#include "base/cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <math.h>#include "bft/bft_printf.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parall.h"#include "base/cs_parameters.h"#include "base/cs_thermal_model.h"#include "cfbl/cs_cf_model.h"#include "cfbl/cs_hgn_thermo.h"#include "cfbl/cs_cf_thermo.h"Functions | |
| void | cs_cf_set_thermo_options (void) |
| Set variability of isobaric specific heat and isochoric specific heat according to the chosen thermodynamic law. | |
| void | cs_cf_thermo_default_init (void) |
| Initialize density, total energy and isochoric specific heat according to the chosen thermodynamic law using the default parameters. | |
| void | cs_cf_check_pressure (cs_real_t *pres, cs_lnum_t n_elts) |
| Check the positivity of the pressure. | |
| void | cs_cf_check_internal_energy (cs_real_t *ener, cs_lnum_t n_elts, cs_real_3_t *vel) |
| Check the positivity of the internal energy. | |
| void | cs_cf_check_density (cs_real_t *rho, cs_lnum_t n_elts) |
| Check the positivity of the density given by the user. | |
| void | cs_cf_check_temperature (cs_real_t *temp, cs_lnum_t n_elts) |
| Check strict positivity of temperature (Celsius) given by the user. | |
| void | cs_cf_thermo_te_from_dp (cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *rho, cs_real_t *temp, cs_real_t *ener, cs_real_3_t *vel, cs_lnum_t n_elts) |
| Compute temperature and total energy from density and pressure. | |
| void | cs_cf_thermo_de_from_pt (cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *temp, cs_real_t *rho, cs_real_t *ener, cs_real_3_t *vel, cs_lnum_t n_elts) |
| Compute density and total energy from pressure and temperature. | |
| void | cs_cf_thermo_dt_from_pe (cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *ener, cs_real_t *rho, cs_real_t *temp, cs_real_3_t *vel, cs_lnum_t n_elts) |
| Compute density and temperature from pressure and total energy;. | |
| void | cs_cf_thermo_pe_from_dt (cs_real_t *cp, cs_real_t *cv, cs_real_t *rho, cs_real_t *temp, cs_real_t *pres, cs_real_t *ener, cs_real_3_t *vel, cs_lnum_t n_elts) |
| Compute pressure and total energy from density and temperature. | |
| void | cs_cf_thermo_pt_from_de (cs_real_t *cp, cs_real_t *cv, cs_real_t *rho, cs_real_t *ener, cs_real_t *pres, cs_real_t *temp, cs_real_3_t *vel, cs_real_t *fracv, cs_real_t *fracm, cs_real_t *frace, cs_lnum_t n_elts) |
| Compute pressure and temperature from density and total energy. | |
| void | cs_cf_thermo_c_square (cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *rho, cs_real_t *fracv, cs_real_t *fracm, cs_real_t *frace, cs_real_t *c2, cs_lnum_t n_elts) |
| Compute square of sound velocity: | |
| void | cs_cf_thermo_beta (cs_real_t *cp, cs_real_t *cv, cs_real_t *rho, cs_real_t *beta, cs_lnum_t n_elts) |
| Compute the thermal expansion coefficient: | |
| void | cs_cf_thermo_cv (cs_real_t *cp, cs_real_t *xmasml, cs_real_t *cv, cs_lnum_t n_elts) |
| Compute the isochoric specific heat: | |
| void | cs_cf_thermo_s_from_dp (cs_real_t *cp, cs_real_t *cv, cs_real_t *rho, cs_real_t *pres, cs_real_t *entr, cs_lnum_t n_elts) |
| Compute entropy from pressure and density: | |
| void | cs_cf_thermo_wall_bc (cs_real_t *wbfa, cs_real_t *wbfb, cs_lnum_t face_id) |
| Compute wall boundary condition values. | |
| void | cs_cf_thermo_subsonic_outlet_bc (cs_real_t *bc_en, cs_real_t *bc_pr, cs_real_3_t *bc_vel, cs_lnum_t face_id) |
| Compute subsonic outlet boundary conditions values. | |
| void | cs_cf_thermo_ph_inlet_bc (cs_real_t *bc_en, cs_real_t *bc_pr, cs_real_3_t *bc_vel, cs_lnum_t face_id) |
| Compute inlet boundary condition with total pressure and total enthalpy imposed. | |
| void | cs_cf_thermo_eps_sup (const cs_real_t *rho, cs_real_t *eps_sup, cs_lnum_t n_elts) |
| Compute epsilon sup: | |
| void | cs_cf_thermo (const int iccfth, cs_lnum_t face_id, cs_real_t *bc_en, cs_real_t *bc_pr, cs_real_t *bc_tk, cs_real_3_t *bc_vel) |
| This function is a driver allowing to call the appropriate thermodynamical functions depending on the quantities provided by the user. Hence it is only used during the initialization step and at the boundaries of type supersonic inlet. It is described in the following how to select the quantity to be returned. | |
| cs_real_t | cs_cf_thermo_b_rho_from_pt (cs_lnum_t face_id, cs_real_t bc_pr, cs_real_t bc_tk) |
| Compute density at boundary based on pressure and temperature. | |
Define thermodynamic laws for the compressible flow module. Only the perfect gas law is available for now. The molar mass has to be provided either in the GUI or in cs_user_parameters.cpp.
