1#ifndef __CS_EQUATION_PRIV_H__
2#define __CS_EQUATION_PRIV_H__
310 void *scheme_context);
#define restrict
Definition cs_defs.h:145
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
unsigned short int cs_flag_t
Definition cs_defs.h:344
cs_cdo_balance_t * cs_equation_get_balance_t(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Compute the balance for an equation over the full computational domain between time t_cur and t_cur +...
Definition cs_equation_priv.h:220
void cs_equation_build_system_t(const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build a linear system within the CDO framework.
Definition cs_equation_priv.h:163
void * cs_equation_init_context_t(cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a scheme data structure used during the building of the algebraic system.
Definition cs_equation_priv.h:69
void cs_equation_prepare_solve_t(void *eq_to_cast, cs_real_t *p_x[])
Carry out operations for allocating and/or initializing the solution array and the right hand side of...
Definition cs_equation_priv.h:181
void cs_equation_restart_t(cs_restart_t *restart, const char *eqname, void *scheme_context)
Generic prototype dedicated to read or write additional arrays (not defined as fields) useful for the...
Definition cs_equation_priv.h:308
cs_real_t * cs_equation_get_values_t(void *scheme_context, bool previous)
Compute or retrieve an array of values at a given mesh location Currently, vertices,...
Definition cs_equation_priv.h:293
void cs_equation_update_field_t(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values if required (...
Definition cs_equation_priv.h:199
void cs_equation_apply_sitffness_t(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, const cs_property_t *property, const cs_real_t *pot, cs_flag_t loc_res, cs_real_t *res)
Compute the cellwise stiffness matrix associated to the property given as a parameter and apply it to...
Definition cs_equation_priv.h:241
void * cs_equation_free_context_t(void *scheme_context)
Destroy a scheme data structure.
Definition cs_equation_priv.h:85
void cs_equation_init_values_t(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Initialize the variable field values related to an equation.
Definition cs_equation_priv.h:101
void cs_equation_solve_t(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *eqc)
Build and solve a linear system within the CDO framework.
Definition cs_equation_priv.h:122
void cs_equation_get_builders_t(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Retrieve cellwise structure including work buffers used to build a CDO system cellwise....
Definition cs_equation_priv.h:275
void cs_equation_set_dir_bc_t(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, cs_real_t field_val[])
Set the Dirichlet boundary stemming from the settings.
Definition cs_equation_priv.h:143
void cs_equation_extra_op_t(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Generic prototype for extra-operations related to an equation.
Definition cs_equation_priv.h:260
Definition cs_restart.h:95
Definition cs_equation_priv.h:321
int field_id
Definition cs_equation_priv.h:339
cs_equation_restart_t * write_restart
Definition cs_equation_priv.h:442
cs_equation_extra_op_t * postprocess
Definition cs_equation_priv.h:438
void * scheme_context
Definition cs_equation_priv.h:373
cs_equation_get_values_t * get_edge_values
Definition cs_equation_priv.h:446
cs_equation_solve_t * solve_steady_state
Definition cs_equation_priv.h:433
cs_equation_extra_op_t * current_to_previous
Definition cs_equation_priv.h:439
int boundary_flux_id
Definition cs_equation_priv.h:340
cs_equation_builder_t * builder
Definition cs_equation_priv.h:367
int main_ts_id
Definition cs_equation_priv.h:344
cs_equation_param_t * param
Definition cs_equation_priv.h:350
int id
Definition cs_equation_priv.h:337
char *restrict varname
Definition cs_equation_priv.h:338
cs_equation_apply_sitffness_t * apply_stiffness
Definition cs_equation_priv.h:437
cs_equation_prepare_solve_t * prepare_solving
Definition cs_equation_priv.h:457
cs_equation_get_values_t * get_face_values
Definition cs_equation_priv.h:445
cs_equation_get_balance_t * compute_balance
Definition cs_equation_priv.h:436
Definition cs_equation_priv.h:434
cs_equation_free_context_t * free_context
Definition cs_equation_priv.h:430
cs_equation_set_dir_bc_t * set_dir_bc
Definition cs_equation_priv.h:455
cs_equation_get_builders_t * get_cw_build_structures
Definition cs_equation_priv.h:449
cs_equation_init_context_t * init_context
Definition cs_equation_priv.h:429
cs_equation_update_field_t * update_field
Definition cs_equation_priv.h:458
cs_equation_restart_t * read_restart
Definition cs_equation_priv.h:441
cs_equation_init_values_t * init_field_values
Definition cs_equation_priv.h:432
cs_equation_get_values_t * get_cell_values
Definition cs_equation_priv.h:444
cs_equation_build_system_t * build_system
Definition cs_equation_priv.h:456
cs_equation_get_values_t * get_vertex_values
Definition cs_equation_priv.h:447
Definition cs_cdo_toolbox.h:68
Definition cs_cdo_local.h:60
Definition cs_cdo_local.h:146
Definition cs_equation_param.h:193
