#include "base/cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <math.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_log.h"#include "base/cs_field.h"#include "base/cs_field_pointer.h"#include "base/cs_map.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "base/cs_parall.h"#include "mesh/cs_mesh_location.h"#include "turb/cs_turbulence_model.h"#include "turb/cs_turbulence_bc.h"Functions | |
| void | cs_turbulence_bc_init_pointers (void) |
| Initialize turbulence model boundary condition pointers. | |
| void | cs_turbulence_bc_free_pointers (void) |
| Free memory allocations for turbulence boundary condition pointers. | |
| void | cs_turbulence_bc_ke_hyd_diam (double uref2, double dh, double rho, double mu, double *ustar2, double *k, double *eps) |
| Calculation of | |
| void | cs_turbulence_bc_ke_turb_intensity (double uref2, double t_intensity, double dh, double *k, double *eps) |
| Calculation of | |
| void | cs_turbulence_bc_inlet_hyd_diam (cs_lnum_t face_id, double uref2, double dh, double rho, double mu) |
| Set inlet boundary condition values for turbulence variables based on a diameter | |
| void | cs_turbulence_bc_inlet_turb_intensity (cs_lnum_t face_id, double uref2, double t_intensity, double dh) |
| void | cs_turbulence_bc_inlet_k_eps (cs_lnum_t face_id, double k, double eps) |
| Set inlet boundary condition values for turbulence variables based on given k and epsilon values. | |
| void | cs_turbulence_bc_set_hmg_neumann (cs_lnum_t face_id) |
| Assign homogeneous Neumann turbulent boundary conditions to a given face. | |
| void | cs_turbulence_bc_set_uninit_inlet_hyd_diam (cs_lnum_t face_id, double vel_dir[], double shear_dir[], double uref2, double dh, double rho, double mu) |
| void | cs_turbulence_bc_set_uninit_inlet_turb_intensity (cs_lnum_t face_id, double uref2, double t_intensity, double dh) |
| void | cs_turbulence_bc_set_uninit_inlet_k_eps (cs_lnum_t face_id, double k, double eps, double vel_dir[], double shear_dir[]) |
| Set inlet boundary condition values for turbulence variables based on given k and epsilon values only if not already initialized. | |
| void | cs_turbulence_bc_rij_transform (int is_sym, cs_real_t p_lg[3][3], cs_real_t alpha[6][6]) |
| Compute matrix | |
Base turbulence boundary conditions.
| void cs_turbulence_bc_free_pointers | ( | void | ) |
| void cs_turbulence_bc_init_pointers | ( | void | ) |
| void cs_turbulence_bc_inlet_hyd_diam | ( | cs_lnum_t | face_id, |
| double | uref2, | ||
| double | dh, | ||
| double | rho, | ||
| double | mu ) |
We use the laws from Idel'Cik, i.e. the head loss coefficient
![\[ |\dfrac{\Delta P}{\Delta x}| =
\dfrac{\lambda}{D_H} \frac{1}{2} \rho U_{ref}^2 \]](form_490.png)
then the relation reads
![\[ \lambda = \dfrac{64}{Re} \]](form_495.png)
![\[ \lambda = \dfrac{1}{( 1.8 \log_{10}(Re)-1.64 )^2} \]](form_497.png)
![\[ \lambda = 0.021377 + 5.3115. 10^{-6} Re \]](form_499.png)
From
| [in] | face_id | boundary face id |
| [in] | uref2 | square of the reference flow velocity |
| [in] | dh | hydraulic diameter |
| [in] | rho | mass density |
| [in] | mu | dynamic viscosity |