| [in] | rho | array of density values |
| [in] | n_elts | size of the array |
| void cs_cf_check_internal_energy | ( | cs_real_t * | ener, |
| cs_lnum_t | n_elts, | ||
| cs_real_3_t * | vel ) |
| [in] | ener | array of total energy values |
| [in] | vel | array of velocity values |
| [in] | pres | array of pressure values |
| [in] | temp | array of temperature values |
| void cs_cf_set_thermo_options | ( | void | ) |
| void cs_cf_thermo | ( | const int | iccfth, |
| cs_lnum_t | face_id, | ||
| cs_real_t * | bc_en, | ||
| cs_real_t * | bc_pr, | ||
| cs_real_t * | bc_tk, | ||
| cs_real_3_t * | bc_vel ) |
When calling the user subroutine, the integer 'iccfth' specifies which calculation has to be performed (and which quantity has to be returned). The values for 'iccfth' for each case are provided below.
The variables are referred to using a different index i:
iccfth is as follows, depending on which quantity needs to be computed:
Detailed values of iccfth and corresponding computations:
Values at the cell centers:
Values at the faces for boundary conditions:
| [in] | iccfth | id of computation |
| [in] | face_id | face index if the computation is for a B.C. -1 if the computation is located on cells |
| [in,out] | bc_en | total energy values at boundary faces |
| [in,out] | bc_pr | pressure values at boundary faces |
| [in,out] | bc_tk | temperature values at boundary faces |
| [in,out] | bc_vel | velocity values at boundary faces |
This is needed when imposing a mass flow rate on a given inlet.
| [in] | face_id | face id |
| [in] | bc_pr | pressure value at boundary face |
| [in] | bc_tk | temperature value at boundary face |
| void cs_cf_thermo_beta | ( | cs_real_t * | cp, |
| cs_real_t * | cv, | ||
| cs_real_t * | rho, | ||
| cs_real_t * | beta, | ||
| cs_lnum_t | n_elts ) |
![\[ \beta = \left(\frac{\partial p}{\partial s}\right)_\rho \]](form_401.png)
for a perfect gas, the explicit formula is:
![\[ \beta = \rho^\gamma \]](form_402.png)
| [in] | cp | array of isobaric specific heat values |
| [in] | cv | array of isochoric specific heat values |
| [out] | beta | array of beta values |
| void cs_cf_thermo_c_square | ( | cs_real_t * | cp, |
| cs_real_t * | pres, | ||
| cs_real_t * | fracv, | ||
| cs_real_t * | fracm, | ||
| cs_real_t * | frace, | ||
| cs_real_t * | c2, | ||
![\[c^2 = \left(\frac{\partial p}{\partial \rho}\right)_s\]](form_399.png)
for perfect gas, this expression simply writes:
![\[c^2 = \gamma \frac{p}{\rho}\]](form_400.png)
| [in,out] | fracv | array of volume fraction values |
| [in,out] | fracm | array of mass fraction values |
| [in,out] | frace | array of energy fraction values |
| [out] | c2 | array of the values of the square of sound velocity |
![\[C_v = \left(\frac{\partial e}{\partial T}\right)_\rho\]](form_403.png)
| [in] | xmasml | array of molar mass values |
| [out] | cv | array of isochoric specific heat values |
| void cs_cf_thermo_de_from_pt | ( | cs_real_t * | cp, |
| cs_real_t * | temp, | ||
| cs_real_t * | ener, | ||
| cs_real_3_t * | vel, | ||
| [out] | rho | array of density values |
| [out] | ener | array of total energy values |
| [in] | vel | array of velocity component values |
| void cs_cf_thermo_default_init | ( | void | ) |
| void cs_cf_thermo_dt_from_pe | ( | cs_real_t * | cp, |
| [out] | temp | array of temperature values |
![\[\epsilon_{\textrm{sup}} = e - C_v T\]](form_405.png)
for perfect gas:
![\[\epsilon_{\textrm{sup}} = 0\]](form_406.png)
| [out] | eps_sup | epsilon sup array |
| void cs_cf_thermo_pe_from_dt | ( | cs_real_t * | cp, |
| [out] | pres | array of pressure values |
| void cs_cf_thermo_ph_inlet_bc | ( | cs_real_t * | bc_en, |
| cs_real_3_t * | bc_vel, | ||
| cs_lnum_t | face_id ) |
| [in] | face_id | boundary face index |
| void cs_cf_thermo_pt_from_de | ( | cs_real_t * | cp, |
| void cs_cf_thermo_s_from_dp | ( | cs_real_t * | cp, |
| cs_real_t * | entr, | ||
![\[s = \frac{p}{\rho^\gamma}\]](form_404.png)
| [out] | entr | array of total energy values |
| void cs_cf_thermo_subsonic_outlet_bc | ( | cs_real_t * | bc_en, |
| void cs_cf_thermo_te_from_dp | ( | cs_real_t * | cp, |
