : cs_mesh_t
- scal_t : cs_lagr_extra_module_t
- scalar_kernel : cs_lagr_agglomeration_model_t, cs_lagr_fragmentation_model_t
- scale : cs_gwf_soil_vgm_spf_param_t
- scaling_coef : cs_param_saddle_context_notay_t
- scaling_factor : cs_property_t
- sch : cs_coal_model_t
- scheme_context : cs_equation_t, cs_equation_core_t, cs_navsto_system_t
- schur_approx : cs_param_saddle_t
- schur_diag : cs_saddle_solver_context_block_pcd_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- schur_matrix : cs_saddle_solver_context_block_pcd_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- schur_scaling : cs_saddle_solver_context_block_pcd_t
- schur_sles : cs_saddle_solver_context_block_pcd_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- schur_sles_param : cs_param_saddle_t
- schur_xtra : cs_saddle_solver_context_block_pcd_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- sck : cs_coal_model_t
- sec : cs_timer_t
- sec_name : cs_io_sec_header_t
- section : fvm_writer_section_t
- sections : fvm_nodal_t
- sedimentation_model : cs_atmo_option_t
- seed_coords : cs_stl_mesh_t
- sefc : cs_cell_mesh_t
- sel_criteria : cs_medcoupling_mesh_t
- select_b_faces : cs_mesh_t
- select_cells : cs_mesh_t
- select_i_faces : cs_mesh_t
- selection_criteria_output : cs_cfd_sys_cplbc_t
- selection_type : cs_enforcement_param_t
- send_field_ids : cs_cfd_sys_cplbc_t
- send_index : cs_halo_t
- send_list : cs_halo_t
- send_perio_lst : cs_halo_t
- send_vals : cs_sys_cpl_t
- set_dir_bc : cs_equation_t
- set_id : cs_lagr_injection_set_t
- set_mesh_time_func : fvm_writer_format_t
- setup : cs_basis_func_t
- sgn : cs_adjacency_t
- shape : cs_lagr_injection_set_t, cs_lagr_model_t
- shape_param : cs_lagr_injection_set_t
- shared_structures : cs_cdo_system_ublock_t
- shour : cs_atmo_option_t
- sig_defaults : cs_opts_t
- sigc : cs_atmo_option_t
- sigel : cs_data_elec_t
- sigma : cs_air_fluid_props_t
- sigma_s : cs_vof_parameters_t
- simplified_boundary_update : cs_gwf_darcy_flux_t
- single_faces_to_cells : cs_mesh_adjacencies_t
- size : cs_tree_node_t, cs_basis_func_t, cs_cdo_balance_t, cs_lagr_attribute_map_t, cs_lagr_event_attribute_map_t
- sl_r : cs_gwf_soil_vgm_tpf_param_t
- sl_range : cs_gwf_soil_vgm_tpf_param_t
- sl_s : cs_gwf_soil_vgm_tpf_param_t
- slam : cs_gas_mix_species_prop_t
- slave_assembly_func : cs_cdo_system_dblock_t, cs_cdo_system_nblock_t
- sle_alpha : cs_gwf_soil_vgm_tpf_param_t
- sle_beta : cs_gwf_soil_vgm_tpf_param_t
- sle_jtype : cs_gwf_soil_vgm_tpf_param_t
- sle_thres : cs_gwf_soil_vgm_tpf_param_t
- sleak : cs_fluid_properties_t
- sles_param : cs_equation_param_t, cs_equation_system_param_t
- sles_strategy : cs_equation_system_param_t
- sliding_ids : cs_cdo_bc_face_t
- slope_consol : cs_lagr_consolidation_model_t
- smagp2 : cs_les_balance_rij_t
- smin : cs_atmo_option_t
- smu : cs_gas_mix_species_prop_t
- soil_capacity : cs_gwf_uspf_t
- soil_cat : cs_atmo_option_t
- soil_cat_albedo : cs_atmo_option_t
- soil_cat_emissi : cs_atmo_option_t
- soil_cat_r1 : cs_atmo_option_t
- soil_cat_r2 : cs_atmo_option_t
- soil_cat_roughness : cs_atmo_option_t
- soil_cat_thermal_inertia : cs_atmo_option_t
- soil_cat_thermal_roughness : cs_atmo_option_t
- soil_cat_vegeta : cs_atmo_option_t
- soil_cat_w1 : cs_atmo_option_t