| void cs_turbulence_bc_inlet_k_eps | ( | cs_lnum_t | face_id, |
| double | k, | ||
| double | eps ) |
| [in] | k | turbulent kinetic energy |
| [in] | eps | turbulent dissipation |
| void cs_turbulence_bc_inlet_turb_intensity | ( | cs_lnum_t | face_id, |
| double | t_intensity, | ||
| double | dh ) |
| [in] | t_intensity | turbulent intensity |
| void cs_turbulence_bc_ke_hyd_diam | ( | double | uref2, |
| double | dh, | ||
| double | rho, | ||
| double | mu, | ||
| double * | ustar2, | ||
| double * | k, | ||
| double * | eps ) |
Calculation of
Both
From
![\[ k = \dfrac{u^{\star 2}}{\sqrt{C_\mu}} \]](form_501.png)
![\[ \varepsilon = \dfrac{ u^{\star 3}}{(\kappa D_H /10)} \]](form_502.png)
| [out] | ustar2 | square of friction speed |
| [out] | k | calculated turbulent intensity |
| [out] | eps | calculated turbulent dissipation |
| void cs_turbulence_bc_ke_turb_intensity | ( | double | uref2, |
| double | dh, | ||
| double * | k, | ||
| double * | eps ) |
Calculation of
![\[ k = 1.5 I {U_{ref}}^2 \]](form_504.png)
![\[ \varepsilon = 10 \dfrac{{C_\mu}^{0.75} k^{1.5}}{ \kappa D_H} \]](form_505.png)
Compute matrix
We note
![\[\vect{R}_{g,\fib} = \tens{\alpha} \vect{R}_{g,\centip} + \vect{R}_{g}^*
\]](form_510.png)
where symetric tensors
![\[\vect{R}_g = \transpose{\left(R_{g,11},R_{g,22},R_{g,33},
R_{g,12},R_{g,13},R_{g,23}\right)}
\]](form_511.png)
![\[\tens{R}_{g,\fib}=\tens{P}_{lg}\tens{R}_{l,\fib}\transpose{\tens{P}_{lg}}
\]](form_514.png)
with
![\[\tens{R}_{l,\fib} =
\begin{bmatrix}
R_{l,11,\centip} & 0 & c R_{l,13,\centip}\\
0 & R_{l,22,\centip} & 0 \\
c R_{l,13,\centip} & 0 & R_{l,33,\centip}
\end{bmatrix} +
\underbrace{\begin{bmatrix}
0 & (1-c) u^* u_k & 0 \\
(1-c) u^* u_k & 0 & 0 \\
0 & 0 & 0
\end{bmatrix}}_{\vect{R}_l^*}
\]](form_515.png)
and
Constant c is chosen depending on the type of the boundary face:
| [in] | is_sym | Constant c in description above (1 at a symmetry face, 0 at a wall face) |
| [in] | p_lg | change of basis matrix (local to global) |
| [out] | alpha | transformation matrix |
| void cs_turbulence_bc_set_hmg_neumann | ( | cs_lnum_t | face_id | ) |
This is useful for outgoing flow.
| void cs_turbulence_bc_set_uninit_inlet_hyd_diam | ( | cs_lnum_t | face_id, |
| double | vel_dir[], | ||
| double | shear_dir[], | ||
| double | dh, | ||
| double | rho, | ||
| double | mu ) |
Apart from assigning values where not already initialized, this function is similar to cs_turbulence_bc_inlet_hyd_diam.
| [in] | vel_dir | velocity direction (not normalized, or nullptr) |
| [in] | shear_dir | shear direction (or nullptr), it also contains the level of anisotropy (Rnt = a_nt k) |
| void cs_turbulence_bc_set_uninit_inlet_k_eps | ( | cs_lnum_t | face_id, |
| double | k, | ||
| double | eps, | ||
| double | shear_dir[] ) |
| [in] | vel_dir | velocity direction |
| [in] | shear_dir | shear direction, it also contains the level of anisotropy (Rnt = a_nt k) |
| void cs_turbulence_bc_set_uninit_inlet_turb_intensity | ( | cs_lnum_t | face_id, |
| double | dh ) |
Apart from assigning values where not already initialized, this function is similar to cs_turbulence_bc_inlet_turb_intensity.
