Here is a list of all variables with links to the structures/unions they belong to:
- r -
- R : cs_iter_algo_aac_t
- r_pg_cnst : cs_fluid_properties_t
- r_v_cnst : cs_fluid_properties_t
- rad_1d_acinfe : cs_atmo_option_t
- rad_1d_aco2 : cs_atmo_option_t
- rad_1d_aco2s : cs_atmo_option_t
- rad_1d_acsup : cs_atmo_option_t
- rad_1d_acsups : cs_atmo_option_t
- rad_1d_aerosols : cs_atmo_option_t
- rad_1d_albedo0 : cs_atmo_option_t
- rad_1d_dacinfe : cs_atmo_option_t
- rad_1d_daco2 : cs_atmo_option_t
- rad_1d_daco2s : cs_atmo_option_t
- rad_1d_dacsup : cs_atmo_option_t
- rad_1d_dacsups : cs_atmo_option_t
- rad_1d_emissi0 : cs_atmo_option_t
- rad_1d_fn : cs_atmo_option_t
- rad_1d_frequency : cs_atmo_option_t
- rad_1d_ir_div : cs_atmo_option_t
- rad_1d_ird : cs_atmo_option_t
- rad_1d_iru : cs_atmo_option_t
- rad_1d_nc : cs_atmo_option_t
- rad_1d_nlevels : cs_atmo_option_t
- rad_1d_nlevels_max : cs_atmo_option_t
- rad_1d_nvert : cs_atmo_option_t
- rad_1d_p0 : cs_atmo_option_t
- rad_1d_ql : cs_atmo_option_t
- rad_1d_qv : cs_atmo_option_t
- rad_1d_qw : cs_atmo_option_t
- rad_1d_qw0 : cs_atmo_option_t
- rad_1d_rho0 : cs_atmo_option_t
- rad_1d_sol_div : cs_atmo_option_t
- rad_1d_sold : cs_atmo_option_t
- rad_1d_solu : cs_atmo_option_t
- rad_1d_tauz : cs_atmo_option_t
- rad_1d_tauzq : cs_atmo_option_t
- rad_1d_temp0 : cs_atmo_option_t
- rad_1d_theta0 : cs_atmo_option_t
- rad_1d_xy : cs_atmo_option_t
- rad_1d_z : cs_atmo_option_t
- rad_1d_zq : cs_atmo_option_t
- rad_1d_zray : cs_atmo_option_t
- rad_energy : cs_lagr_extra_module_t
- radiative_model : cs_lagr_extra_module_t
- radiative_model_1d : cs_atmo_option_t
- radii : cs_lagr_injection_set_t
- rain : cs_atmo_option_t
- rain_evap : cs_ctwr_option_t
- rain_to_packing : cs_ctwr_option_t
- range_set : cs_cdo_system_dblock_t, cs_cdo_system_nblock_t, cs_cdo_system_ublock_t, cs_cdo_system_xblock_t
- rank : fvm_to_histogram_writer_t
- rank_connect : cs_interpol_grid_t
- rank_step : cs_block_dist_info_t
- rans_param : cs_turbulence_param_t
- rate_consol : cs_lagr_consolidation_model_t
- rayasg : cs_lagr_reentrained_model_t, cs_lagr_roughness_param_t
- rayasp : cs_lagr_reentrained_model_t, cs_lagr_roughness_param_t
- rc_tilda : cs_cdofb_vecteq_t
- rcfact : cs_velocity_pressure_param_t
- rcodcl1 : cs_field_bc_coeffs_t
- rcodcl2 : cs_field_bc_coeffs_t
- rcodcl3 : cs_field_bc_coeffs_t
- rcpt1d : cs_1d_wall_thermal_local_model_t
- reac_pty_uniform : cs_equation_builder_t
- reacnum : cs_atmo_chemistry_t
- reaction_hodgep : cs_equation_param_t
- reaction_id : cs_gwf_tracer_t
- reaction_properties : cs_equation_param_t
- reaction_term : cs_cdo_balance_t
- read_auxiliary : cs_restart_auxiliary_t
- read_restart : cs_equation_t
- recv_field_ids : cs_cfd_sys_cplbc_t
- recv_vals : cs_sys_cpl_t
- recvr : cs_combustion_gas_model_t
- ref_concentration : cs_solidification_binary_alloy_t
- ref_temperature : cs_gwf_tpf_t, cs_thermal_system_t
- ref_value : cs_property_t
- reference_pressure : cs_navsto_param_t
- reference_values : cs_turbulence_param_t
- reinit_turb : cs_turb_rans_model_t
- related_properties : cs_property_t
- relax : cs_ctwr_zone_t, cs_at_opt_interp_t
- relax_pty : cs_equation_system_param_t
- relaxv : var_cal_opt, cs_equation_param_t
- relxst : cs_time_step_options_t
- remove_boundary_faces : cs_cdo_quantities_t
- repnck : cs_coal_model_t
- repnle : cs_coal_model_t
- repnlo : cs_coal_model_t
- res : cs_iter_algo_aac_t, cs_iter_algo_default_t
- res0 : cs_iter_algo_aac_t, cs_iter_algo_default_t
- res2 : cs_saddle_solver_context_alu_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- res_norm : cs_solving_info_t
- residual_moisture : cs_gwf_soil_vgm_spf_param_t
- resnorm_type : cs_param_sles_t
- restart : cs_param_sles_t, cs_rad_transfer_params_t
- restart_file : cs_function_t
- restart_nt : cs_domain_t
- restrike_point : cs_elec_option_t
- resuspension : cs_lagr_model_t
- reuse_interpolation : cs_param_amg_hmg_t
- rgpt1d : cs_1d_wall_thermal_local_model_t
- rho : cs_turbulence_t, cs_lagr_precipitation_model_t, cs_thermal_system_t
- rho0ch : cs_coal_model_t
- rho1 : cs_vof_parameters_t
- rho2 : cs_vof_parameters_t
- rho20 : cs_coal_model_t
- rho2mn : cs_coal_model_t
- rho_bulk : cs_gwf_tracer_default_context_t
- rho_c : cs_cdofb_navsto_builder_t
- rho_kd : cs_gwf_tracer_default_context_t
- rho_l : cs_air_fluid_props_t
- rho_met : cs_atmo_option_t
- rhock : cs_coal_model_t
- rhoel : cs_data_elec_t
- rhol : cs_libby_williams_params_t
- rhs : cs_cdo_system_helper_t, cs_cell_sys_t, cs_saddle_solver_context_alu_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- rhs_array : cs_cdo_system_helper_t
- rhs_norm : cs_solving_info_t
- rhs_tilda : cs_saddle_solver_context_gkb_t
- richards : cs_gwf_sspf_t, cs_gwf_uspf_t
- rij : cs_turbulence_t
- rnbs : cs_data_joule_effect_t
- ro0 : cs_fluid_properties_t
- rob_values : cs_cell_sys_t
- robin_ids : cs_cdo_bc_face_t
- roref : cs_fluid_properties_t
- rosoot : cs_combustion_gas_model_t
- roughness : cs_lagr_model_t
- row : cs_cdo_assembly_t
- row_size : cs_matrix_row_info_t
- rpty_val : cs_cell_builder_t
- rpty_vals : cs_cell_builder_t
- rtol : cs_param_convergence_t
- run_id : cs_domain_t
- rupture : cs_atmo_option_t
- rvsra : cs_fluid_properties_t