- soil_cat_w2 : cs_atmo_option_t
- soil_humidity : cs_atmo_option_t
- soil_meb_model : cs_atmo_option_t
- soil_model : cs_atmo_option_t
- soil_porosity : cs_gwf_t
- soil_surf_temp : cs_atmo_option_t
- soil_temperature : cs_atmo_option_t
- soil_w1_ini : cs_atmo_option_t
- soil_w2_ini : cs_atmo_option_t
- soil_zone_id : cs_atmo_option_t
- solar_1D_profile : cs_atmo_option_t
- solid_porosity : cs_ibm_t
- solub : cs_lagr_precipitation_model_t
- solute_equation : cs_solidification_binary_alloy_t
- solve : cs_cdocb_scaleq_t, cs_equation_t
- solve_rain_velocity : cs_ctwr_option_t
- solve_steady_state : cs_equation_t
- solve_steady_state_system : cs_equation_system_t
- solve_system : cs_equation_system_t
- solve_temperature_seen : cs_lagr_specific_physics_t
- solver : cs_param_saddle_t, cs_param_sles_t
- solver_class : cs_param_saddle_t, cs_param_sles_t
- solver_type : cs_gwf_tpf_t
- source : cs_cell_sys_t
- source_c_ids : cs_porosity_from_scan_opt_t
- source_mask : cs_equation_builder_t
- source_term : cs_cdo_balance_t
- source_term_displ : cs_lagr_attribute_map_t
- source_terms : cs_cdoeb_vecteq_t, cs_cdofb_vecteq_t, cs_cdovb_vecteq_t, cs_macfb_vecteq_t, cs_equation_param_t
- sources : cs_porosity_from_scan_opt_t
- space_poly_degree : cs_equation_param_t
- space_scheme : cs_equation_param_t, cs_equation_system_param_t, cs_navsto_param_t
- spack_file_name : cs_atmo_chemistry_t
- species_profiles_to_field_id : cs_atmo_chemistry_t
- species_to_field_id : cs_atmo_chemistry_t, cs_gas_mix_t
- species_to_scalar_id : cs_atmo_chemistry_t
- squant : cs_atmo_option_t
- square_norm_b11 : cs_saddle_solver_context_alu_t, cs_saddle_solver_context_gkb_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- src_flag : cs_equation_builder_t
- srct_h_array : cs_gwf_tpf_t
- srct_w_array : cs_gwf_tpf_t
- srrom : cs_coal_model_t, cs_combustion_gas_model_t, cs_elec_option_t
- ssec : cs_atmo_option_t
- st_defs : cs_gwf_tracer_decay_chain_t
- stage : cs_domain_t
- staggered : cs_velocity_pressure_param_t
- start_nt : cs_time_control_t
- start_t : cs_time_control_t
- starting_iter : cs_iter_algo_param_aac_t
- stat_weight : cs_lagr_injection_set_t
- state : cs_coal_bc_inlet_t, cs_xdef_t
- state_flag : cs_property_t
- state_ratio : cs_solidification_t
- status : cs_adv_field_t
- std_send_block_size : cs_halo_t
- std_send_blocks : cs_halo_t
- steady : cs_at_opt_interp_t
- stl : cs_ibm_object_t
- strategy : cs_solidification_t
- stream_function_eq : cs_navsto_system_t
- stride : cs_adjacency_t, cs_cdo_system_block_info_t, cs_enforcement_param_t, cs_meg_xdef_input_t, cs_xdef_array_context_t, fvm_nodal_section_t
- strong_pena_bc_coeff : cs_equation_param_t
- strong_threshold : cs_param_amg_boomer_t
- study_name : cs_domain_t
- subgrid_model : cs_atmo_option_t
- support : cs_xdef_t
- surf_coeff : cs_cfd_sys_cplbc_t
- surface : cs_ctwr_zone_t
- surface_in : cs_ctwr_zone_t
- surface_out : cs_ctwr_zone_t
- syear : cs_atmo_option_t
- sys_elt_idx : cs_cfd_sys_cplbc_t
- sys_flag : cs_equation_builder_t
- sys_n_ranks : cs_sys_cpl_t
- sys_name : cs_sys_cpl_t
- sys_root : cs_sys_cpl_t
- sys_weight : cs_cfd2sys_intersection_t
- system : cs_gwf_tpf_t
- system_helper : cs_cdocb_scaleq_t, cs_equation_builder_t, cs_equation_system_t, cs_saddle_solver_t
