Build an algebraic CDO face-based system for the Navier-Stokes equations and solved it with a prediction/correction algorithm. A first equation related to the velocity prediction is solved and then a second equation related to the pressure correction is solved to project the velocity field into the space of divergence-free field. More...
#include "base/cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <float.h>#include <assert.h>#include <string.h>#include "bft/bft_mem.h"#include "base/cs_array.h"#include "alge/cs_blas.h"#include "cdo/cs_cdo_assembly.h"#include "cdo/cs_cdo_bc.h"#include "cdo/cs_cdo_solve.h"#include "cdo/cs_cdofb_priv.h"#include "cdo/cs_cdofb_scaleq.h"#include "cdo/cs_cdofb_vecteq.h"#include "cdo/cs_cdofb_navsto.h"#include "cdo/cs_equation_bc.h"#include "cdo/cs_equation_priv.h"#include "cdo/cs_evaluate.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "base/cs_post.h"#include "cdo/cs_reco.h"#include "cdo/cs_source_term.h"#include "cdo/cs_static_condensation.h"#include "base/cs_timer.h"#include "cdo/cs_cdofb_predco.h"Functions | |
| void | cs_cdofb_predco_init_common (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step) |
| Set shared pointers from the main domain members. | |
| void * | cs_cdofb_predco_init_scheme_context (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nsc_input) |
| Initialize a cs_cdofb_predco_t structure. | |
| void * | cs_cdofb_predco_free_scheme_context (void *scheme_context) |
| Destroy a cs_cdofb_predco_t structure. | |
| void | cs_cdofb_predco_compute_implicit (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context) |
| Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a prediction/correction approach and an implicit Euler time scheme. | |
| void cs_cdofb_predco_compute_implicit | ( | const cs_mesh_t * | mesh, |
| void * | scheme_context ) |
Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a Artificial Compressibility approach and an Euler time scheme.
| void * cs_cdofb_predco_free_scheme_context | ( | void * | scheme_context | ) |
| [in] | scheme_context | pointer to a scheme context structure to free |
| void cs_cdofb_predco_init_common | ( | const cs_cdo_quantities_t * | quant, |
| void * cs_cdofb_predco_init_scheme_context | ( | const cs_navsto_param_t * | nsp, |
| cs_adv_field_t * | adv_field, | ||
| cs_real_t * | mflux, | ||
| cs_real_t * | mflux_pre, | ||
| cs_boundary_type_t * | fb_type, | ||
| void * | nsc_input ) |
| [in] | mflux | current values of the mass flux across primal faces |
| [in] | mflux_pre | previous values of the mass flux across primal faces |
| [in] | fb_type | type of boundary for each boundary face |
| [in] | nsc_input | pointer to a cs_navsto_projection_t structure |
